  1. Aug 20, 2022 at 1:51 PM
    nevadawolf03
    nevadawolf03 Well-Known Member
    PNW
    2016 SR5 DCLB
    SR wheels, side marker black-out, Clazzio's, Tweeters, Tailgate inserts, interior vinyl inserts
    +1. I also put a tarp on the bottom for easier clean up as well.
    rgljr831 and Stuck in VT like this.
  2. Aug 20, 2022 at 2:24 PM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Picked up an OEM oil filter, 6 quarts of Valvoline EP 5w30, Valvomax drain plug, and a K&N cabin filter.
    Also grabbed some high temp paint for the rear hubs.
    Maintenance is paramount.
    markram, TacoTime55, rgljr831 and 2 others like this.
  3. Aug 20, 2022 at 2:24 PM
    MGMDesertTaco
    It's a black push pin that sits inside of another black receptacle thingy. Basically, the receptacle thingy goes in first then the push pin goes in the center of that and holds it in place. It's just like the black push in retainer clips holding the front grill on only smaller.
    You've probably dropped both pieces in the door or on the ground somewhere.
    rgljr831 likes this.
  4. Aug 20, 2022 at 2:27 PM
    MGMDesertTaco
    Those are nice, but I was thinking cheaper like the Garmin tandem for the front and Garmin mini 2 for the rear or maybe this 4k Kenwood system...
    https://www.crutchfield.com/p_113DRVA601/Kenwood-DRV-A601WDP.html
    Garmin has voice recognition, but it's not 4k resolution. :notsure:
  5. Aug 20, 2022 at 2:33 PM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    From the other videos I seen on removal and re-installation, you need to find the piece that went into the door, then re-insert it into the body of the clip. The thin inner part simply gets pushed back in so it's flush with the clip body that forces the sides of the clip body to move outward and thus holds your door panel to the door frame.
  6. Aug 20, 2022 at 2:59 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    The clips used in the door panels are very common. Take a pic of the one in the other door and measure the hole size. Then source from Amazon. You should be able to find a variety pack or purchase a container of the exact ones easily.
    stftaco likes this.
  7. Aug 20, 2022 at 3:10 PM
    21trd_mike
    21trd_mike Member
    Michael
    Tampa, Fl
    2021 Tacoma TRD off road
    Got TRD pro wheels installed:cool:. From that TRD sale a week ago or so.
  8. Aug 20, 2022 at 3:19 PM
    Cappy
    Cappy Well-Known Member
    Georgia
    Yea I guess I should have looked at the other door but it started raining. I have the piece that pushes in the hole, its what's on the other side of the metal panel that fell out. I'm not sure I can figure out by looking at the other door if it's on the backside of the metal but I'll give it a shot. At least I didn't lose any of the clips that hold the sail panel on.......this time.
    Edit. So I just got a big laugh out of this scenario. The rain stopped so I went outside and looked at the passenger side and pulled out the push pin. There wasn't anything on the other side of the metal panel where the pin goes in. So I popped out the center of the pin and put it back. Then I went to the drivers side and looked at the hole again and there is a white piece of something on the other side of the hole where the push pin goes in. Guess what...it's one of the clips from the sail panel that I lost a while back that just got caught up in there...lol. Just left it there and popped out the center of the push pin and put it back in. Held just fine. Guess when I went to put it in originally, the old clip was in the way and I thought I had pushed something through the hole by accident. Apparently I need to get some rest. :p
    oostroma[QUOTED] and markram like this.
  9. Aug 20, 2022 at 3:29 PM
    Tony382
    Tony382 Well-Known Member
    2022 Tacoma TRD Sport
    Bilstein 5100's installed all around today, stock setting. Originally wanted the 4600's but they have been on backorder for some time. I'm happy tho knowing that if I did want to raise the front end a bit, I can adjust the clip setting on these.
