  1. Feb 6, 2023 at 4:28 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Nice!!!
    StupaDazHo[QUOTED] likes this.
  2. Feb 6, 2023 at 4:37 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    As long as the tread is good enough quality I see going to a less wide tire is better also. The only concern for me would be cornering and traction. And the amount of load that the tires can handle compared to their wider tires. it would probably be less since it has less rubber. But if that’s not a concern then it’s a great idea!
    TartanEagle likes this.
  3. Feb 6, 2023 at 5:04 PM
    Kennythefisher
    Kennythefisher Active Member
    Kenny
    2017 Tacoma OR
    6112/5160-275/70/17
    It’s via Bluetooth, and the Garmin app.
    You download the video to phone
    /computer and you can edit . That was just a 10sec clip from a longer drive. You can view camera live view from your phone while driving . Only issue I have is , I have wireless car play via Bluetooth and the Garmin is Bluetooth as well. So I have to turn off my head unit or it wants to connect and override the camera connection.
    You can also take the camera of its mount and do all your downloads out of the truck, super easy. I bought the polarized lens for it and it helps with glare.
    stftaco[QUOTED] likes this.
  4. Feb 6, 2023 at 6:01 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Any pictures from the front or back was looking to get 235's for my next tire
  5. Feb 6, 2023 at 6:25 PM
    DuffyBank
    DuffyBank Well-Known Member
    235/85/16 Duratracs
    RCrumb, tektaco84, slimfl08 and 15 others like this.
  6. Feb 6, 2023 at 6:26 PM
    DuffyBank
    Contact areas are very similar because the narrower tire has a longer contact patch than the wider tire.
    Stuck in VT and BC Hunter like this.
  7. Feb 6, 2023 at 6:31 PM
    cgolf
    cgolf Well-Known Member
    2020 Tacoma TRD Off Road
    None
    Installed these replacement radio knobs. I think they are the Rav4 knobs. Found this mod on here. Not a big deal but I do like the looks and they are easier to grab.
  8. Feb 6, 2023 at 6:47 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    There is a very large thread called “the skinny on skinny tires” where one can read for hours….and hours…
    I agree that the gross contact area under a tire won’t be too far off the vertical load the wheel is supporting divided by the tire pressure. Unless you have a lot of vertical acceleration, (bouncing) that’s not going to vary much.
    MrMobile and DuffyBank[QUOTED] like this.
  9. Feb 6, 2023 at 7:00 PM
    Aval1996
    Aval1996 Active Member
    Andres
    2017 White Toyota Tacoma TRD sport LB
    Rancho leveling kit K&n intakr Pedal commader Meso customs chrome delete Red top optima battery Ripp performance coil packs
  10. Feb 6, 2023 at 7:13 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Beerpayzdabillz likes this.
  11. Feb 6, 2023 at 7:59 PM
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    Looks good. Are you running a spacer? They fill the wheel wells more than I thought.
  12. Feb 6, 2023 at 8:08 PM
    DuffyBank
    No spacers, ome 886/Dakar HD and pac brake airbags, stock trd or wheels
    kas2828[QUOTED] likes this.
  13. Feb 6, 2023 at 8:11 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    makes it easier to add power accessories, like audio amps, winches, lights.
    afgixxer[QUOTED] likes this.
  14. Feb 6, 2023 at 8:17 PM
    kas2828
    Austin
    Arizona
    Nice. I have Bilstein 5100s 887/icon but they have started to sag in the front with time and weight of full steel skids and sliders.How do you like the 886 for extra weight? I’m running 285/75/16 with a 1.25 spacer on stock Trd wheel as well. Took spacer and some cutting and trimming to work off roading.
  15. Feb 6, 2023 at 8:25 PM
    DuffyBank
    No issues with the 886 and they ride great. Bumper winch and full steel skids with no sag. I had the same on my second gen with an arb bumper and winch. They were on there for thirteen years and didn't sag.. I work in the bush so they see lots of forestry roads and exploration trails.
  16. Feb 6, 2023 at 9:24 PM
    seidita84t
    seidita84t Well-Known Member
    2017 Quicksand DCLB TRD offroad
    Hey there, no worries, too many posts to scrounge through anyway.
    At the moment, I'm not running this tire/wheel setup. Only because some friends from Supreme Suspensions asked to use my truck for SEMA this past year, and they've got a deal with Hostile and Falken. So the truck is currently running Hostile Mojave wheels with Falken Wildpeak MT 35s.
    To your actual questions though, suspension is fox 2.5s front and rear, Supreme UCAs, Supreme supplemental spacers (add a little more lift up front without having to over-preload the coil overs), Deavers out back. At the time of this Pic, the front of the truck was at about 3.25" of lift, with the rear being around 2.5"
    I can't say much about trimming. Prior to going up to the pictured tires (which are pretty much 34s) I was running skinny 33's, and had done the cab mount chop just as a preventative measure. I had also already damaged the front bumper, so I did the viper cut thing. And I can't say much about the inner fenders, because one REALLY good send with the 33s and the bumps not set right ripped those out a long time ago.
    Honestly depends how you're wheeling, and if you're wheeling. Overall though I've seen a good handful of people run this combination without major trimming and be pretty happy with it if not really wheeling hard.
  17. Feb 6, 2023 at 11:32 PM
    johnnytwotimes
    johnnytwotimes Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    link?
  18. Feb 7, 2023 at 6:00 AM
    Odlcjro01
    Odlcjro01 Well-Known Member
    Lee
    Rhode Island
    2021 Tacoma MGM DBC SR5
    LT265/75R16 tire, side steps
    MAS and 1Crusader like this.
  19. Feb 7, 2023 at 7:51 AM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Just got back from a Costa Rican wedding vacation. I got to say, I saw some cool 3rd gen Tacoma's.
    Lots of Helix, Nissan's and even a few Chevy trucks. Tons of Toyota SUV's
    Id guess that every other vehicle has some sort off-road related items. Most vehicles had roof racks with black abs style water tanks.
    Probably one out of twenty had roof top or bed top tents as well.
    Below is a GoPro video I put together of the trip.
    Pretty cool stuff.
    https://youtu.be/9U68N7zUhmo
  20. Feb 7, 2023 at 8:09 AM
    22LunarNM
    22LunarNM Active Member
    Wayne
    NM
    22 TRD OR
    Same guy tuned mine…loving it so far!
    OhNoItsMe[QUOTED] likes this.
