  1. Mar 6, 2023 at 5:11 AM
    Hauser94
    Hauser94 Well-Known Member
    2016 Black Tacoma SR5 DCSB
    Well they’re old I was just wondering if it’d ve okay to burn then until next winter, they came with the wheels
    RIX TUX likes this.
  2. Mar 6, 2023 at 5:13 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Sounds like you have a plan. Good luck
  3. Mar 6, 2023 at 5:42 AM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    RyanDCLB[QUOTED] likes this.
  4. Mar 6, 2023 at 5:46 AM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    My Tacos have been tuned since 2018. You won't be happy with your truck until you get it tuned. It's pricey but no more than sliders or a metal bumper. Best Mod there is. Get ahold of Paparay and he'll fix you up. He will treat you like his best friend.
    usmc2msu, dlb97as, markram and 6 others like this.
  5. Mar 6, 2023 at 5:51 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    You could try moving the front to the back and back to the front to see if this reduces the noise.
    Hauser94[QUOTED] and RIX TUX like this.
  6. Mar 6, 2023 at 5:53 AM
    Hauser94
    My question is will this damage my truck in any way. I can deal with the noise. I just want to know if the uneven tread is hurting my vehicle
  7. Mar 6, 2023 at 6:19 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Me older bro has the Kita saw, and doesn’t like it as it will shut off in the cut under certain conditions.
    I don’t know if it is still there, but there was/is a Milwaukee shop on Beach Blvd, northern part of OC where you can take your Milwaukee powered tools to get fixed. I have a grinder that is waaay old and it has always fired up for me(and still working). Alls it needs is a new cord and possibly a new brush.
  8. Mar 6, 2023 at 6:23 AM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Love mine, they make a case for them now, but back when I got mine, I had to improvise...20200701_004151.jpg 20200701_012642.jpg
  9. Mar 6, 2023 at 6:31 AM
    Topanga Taco
    Rick
    This is my go to saw on trails. Small enough to swing, but acts like it has big balls(machined for compression and finger ported) to cut through big wood if necessary.
    The legendary 346XP.
  10. Mar 6, 2023 at 6:34 AM
    oostroma
    oostroma (Boomer)
    Ontario
    IMO, I don't think so. Only if the tires were un-ballanced would it cause an issue over the long term. If you are experiencing vibrations or pulling in either direction then I would have them re-ballanced for piece of mind.
    Hauser94[QUOTED] likes this.
  11. Mar 6, 2023 at 6:45 AM
    tollster64
    tollster64 Well-Known Member
    Pennsyltucky
    2019 TRD DCSB
    No it’s not, and the noise will change slightly over time, becoming less prominent . However, tires that were mated to the original vehicle will continue to wear in the same pattern as well as the new pattern on your truck, so the lifespan isn’t the same as if you put brand new ones your vehicle.
    The variances in frame tolerances are a go-no go on the assembly line, they make final adjustments with toe, camber, and caster to meet the go no-go specification before they are shipped.
    They will continue to wear in the original pattern from the vehicle they were removed from, which may be minimal, but inherent. A good example of this is a tire that is worn on the front of a new truck due to toe in or toe out. You may notice the wear, and take your truck in for an alignment and even rotate those tires to the rear during the service. However, that wear pattern is imprinted on that tire now and will continue to exhibit it throughout the balance of its life span. The only thing you are now doing is trying to minimize that wear pattern for longitivtiy of the tire.
    MGMoverland and Hauser94[QUOTED] like this.
  12. Mar 6, 2023 at 6:47 AM
    Topanga Taco
    Rick
    Finger ported 346xp.
    tollster64 likes this.
  13. Mar 6, 2023 at 6:47 AM
    Hauser94
    Thank You I appreciate it
  14. Mar 6, 2023 at 6:48 AM
    Hauser94
    Thank You, yeah there are zero vibrations or pull so that puts my mind at ease thank you
  15. Mar 6, 2023 at 6:51 AM
    Topanga Taco
    Rick
    I’ll stop, but I do swing Huskies :0)
  16. Mar 6, 2023 at 6:53 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Yes 400W running 100W not running.
    BC Hunter likes this.
  17. Mar 6, 2023 at 6:55 AM
    MTB58
    MTB58 Well-Known Member
    Marty
    Prescott, Az
    2022 TRD Offroad DCSB Army Green
    Redar TBC, Window Tint, 265x75x16 Wildpeak, OEM TRD LIft, Soft Tonneau Cover, RCI Full Steels Skids, RCI Sliders
    I have not had mine tuned, because the pedal response doesn't bother me and the shifting has not pushed me over the edge just yet. When the shifting bothers me the most is when I tow our small travel trailer, but I just manually shift it and it works for me.
    There are thousands of pages on this forum regarding tunes people have done, just do a search.
    musicisevil likes this.
  18. Mar 6, 2023 at 6:58 AM
    tollster64
    Pennsyltucky
    2019 TRD DCSB
    I love my XP 346, and did a mild exhaust port while retaining the approved spark arrestor. It was a little involved using a dremel and the final adjustment was rolling back the high RPM to reduce the possibility of over reving, opening it up increased throttle response time for limbing, but also a very noticeable mid range and top end punch on deep long cuts with full chisel chains in hardwood. The adaptive tuning didn’t curtail the top end rpm, so there was a high side adjustment that was required on the carb screw. No sluggishness, quick start and warm up, and an instant on off the bottom, the adaptive tuning meshed well with this mod. The sound is a bit louder over the stock saw.
    I found the XP exhaust mod on arboristsite.com forums.. and there are other threads and YouTube vids for it..
    Topanga Taco[QUOTED] likes this.
  19. Mar 6, 2023 at 7:02 AM
    tollster64
    Pennsyltucky
    2019 TRD DCSB
    you’re very welcome. It’ll be fine based on what you’ve mentioned.. give it some time and the road noise will quiet down some, it’s most noticeable at first..
  20. Mar 6, 2023 at 7:16 AM
    Topanga Taco
    Rick
    Good stuff. It’s a must that you tune the H after porting. The rpm’s will rise and you need sufficient fuel to feed it. Don’t worry about the 346 over revving. They can take that and then some.
    AS were the days! But I’m not a member anymore. But that’s where I got started too.
    tollster64[QUOTED] likes this.