  10. Aug 20, 2022 at 5:19 PM
    CorsoTaco
    CorsoTaco 22 Trail loaded out
    North Ga
    22 LR Trail
    C4 sliders, TRD CAI, Spod source LT, CBI covert, 6112/5160's, OME heavy leafs, Wheeler's super bumps with flip kit, RCI engine skid, R4T lower control arm skids, SOS Concepts gas tank skid, Rago bed stiffeners, 255/85/16 ST Maxx, MESO stuff, AJT stuff, Martin cab rack, rough country 40" single row bar, Rigid 30" SAE light bar, SDHQ ditch brackets, Rigid SR-M ditch lights with amber covers, AVS hood thingy and door thingys, Bulletpoint phone and tablet mount, Taco Vinyl raptor lights, Tacoma Lifestyle sequential turn signals, Tufskinz door sill protectors, and a few other knick knacks.
    Well, trying to start my 5160 install, but the damn bolt that I need to remove to put in the brake line spacer just keeps spinning....
    F... me
    Edit: I finally got it out. After using a flathead and prying the bracket up as I slowly loosened it, as well as saying a few prayers.
    skyking3, davidstacoma and rgljr831 like this.
  11. Aug 20, 2022 at 6:19 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    4x4 with stock suspension?
    TexasWhiteIce likes this.
  12. Aug 20, 2022 at 7:13 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Picked up my fiberglass 3 inch wide front fenders today! They were already inferno and came from a member here who sold their truck.
  13. Aug 20, 2022 at 7:46 PM
    TacosMan
    TacosMan Well-Known Member
    Yeah you can see.
  14. Aug 20, 2022 at 8:12 PM
    shiftd
    shiftd Well-Known Member
    Pennsylvania, USA
    2020 Tacoma TRD Pro
    Did a few things the past 2-3 days.
    Relocated the media port for android auto / apple carplay to the center console. For my use this is more convenient.
    Turned the original USB port on the dash to charge only, and added an extra USB port on the top of the dash on my DMM from the Taco Garage. The new USB ports are powered by a power outlet fuse tapped and installed near the driver fuse box
    Also installed a Switch Pros 9100. Now I can spend some more money on accessories.
  15. Aug 20, 2022 at 8:27 PM
    Tony382
    Negative, I have a RWD Sport. I found the Sport suspension to be too stiff for my liking. I do appreciate the handling characteristics of it, but it definitely was too stiff. I would've replaced with Bilstein 4600's but they've been on backorder forever and I have a road trip coming up. I'm diggin the 5100's however although body roll has increased a bit.
  16. Aug 20, 2022 at 8:46 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Can’t wait to see those installed! Going with LT suspension? Gonna be awesome! :thumbsup:
    5nahalf[QUOTED] and 20tacoma17 like this.
  17. Aug 20, 2022 at 8:50 PM
    5nahalf
    Erik
    Minnesota
    For the time being its going to just run on the pro suspension I have (1.5 inch eibach lift springs installed). I am 2.5 inches lifted from stock. Im going to put some wider wheels on and some 32 inch tires.
    Eventually I want to put some long travel suspension, but I dont offroad much more than what I need to get to my fishing spots. Though winter time can make some fun "offroad" onroad driving.
  18. Aug 20, 2022 at 9:00 PM
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Is that a tent stake? And why tho?
    RIX TUX and musicisevil like this.
  19. Aug 20, 2022 at 9:04 PM
    Casey182
    Casey182 Well-Known Member
    Sacramento
    '20 TRD OR - '21 T4R ORP - '66 Chevy C10 SB
    For the memes
  20. Aug 20, 2022 at 9:52 PM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Removed this.
    Installed this. https://shop.enfigcarstereo.com/product/enfig-mic-toy1/
    W
    orks really well with my Aftermarket HU. Calls are clear and no more feedback on the other end. It snaps right in the empty spot in the overhead console. The OEM mic adapter will be for sale…
    nwmo likes this.
