  1. Nov 21, 2022 at 6:53 AM
    Tacospike
    Two Trucks
    Nice job!
    I had wondered when someone would try a blue. The specs / lumen on the Blue looked pretty low on the website but that looks pretty bright given the color. The white and amber pods are wicked bright
    and like that mounting much better
    757E6FAB-E1E4-4EC1-AA88-866331807DAD.jpg 7D1E0085-4CFA-4700-B301-7FFBB1674071.jpg
    Relaxo, RCrumb, BJK1280 and 4 others like this.
  2. Nov 21, 2022 at 7:19 AM
    TXsandyTaco
    TXsandyTaco Well-Known Member
    Meridian, ID
    2018 Quicksand TRD Sport
    I swapped out all the stock speakers with Kicker. Went with the component 6 x 9’s and tweeters up front (48KSS269) and the 6.75” in the rear (47KSC6704).
    I used 80mil Kilmat sound deadening on the interior and outer panels of all doors (this part took WAY longer than I expected).
    Notes on the ‘direct plug/play’ of these speakers (and mounting accessories/harnesses) from Crutchfield: it’s up to you to figure out how you attach the tweeters to either the brackets supplied by Kicker or to the universal bracket included by Crutchfield (a solid plastic disc you drill out to size). I opted for automotive 3M double sided tape but the rim of the bracket is so narrow it was tough to cut the tape to size.
    Definitely sounds far better than stock but I’m sure the factory HU is serving up much less power than these speakers need for optimal sound.
    Side note: I too ended up with a grab bar bolt cover that won’t click back into place (top one only). Ugh. I see others have had the same problem so will check the pins to see if anything got bent.
  3. Nov 21, 2022 at 7:23 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    You do if you want the pressures to appear in the correct location on the display in the dash cluster. Turn on the truck and hold the button until the warning light flashes thrice, then drive for a while until the truck learns the sensor locations.
    If you’re only using tpms for the low pressure warning light, never look at the tpms display screen and only do a 4 tire rotation it won’t really matter
    Rocket23[QUOTED] likes this.
  4. Nov 21, 2022 at 7:25 AM
    Rocket23
    Rocket23 Licensed Dynacologist
    Rocket
    Pennsylvania
    2019 sr5
    The list is growing.
    A powered sub amp was my last addition with my kicker upgrade. Sound deadening was a must. Sounds clear even cranked any of that 3m tape. Might cure the cover problem.
  5. Nov 21, 2022 at 7:27 AM
    Rocket23
    Rocket
    Pennsylvania
    2019 sr5
    Nope 5 tire. I threw a coupla hundred for the luxury to do that lol.
  6. Nov 21, 2022 at 7:34 AM
    musicisevil
    Alaska
    2019 TRD Sport
    Hey me too! I like having a matching sized spare and the added tire life. In that case you have to remove the sensor ID of your new spare from the ECU and add the ID of your former spare which you put into rotation. The 3rd gens can only store and learn the locations of 4 sensors.
    Serval ways to do it; Techstream, tpms tool or one of the obdii dongles
  7. Nov 21, 2022 at 8:08 AM
    General Chaos
    General Chaos I like pie.
    Joe
    NC
    2022 MGM Tacoma OR TRD 6MT
    Hey can anyone post a link to the thread where you can ask for the correct OEM part numbers? I’ve seen it before but I can’t find it in a search.
    I need to put that on my watch list.
  8. Nov 21, 2022 at 8:11 AM
    TXsandyTaco
    Meridian, ID
    Which sub did you go with and where did you mount it?
  9. Nov 21, 2022 at 8:27 AM
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    Had these made up in reflective black 283AA541-9968-4B70-BC92-0B7F0B89B02F.jpghad them on my mgm tundra and they glow pretty good at night
  10. Nov 21, 2022 at 8:40 AM
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
  11. Nov 21, 2022 at 9:08 AM
    4xThad
    4xThad Thad
    Thad
    Bend, OR
    2021 Cement Tacoma TRD OR DCLB; 2021 Blizzard Pearl 4Runner Limited; 2006 Tundra-SOLD
    Tint, DK ucas, Big Billies with Icon springs, SCS S6 wheels wrapped in Duratracs, a GFC, a Smartcap, martin OR RR, roam boxes sometimes, maxtrax and rotopax sometimes, and a ski rack other times
    whatcha gonna do with your old one?
  12. Nov 21, 2022 at 9:16 AM
    FlatbedTaco
    FlatbedTaco Well-Known Member
    2016 TRD Offroad 6 Speed MT
    Cooper 37's Black Rhino Bead Lock's Twin locked Kings Mits Alloy
    Transformed from camping setup to wheeling setup
  13. Nov 21, 2022 at 9:18 AM
    FifthGent
    FifthGent Well-Known Member
    2022 OR DCSB
    30E3713D-E058-4C7F-B88F-5D5DDE13629E.jpg 7E778049-AC60-4CE3-8341-63C93FC4AC29.jpg
    Swapped into a red tail light and added DIR mod at the same time
    BJK1280, AwesomeLaw68 and OldSaltyDog like this.
  14. Nov 21, 2022 at 9:53 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    I've never been pulled over for snow covering my plate.
  15. Nov 21, 2022 at 9:54 AM
    AwesomeLaw68
    Lawson
    Brand new.
    You now just have to black out all that chrome.
  16. Nov 21, 2022 at 9:55 AM
    Tacospike
    Two Trucks
    It's too far gone......
    RIX TUX likes this.
  17. Nov 21, 2022 at 9:55 AM
    AwesomeLaw68
    Lawson
    Brand new.
    Ok, I need a lesson, where is the TPMS reset button located.
    Tacospike likes this.
  18. Nov 21, 2022 at 9:55 AM
    Tacospike
    Two Trucks
    left-ish under the steering wheel
    Google photo but should work for you
    AwesomeLaw68[QUOTED] likes this.
  19. Nov 21, 2022 at 9:56 AM
    AwesomeLaw68
    Lawson
    Brand new.
    I will check that out later, Thank you.
    Tacospike[QUOTED] likes this.
  20. Nov 21, 2022 at 10:20 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    @Tacospike
    Thanks! I would have gone with aqua if it’s available. Yes, blue is still plenty bright. I might get some frosted film to cover and diffused the illumination. I did mount it on the curvature to point down as much as possible so it won’t blind anyone back there. Lol
    I almost went with red but decided I want some contrast. I can see the floor really well back there. One thing I noticed is it doesn’t dim as much as the light bars up front. Was yours on a Tundra?I think I got the idea from you.:D:anonymous:
    I might add a white max pod behind the rear seats. Hope the illumination won’t leak out…I’m gonna shine a flashlight back there when it’s dark.
    I just need to figure out a good mounting spot. Got any ideas?
