  1. Mar 17, 2023 at 6:48 PM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Biggest thing with mpg and towing is to get into 5th, I spent a lot of time at 63mph in 5th.
    Are you able to keep an eye on temps and torque converter lock up status?
    I highly recommend OBD fusion.
    CemenTRDgen and Canadian Caber like this.
  2. Mar 17, 2023 at 6:52 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I have a android headunit that can track all those things with a bluetooth obd plug, so I should be good.
    I did a little test this evening taking my daughter to tutoring. A stretch of road I normally get 16-17mpg on I was getting 21mpg according to the computer. Will be interesting to run a few tanks through as I have the last 20k miles logged with mpg and fill ups.
  3. Mar 17, 2023 at 6:57 PM
    mosccat
    Mark
    2020 OR
    NIce, what HU?
    You may have been extra cautious with the throttle, I do believe the dam helps +1mpg though, I do have a tonneau cover too.
  4. Mar 17, 2023 at 7:01 PM
    5nahalf
    Erik
    Minnesota
    I have been running a joying toyota corolla headunit for the past few years. It was made before joying found out that they worked in tacomas too, so its a little hacky, but it works well.
    I just got a tonneau cover last month, before that I had a soft topper and that thing sucked my gas tank dry. The gap between the top of the cab and the top of the topper was like 6 inches so it acted like a giant sail on the highway. I had to nearly go full throttle just to maintain 75 in the winter.
    mosccat[QUOTED] likes this.
  5. Mar 17, 2023 at 7:06 PM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    TRDRed likes this.
  6. Mar 17, 2023 at 7:33 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    Bagman and tollster64 like this.
  7. Mar 17, 2023 at 7:36 PM
    OhNoItsMe
    OhNoItsMe Well-Known Member
    NM
    2022 TRD OR
    This is wild as hell :rofl:
  8. Mar 17, 2023 at 7:56 PM
    Bassassasin1
    Bassassasin1 Active Member
    2016 TRD Off-road
    01045797-7929-47D3-82F5-E203A496B1BD.jpg New rubber! What y’all think?
  9. Mar 17, 2023 at 8:14 PM
    mbrenn
    mbrenn Member
    Matthew
    Just rolled 35k on mine (bought at 34k)!
  10. Mar 17, 2023 at 8:39 PM
    bismarck
    bismarck Well-Known Member
    2023 TRD Off Road
    I hit triple digits on the odometer ... if that counts?
  11. Mar 17, 2023 at 9:15 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    Happy Birthday!
    tacotrdyota[QUOTED] likes this.
  12. Mar 17, 2023 at 9:21 PM
    mbrenn
    mbrenn Member
    Matthew
    Pics or it didn’t happen
    I subsequently dropped $150 for a 35k service too… :/
  13. Mar 17, 2023 at 9:58 PM
    polodinks
    polodinks Well-Known Member
    Polo
    Florida
    did quite alot... oem style bed lights, led license plate lights, yellow fog tint and a course motorsports magnetic phone mount
    MAS likes this.
  14. Mar 17, 2023 at 9:59 PM
    polodinks
    Polo
    Florida
    jealous :bowdown:
  15. Mar 17, 2023 at 10:00 PM
    TacoATC
    TacoATC Active Member
    2023 Tacoma TRD Off-Road
    Got new wheels/tires put on after getting the run-around by another shop in town! Love the look! -10 offset with 265/70/R17.
  16. Mar 17, 2023 at 11:01 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Got started on my +2 kit tonight and got one side loosely bolted in. Will do the other side tomorrow, then need to do the hydro bumps, limit straps, and after that just waiting on a couple miscellaneous front end parts. Rocking 2wd until some Rcvs show up later this week.
    Roof Walker, 4xThad, Yota541 and 27 others like this.
  17. Mar 18, 2023 at 1:09 AM
    6mtTRD
    6mtTRD Well-Known Member
    2022 Celestial Silver Metallic TRD Off-Road
    Cilajet ceramic coating
    Got the Meso puddle pods installed. Install wasn’t nearly as bad as I thought and took me about 1.5 hours. I’m curious about others experience with them because of two things:
    1. The extra connector on the harness going into the mirror is NOT a match for the DRL lead of the V5 turn signals I have installed. I didn’t plan on using the DRL but just interesting since they were mentioned as being complimentary items.
    2. My dome light switch has NO control over the puddle lights. No matter which position the dome light switch is, the puddle lights come on whenever I unlock the truck or open the door. This one I’m kinda concerned about because sometimes I may want to unlock the truck without the puddles on. May have to message Meso on that.
    I also wonder if it would be possible to power another VLED pod light on the same circuit and attach it to the bottom of the door panel so when the door is opened, there is still light exactly where you’re stepping?
    I didn’t bother putting the driver side a pillar or sill molding back on because I’ll be installing the Weboost and running wire for the ARB dual to a dash switch and also running wiring to the overhead panel to add a future switch for a front e-locker. Figure better to just get that all done while it’s apart because the KTJO a pillar with grab handle is a bit finicky to get on and off.
    4161E7F0-D982-4F33-A04E-B783A18656E1.jpg 2AE5552F-6E8C-4662-8737-31A565FFF3D1.jpg 2DB5408E-84F4-4689-9BAE-9F89D149B624.jpg FEAE543F-5428-4F7B-B7C8-731C8EDDB227.jpg
    BJK1280, MAS, RCrumb and 10 others like this.
  18. Mar 18, 2023 at 1:17 AM
    DustyMcTaco
    DustyMcTaco Well-Known Member
    2018 Tacoma TRD Sport
    Meso Taillights and other Meso stuff
    yeah not how i would do it, but i guess they trust the fuck out of those harbour freight jacks! i went for a walk and came back to see this. I quickly said a prayer and kept walking to go get some coffee.
  19. Mar 18, 2023 at 1:25 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Illumination under the door is a good idea. I did this with my access cab doors.
    gen2eng, MAS, D-knoww and 14 others like this.
  20. Mar 18, 2023 at 4:52 AM
    Spicietaco
    Spicietaco Well-Known Member
    2020 dblc trd off rd 4x4
    Wheels, tires, lift, shocks, fender flares
    20230326_152956.jpg New trd front skid plate, baja designs sport squadron fog lights plus an led light bulb kit for the interior....now to get out of the hospital and get it done.....20230302_121905.jpgupdate was able to get the new fog lights in
    BJK1280, MAS, RCrumb and 7 others like this.
