  1. Mar 13, 2023 at 8:18 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    The DB installation documentation recommends keeping the Cross Bin all the way forward against the cab to keep the Cross Bin and its contents from bouncing around. As well as the aforementioned problem with interfering with locking rods and safety catch. Can't say if this would apply to the OEM cover. The Cross Bin support flanges rest on the bed rails so technically you could put it anywhere it doesn't interfere with the cover.
    Spadi_5 and Pilvr83[QUOTED] like this.
  2. Mar 13, 2023 at 8:39 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Why did you bolt it down?
  3. Mar 13, 2023 at 9:01 AM
    patos tacoma
    patos tacoma Well-Known Member
    May want to unbolt it……..it’s measured, so it’s not going anywhere……
    And rebolt your bed correctly (more important)
    Unfortunately, you’ll have to live with the holes in your bed cover.
    BC Hunter likes this.
  4. Mar 13, 2023 at 9:08 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Looks good asf. Does it support wireless AA?
    VTi EG6 and Crowkiller06 like this.
  5. Mar 13, 2023 at 9:14 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    I thought we just advanced the clocks an hour yesterday. Looks like you advanced right to Friday.
    SoCalSport, burnttaco7, Burns and 9 others like this.
  6. Mar 13, 2023 at 9:34 AM
    WAFTLR
    WAFTLR Member
    2022 TRD OR DCSB
    When purchasing you have the option to get a transfer case skid that fits stock (with the exhaust hanging down under the T-case) or a higher clearance skid that requires an exhaust re-route for fit.
    I went with the higher clearance one. A local muffler shop did the reroute work for $100.
  7. Mar 13, 2023 at 10:49 AM
    StupaDazHo
    StupaDazHo KDMAX Pro Tuner in DFW / North Texas area
    Cory
    Bedford, Tx.. DFW
    2021 Taco TRDSport Lifted
    TRD Lift Bed Mat and Tonneau cover Tinted Windows, Tailgate Letters, Interior LED Light, Raptor Lights
    Tuned on Friday afternoon with KDMAX Pro 9.0 - Sport.. Its a huge difference. I'm used to keeping the RPM's up to prevent the gear hunting. I'm having to relearn to drive it in town due to the new pedal response. Honestly the truck feels lighter, and very quick off the line. Its completely different than stock.. Will run a tank or 2 through it to let it settle in.. and then decide if I keep Sport.. or transition to Normal or Lite.
    As others have said, I should have done it sooner.
    robin303, MAS, tugboat_marty and 6 others like this.
  8. Mar 13, 2023 at 10:51 AM
    d0ugh0ck
    d0ugh0ck Well-Known Member
    NJ
    Making some brackets for handles with scraps from my rack build.
    Vinny C, GRNT4R, ClassyTacos and 5 others like this.
  9. Mar 13, 2023 at 11:14 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    About 30 more hours put into the audio install over the last week and it's getting close to being wrapped up. All speakers installed, crossovers mounted, almost 100' of speaker wire ran, and amp rack modified a bit. Pushing 12g wire thru the door accordion tubes on this truck is up there with the least fun things I've ever done. It's so much work to make it look like you didn't change anything, but at least my speakers match my wheels lol.
  10. Mar 13, 2023 at 11:15 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    More parts just arrived for my spring time upgrades.
    So far my upgrade list is - front and rear bumpers, 1.5" lift with new leaf pack, AuxBeam control panel, 400w anytime mod, wiring in a WeBoost cell booster, and vinyl wrapping my fender flares
    danny15l, MAS, tugboat_marty and 5 others like this.
  11. Mar 13, 2023 at 11:24 AM
    tehkei90
    tehkei90 Well-Known Member
    2021 Tacoma TRD OR
    took my 2 year old truck to get the last oil change for free (at the dealership) and they replaced my battery, under warranty. is this normal? also the truck only had 7700 miles on it. seemed like the battery went bad took quickly. but yay new battery i guess...
    MAS, BC Hunter, markram and 2 others like this.
  12. Mar 13, 2023 at 11:31 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    What does that average out to? 320mi/mo = 10-11mi/day... Weekly you should at least be driving 30+min for the alternator to recharge the battery. They might have performed an alternator and load-test and determined the battery was not going to last too much longer. That was rather nice of them to replace it.
  13. Mar 13, 2023 at 11:33 AM
    ssd2k2
    Keith
    Minnesota
    Depends on the temperature of where you live, how often you drive, and how far you drive.
    Hot climates kills batteries quicker, not starting the truck for long periods of time the battery will drain, and short trips don't give the alternator enough time to charge it back up.
    Might want to invest in a battery tender to keep the battery topped off.
  14. Mar 13, 2023 at 11:39 AM
    Hansamzac
    Hansamzac Well-Known Member
    Central Ohio
    2022 Tacoma TRD OR Lunar Rock
    BakFlip M4 tonneau, debadged, LED interior lights, LED bed light, Rhino mud flaps, window tint, blacked out chrome bumper, Clazzios
    Doesn't match truck color but I shouldn't misplace it either.
    japjoe7, MAS, iScramble and 8 others like this.
  15. Mar 13, 2023 at 11:41 AM
    tehkei90
    2021 Tacoma TRD OR
    Yeah that could be it, I may have to look into one of those Battery tenders. I used to drive alot more, but since i started WFH my poor truck has just been sitting. except for weekends.
    ssd2k2[QUOTED] likes this.
  16. Mar 13, 2023 at 11:43 AM
    ssd2k2
    Keith
    Minnesota
    I use one of these for my Miata.
    I drive it maybe 200 miles a year and am on year 5 with the battery.
    https://www.amazon.com/gp/product/B00068XCQU?ie=UTF8
  17. Mar 13, 2023 at 11:57 AM
    flakbait
    flakbait Well-Known Member
    2022 TRD OR DCSB 6MT
    35% Tint, OEM Floor Mats, Bed Lights, Door Sill Protectors, Bed Mat, A/c Drain Mod, Gas Cap Holder, LED Reverse Tail Lights, Pace Edwards Ultragroove Tonneau Cover, Yakima Crossbars, Black "Tacoma" Inserts, Black Emblems, Center Console and Glove Box Organizers, Paint Matched Bumper Caps, Chalk Bag Bottle Holder, OEM Bed Step, OEM Black Housing sr5 Taillights, Diode Dynamics Hitch Pod, Interior LEDs, Footwell Lighting, OEM Remote Tailgate Lock, VTAIL Taillights and Plenty More to Come!
    Any issues with the Retrax leaking at the front of the bed? I went with the Pace Edwards and think I should have gone with the Retrax... Where'd you purchase yours from? Looks good!
  18. Mar 13, 2023 at 11:57 AM
    DuffyBank
    DuffyBank Well-Known Member
    1/2" rubber washers on the bed bolts. Interesting.
    How do you plan on cleaning the bed of sand/dirt/leaves that work their way under the mat and keeping the drain holes open?
  19. Mar 13, 2023 at 12:21 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Installed the N2 Designs keyless entry/remote start kit. All plug play, pretty easy to install. I think the hardest part was the removal of the plastic part below the steering wheel... being I have the standard key, I really love having a remote to lock & unlock it now..:thumbsup:
    MAS likes this.
  20. Mar 13, 2023 at 12:40 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Please send some extra freedom to Canada aka the Venezuela of the north
