  1. Jan 3, 2023 at 11:19 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
  2. Jan 3, 2023 at 11:26 AM
    MDA57
    MDA57 Well-Known Member
    Mark
    Durham,NC
    2022 TRD OFFROAD Army Green /1997 4Runner
    NONE yet
    Washed and waxed
    [​IMG] [​IMG] [​IMG]
    JakNY, TacoHungry, Bagman and 16 others like this.
  3. Jan 3, 2023 at 11:45 AM
    Humble mtn adventures
    Humble mtn adventures Well-Known Member
    Mark
    Colorado
    2021 Tacoma TRD OR
    Those lights are sweet! Just wondering what did you tie into for the backlight to work on the Ditch Lights?
  4. Jan 3, 2023 at 11:49 AM
    Tacospike
    Two Trucks
    Seen a few people use an add a fuse to TAIL or Low beam
  5. Jan 3, 2023 at 11:55 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I'll be installing these backlit fogs this week. Just arrived today.20230103_114313.jpg
    BJK1280, japjoe7, RCrumb and 11 others like this.
  6. Jan 3, 2023 at 1:53 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Birthday gift from my wife for “her” truck installed. Applied 3 coats of scotchguard a few days ago. These are microfiber
    japjoe7, oostroma, MiTacoTRD and 8 others like this.
  7. Jan 3, 2023 at 2:06 PM
    Crazy Larry
    Crazy Larry Active Member
    NJ/Phila
    2022 AG Trail Edition
    first oil change today at 5600 miles. I added a Fumoto valve and aluminum filter housing. Tires rotated.
  8. Jan 3, 2023 at 2:34 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Got my spacers installed on my BAMF behind the grill light mount.
    With the spacers the horns can stay mounted in the factory position, before they have to be flipped around and be pressed against the radiator.
    As you can see in one of my pictures the lights are still over 4" inches away from the inside of the grill.
    My one main concern is pushing all the weight of the metal bracket and lights 1.5" further out will put extra strain on the mounting points.
    I will definitely monitor the bolts regularly to make sure nothing breaks.
    To do this I used:
    3 - 1.5" long aluminum spacers with 3/4" O.D. and 5/16" I.D.
    3 - 80mm long stainless steel m6 bolts, cut down to 75mm for the top 2 and 60mm for the bottom bolt
    2 - m6 stainless steel fender washers to go between the spacers and radiator mounts.
    Reused all the washers and the 1 m6 locking nut that came with the light mount
    The lights are @Backwoods Adventure Mods 9" Prowlr lights
    They haven't been wired in or aimed yet, that is a job for a much warmer day.
    PXL_20230103_221510820.jpg PXL_20230103_221057949.jpg PXL_20230103_221108547.jpg PXL_20230103_221116624.jpg PXL_20230103_221532192.jpg
  9. Jan 3, 2023 at 3:00 PM
    84-4runner
    84-4runner Well-Known Member
    frank
    Northern Arizona
    2019 tacoma offroad
    intake mods, firestone airbags, campershell, backup lights,
    I like how you did that until I saw what you did I thought that you were going to use flat stock to move the light
    mounting points out. This looks like a better solution. It looks like the bottom ( lower ) mounting bolt and upright
    will take more stress but it shouldn't be much more than stock. The further out the lights are from the radiator the
    better the air flow will become behind the lights. So another couple of three inches would be even better. Just
    adding some additional support. You did a great job on this.
    ssd2k2 likes this.
  10. Jan 3, 2023 at 3:57 PM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Installed additional bed lighting on my '22 Limited Nightshade, very easy addition and helps a bunch. Went with the Toyota OEM version, a bit pricier, then I washed it! 20230102_120731.jpg 20230102_120738.jpg 20230102_122906.jpg 20230102_122946.jpg
    BJK1280, Sypherd, japjoe7 and 15 others like this.
