  1. May 22, 2023 at 2:57 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    How about installing two large o-rings to take up the gap one on each side or perhaps two on each side.
    thomasburk[QUOTED] likes this.
  2. May 22, 2023 at 3:35 AM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Last time I purchased plastidip it wasn't $5.
    Last summer the price range in my area was $9-$11. Almost double what it used to be... Just plain ol black.
    burnttaco7 likes this.
  3. May 22, 2023 at 4:10 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I'm always interested in your posts, you really push the envelope!
    Are your rear leafs after market? They look very thin, and I'm thinking on your truck you would be requiring max performance. Do these leafs give you any lift above factory OEM? Thx.
  4. May 22, 2023 at 4:15 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Thanks for the suggestion. I would say all of the slack needs to be taken up from passenger side because the Gap is mainly on the driver side between the tailgate and the bed wall. I'm happy to try anything; rubber O- Rings, washers whatever, but I'm thinking an O-ring would get compressed too quickly, and the other issue I have is just getting this tailgate off I'm thinking I'm going to have to open the tailgate and start unclipping wire connections I'm just not into that right now but I'm starting to see it as a necessity if I want to get this handled. I'm hoping someone's going to chime in eventually with experience in solving this:)
    AwesomeLaw68[QUOTED] likes this.
  5. May 22, 2023 at 4:17 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Idk, but i think he was wagering a $5 bet.:notsure:
    WallyIAm, bls82261, wayupnort and 2 others like this.
  6. May 22, 2023 at 4:53 AM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    They sure do!
    I'm in Edmonton and I got a grill, turn siggys, and a couple other small things. I did get surprised with a duty charge though. I think it was about 10% ish?
  7. May 22, 2023 at 5:29 AM
    DuffyBank
    DuffyBank Well-Known Member
    musicisevil likes this.
  8. May 22, 2023 at 5:49 AM
    HuskerPaul
    HuskerPaul Well-Known Member
    Kansas
    2022 Lunar Rock Off-Road Access Cab
    A couple quick ones this weekend …
    (1) AC drain mod
    (2) Blind spot mirrors; those 2” round ones that stick on. Only I adjust the actual mirrors for blind spots and stuck these on the inside bottom of the mirrors to see the side of my truck and back tires. Works great.
    Next up … MillerCat shield
    TRDRed, MTBTACORN and rgljr831 like this.
  9. May 22, 2023 at 5:50 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yup! They are Chevy 63" leafs. They work pretty well (get ~13" of vertical travel, and max out my 16" shocks during flex) but I'm actually 3 linking the rear of the truck here soon.
  10. May 22, 2023 at 6:30 AM
    Crow41
    Crow41 Well-Known Member
    Lehigh Valley PA
    nice work!
  11. May 22, 2023 at 6:32 AM
    Crow41
    Lehigh Valley PA
    You did a great job!
    fellow_expert[QUOTED] likes this.
  12. May 22, 2023 at 6:48 AM
    fellow_expert
    fellow_expert Well-Known Member
    2019 Midnight Black SR5 4x4
    Thanks! It definitely took longer to prep/mask everything off than it even did to paint, but I’m thrilled with how it turned out.
    bls82261 likes this.
  13. May 22, 2023 at 6:50 AM
    wildland89
    wildland89 Well-Known Member
    2013 Tacoma ACLB
    Finished helping a buddy build out his truck bed this weekend. He was looking at a Goose Gear set-up, and I said we could make something customized and better for less money. Three weekends later, here we are. He's still touching up some paint :rolleyes: I know how he drives , so we took extra care in trying to make this thing bomb-proof. Because he was looking at like $6k for everything from Goose Gear, his budget was basically anything under that amount. So, we built an airplane. I offered to do everything out of plywood to save a ton of money, but he opted to go with 8020 aluminum extrusions for the weight savings and strength. Not cheap, though.
    There's a 3/4" plywood bottom plate attached to the truck using the factory bed mount bolts. A 1/4" piece of steel flat stock bolts to these, and the plywood is bolted to the flat stock. The frame for the drawers and deck is all 8020, and is attached to the bottom plate using nutserts and bolts. Rubber diamond plate on top of the top deck, which is 1/2" plywood to save weight. In the back driver's side corner are his dual jerry can mount and jack mount. And there's a propane mount behind his fridge slide-out.
    Going to use the experience, and the scrap plywood and 8020 extrusions and parts to make a rear-seat delete for my 2nd Gen sometime this fall.
    IMG-6907.jpg IMG-6903.jpg IMG-6902.jpg 70399267921--E935C0F8-A8B1-4869-9C90-1C8B7E767686.jpg
    Mrod18, tektaco84, Castle 4 and 42 others like this.
  14. May 22, 2023 at 7:11 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    It's usually the delivery company not the shipper that charges those fees. Fedex and DHL are the worst. They always charge GST, an import fee and an arbitrary customs fee. They don't always if ever forward those fees to the Govt agency. Usually 10% or more. There are shippers like USPS who don't do that.
    oostroma likes this.
  15. May 22, 2023 at 7:15 AM
    Dschiz
    Dschiz Well-Known Member
    2022 Toyota Tacoma TRD Sport (Super White)
    Factory 2-inch lift kit with Toyota Heritage Grille. Added some heritage color tri-color vinyl to hood and rear.
    Purchased truck February 2022. Finally hit the 10K service...great experience with local Toyota dealership. Oil changed/tires rotated....all good. I could watch also as it was at the edge of bay while they did the work. *Bonus they do a video under the truck and give you a play by play on how everything looks...
  16. May 22, 2023 at 7:16 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    LEDs are getting closer every year but until their emitters are the diameter/shape of the pencil lead sized halogen filament that the projectors are specifically designed for, their focus and throw won’t be better than an h9.
    They are really good at lighting up the area immediately in front of the vehicle though, and that’s all people in urban settings with complete streetlight saturation want
    BC Hunter likes this.
  17. May 22, 2023 at 7:20 AM
    Signatureinc
    Signatureinc Well-Known Member
    Doug
    Flat Land, Ontario
    2019 TRD OR Access Cab
    I bought mine used so brought it to a more local Toyota dealership for service so wasn’t sure how they would accept me and they have been great and oil changes are only $80 CDN. I like the idea of watching too and their service bays are wide open so watching is easy haha
    Dschiz[QUOTED] likes this.
  18. May 22, 2023 at 7:26 AM
    Signatureinc
    Doug
    Flat Land, Ontario
    I think we have all dropped our phone/wallet/keys down the Taco black abyss….has anyone used these I’m tempted because I literally keep my phone plugged in so if it falls I have a life line..
  19. May 22, 2023 at 7:27 AM
    AwesomeLaw68
    Lawson
    Brand new.
    You don't have to unclip the wires, you slide off the cables that hold the tailgate up, and then lift the tailgate off with the assistance of someone, and slide on a very big washer or thick o-ring and go for it, perhaps adding bed stiffeners would help too.
  20. May 22, 2023 at 7:28 AM
    AwesomeLaw68
    Lawson
    Brand new.
    I purchased those off Amazon, so much cheaper and they are exactly the same thing, work wonders helping you stop dropping phones or french fries down the side of the seat.
