  1. Apr 16, 2023 at 5:11 PM
    CavalBlueTaco
    CavalBlueTaco Well-Known Member
    Michael
    2019 Cavalry Blue Tacoma TRD Sport
    None
    sweet toys in the garage too.
    Sean_Tippy[QUOTED] likes this.
  2. Apr 16, 2023 at 5:35 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
  3. Apr 16, 2023 at 5:38 PM
    wh11
    wh11 Well-Known Member
    2020 Cement OR
    I bought this Relentless Fab tailgate reinforcement a year ago and my dumbass thought I'd save some money and paint it myself. I forget if I used primer or not but I remember I used Rust-Oleum truck bed coating spray. How can I prevent the paint peeling like this in the future? What should I do now to correct this? Wondering if I just need to sand everything down and start over.
    AwesomeLaw68 and rgljr831 like this.
  4. Apr 16, 2023 at 5:39 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    Check out Fitztaprint on Etsy - solid seller with all sorts of different panel configurations!
    AwesomeLaw68 likes this.
  5. Apr 16, 2023 at 5:41 PM
    wh11
    2020 Cement OR
    Trying to fit a 275/70/17 spare under the truck. It's pretty snug here now but I'm worried that I can't get it all the way up in the spare wheel well. Do ya'll think this is an issue? I tried hammering out the two clamps but they didn't budge much. Thinking of grabbing a torch to ease the metal up a bit and having another go at it.
    AwesomeLaw68, andthen and rgljr831 like this.
  6. Apr 16, 2023 at 5:45 PM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Deflate the tire some or completely (if you have a compressor onboard). And pull it back towards the hitch while you bring it up
  7. Apr 16, 2023 at 5:56 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Finally got the Pro Shift Knob Illumination installed, and I love it.
    I also tied it into the security light as you can see from the pictures (blue for interior and red for the security).
    I tied the blue interior LED to be on when I have my headlights on. I installed LEDs in the cup holders and rear center console so it was easy to just tape into that wiring.
    Not sure what the difference is between the AT and MT but I did not have to drill a hole in the collar to pass the wires through.
    JohnB81, MrMobile, drizzoh and 8 others like this.
  8. Apr 16, 2023 at 6:03 PM
    RobWinNC
    RobWinNC ...needs more chrome.
    Rob
    Apex NC
    2016 Limited MGM 4X4 DCSB AT
    Finally got around to mounting the traction boards properly prior to upcoming shenanigans at the Outer Banks.
  9. Apr 16, 2023 at 6:03 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I used a 27oz dead blow hammer and they moved significantly with less than 10 whacks each. Pulling the spare rearward while lifting as mentioned above also helps.
    This is what my 285/70r17 looks like fully inflated:
    Edit: this is also with the lifter relocate linked several posts below
  10. Apr 16, 2023 at 7:09 PM
    Sean_Tippy
    Sean_Tippy Active Member
    Sean
    Eagle, Idaho
    2021 Army Green Tacoma DCSB TRD OR
    TRD Lift, FN (f)X Pro Gunmetal 17x8” wheels, 275/70 R17 BFG All Terrain T/A KO2s, Pace Edwards Ultragroove Metal retractable tonneau cover, Prinsu Cabrack, Southern Style Off-road slimline full plate bumper, Heiss 20” LED, Warn Evo-10S winch, Inno ski/board rack, Diode Dynamics SS3 fog lights, Billie Bars Mid-Rise 17” bed rack
    I have a KO2 spare in that size. The tire shop couldn’t get it to fit but I just got under the truck and shimmied it side to side while essentially bench pressing it and got it to squeak into the spot. I probably bent something in the process but it fits.
    markram and rgljr831 like this.
  11. Apr 16, 2023 at 7:10 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I opened my tailgate.
    My office chair hydraulic piston is entering a failing stage after 3 years. I considered swapping the Taco stock OR shocks for 51xx/61xx and use the original as a chair system, but I figured you would say they are not enough.
    So bought a new office chair instead ... Tempurpedic seatpad which is very comfortable so I just bought another one of the same model.
    Just a bit easier than transporting in a Corolla.
    MrMobile, markram, MTBTACORN and 3 others like this.
  12. Apr 16, 2023 at 7:23 PM
    brown71
    brown71 Member
    Scott
    Maine
    2019 Silver Sky Limited
    Bilstien 5100, Icon RXT leaf springs, Overland Tailor Tune, SmartCap EVO Adventure, Diode Dynamics amber fog lights, Wheeler’s U bolt flip kit and front bump stops
    I installed the Hypertech speedometer calibrator. It corrected the difference caused by the 33” tires I installed as advertised.
  13. Apr 16, 2023 at 7:29 PM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Strip it off completely, prepare the surface (it needs to be slightly rough to allow for good paint adhesion) then spare no expense on the primer and paint you choose, it really does make a difference. Seek advice from the paint representative of the brand of your choosing (Sherwin Williams for example) and they can easily offer you the best solution for your material and environment.
    markram, rgljr831 and TRDRed like this.
  14. Apr 16, 2023 at 7:38 PM
    Ncousins1
    Ncousins1 Well-Known Member
    Niko
    Gainesville, FL
    2023 Solar Octane TRD Pro Tacoma
    Got the new truck out on the trail for the first time. Had a blast
    71D31107-DC76-477E-85BB-DB3F7A19D29B.jpg 8780250E-5572-424B-88C6-F2762E808828.jpg
  15. Apr 16, 2023 at 7:41 PM
    bismarck
    bismarck Well-Known Member
    2023 TRD Off Road
    get it down to metal. wipe it down with isopropyl or mineral spirits. Use an etching primer. sand. primer. sand. paint. sand. paint. etc..
    Jmac2408, dleriche and scouterjan like this.
  16. Apr 16, 2023 at 7:46 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Good looking rig!
    Where are those trails?
    Ncousins1[QUOTED] likes this.
  17. Apr 16, 2023 at 8:03 PM
    Ncousins1
    Niko
    Gainesville, FL
    Thanks! It’s Citrus Wildlife Management Area in Florida
    wcoffman[QUOTED], 18Tacos and Sypherd like this.
  18. Apr 16, 2023 at 8:03 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Super sharp!
    MonkeyChief[QUOTED] likes this.
  19. Apr 16, 2023 at 8:22 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Hi-Lift Lift-Mate is finally here. I’ll test it out and post pics next weekend. Way too much going at work this week, won’t have the energy or patience after work this week. It does fit nicely in the wheel spokes though. :thumbsup:
  20. Apr 16, 2023 at 9:00 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Seeing if I need the back up light glare reducer. Technically it’s gorilla tape. And blocking 1/2 the backup light slot does reduce the glare when I reverse.
    sphinxbccp[QUOTED] and rgljr831 like this.