  11. Jan 3, 2023 at 4:10 PM
    JohnB81
    JohnB81 Well-Known Member
    OC
    2018 Tacoma TRD Sport 4x4 DCSB
    trifold solid bed cover (Amazon) Pop & Lock tailgate auto lock LED Headlight/ fog lights, reverse lights, dome/plate lights AVS ventshades Smartliner front & rear floor mats Rough Country neoprene seat covers BHLM NiLight LED strip bed lights NiLight RGB LED strip lights behind rear seat storage NiLight RGB LED strip lights for under hood and behind the grill lighting NAVIKS Apple CarPlay interface on stock Entune system Auxbeam auxiliary fuse box/ switch controller Auxbeam custom fit switch panel (Etsy) Coin holder bucket (Etsy) Center console organizer HookeRoad center console vault 32” Slim LED light bar mounted on CaliRaised Offroad lower bumper brackets Suparee sequential turn signals in black smoke OEM bed mat Sokie Tech hood struts 14” Hood scoop LED light bar RGB Raptor lights with smoked lens K&N air filter with TRD air intake accelerator K&N cabin air filter ViAir portable air compressor TuffSkinz interior red color accents on doors and center console TRD faux Pro shift knob w/ TVD TRD decal Glove box letters from Tacos4Cheap MESO customs chrome delete MESO customs door handle blackout covers MESO customs minimalist key fob V1 & V2, red MESO buttons MESO customs puddle lights MESO customs dual color map lights Matte black steering wheel overlay TVD matte black glove box overlay Pedal Commander A/C drain mod Red/Black paracord grab handles Red seat pull straps LOSTAR faux Pro skid plate Rockville 8” powered subwoofer CaliRaised LED catalytic converter plates Hooke Road tailgate panel Rok-Block tailgate gap seal Rear cab USB mod (idea from @ClassyTacos) Xprite RGB rock lights Falken Wildpeak MT 285/70/R17 Painted calipers red w/ TRD decal Akebono brake pads eBay seat jackers 4WP rock sliders DS18 tweeters DS18 front speakers Bought it with: Black Rhino Hammer wheels Spacer lift 285/75/17 Toyo MT’s TRD Pro Grill Hertz Audio speakers/ KENWOOD tweeters
    New tailgate panel from Hooke Road. Install was nearly too quick and easy. Honestly took me longer to post this than it did to install.
    Happy with the product. Basically a big plastic cutting board with some cup holders. No more corrugated FRP knee pain or uncomfortable seat.
    u-Box Tacoma Tailgate Panel - Black Plastic Compatible with Toyota Tacoma 05-23 (2nd & 3rd Gen) Pickup Trucks https://www.amazon.com/dp/B09PVDSPPS
    Relaxo, BJK1280, kas2828 and 13 others like this.
  12. Jan 3, 2023 at 5:20 PM
    thewrongtone
    thewrongtone Well-Known Member
    Central AR
    ‘22 Army Green TRD/OR
    TRD Lift
    Does the nightshade trim come with “Pro” tail lights?
  13. Jan 3, 2023 at 5:45 PM
    quantumechanic
    quantumechanic Well-Known Member
    2022 Tacoma SR5 DCSB 4x4
    What steps do you have? Are you happy with them?
    I don’t think I’ve seen those before.
    Thanks
  14. Jan 3, 2023 at 6:07 PM
    OldSaltyDog
    Hampton Roads VA.
    Not sure but here's a picture of the Nightshade taillight...
  15. Jan 3, 2023 at 6:14 PM
    OldSaltyDog
    Hampton Roads VA.
    E.T. and burnttaco7 like this.
  16. Jan 3, 2023 at 6:15 PM
    TacoHungry
    TacoHungry Well-Known Member
    CO
    '22 AG DCSB TRD Off Road
    Installed the Z Precision cupholder, got tired of the wife’s hydro flask being in the way and becoming a projectile around turns
  17. Jan 3, 2023 at 6:26 PM
    dagsom
    dagsom Active Member
    San Diego
    AwesomeLaw68[QUOTED] likes this.
  18. Jan 3, 2023 at 7:19 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Guess I need to replace the “gen1” Motivx filter tool!
  19. Jan 3, 2023 at 7:38 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Same here. I really like it.
    afgixxer and TacoHungry[QUOTED] like this.
  20. Jan 3, 2023 at 7:44 PM
    beardo1_0
    beardo1_0 Well-Known Member
    Fremont, CA
    2023 Tacoma TRD Off Road
    Installed Yakima Overhaul bed rack. Was planning on installing Alpha Rex lights as well but ran out of daylight. And now that there’s a week long storm coming to Cali, don’t think I can work on the truck for a while
    BJK1280, TWUserName, markram and 5 others like this.
