  1. May 31, 2023 at 10:59 AM
    StinkFu
    StinkFu Well-Known Member
    Pacific Northwest
    2022 Tacoma TRD Pro MT
    AJT Design Tacoma 4x4 Knob AJT Design Tacoma Climate Rings AJT Design Tacoma Door Handle Covers All-Pro Off-Road HD Rock Sliders Alu-Cab Tilting Fridge Slide Aluminum Radio Knobs Android Auto Cable ARB Twin Air Compressor AWE 0FG Exhaust with BashGuard - No Tips Badland Jack Mount Badland Off-Road Jack Baja Design Rock Lights / Scene Pods Black Door Handle Covers Bolton Velocity Off-Road Kit Cali Raised AC Drip Relocation Cali Raised Center Console Molle Panels Cascadia 4x4 45W Panels & Controller - Note: Refunded Ceramic Coating CourseMS Phone Mount Desert Does It Seat Blocks & Panel Diode Dynamics Chase Lights Diode Dynamics Ditch Lights Diode Dynamics Stealth Light Bar Kit Dual Circuit Breaker Battery Tie-Down Expedition Essentials Panel Bracket Factor 55 HitchLink Flag Stickers Glove Box Letter Inserts GloveBox Organizer Hella Supertone Horn Kit Icon 1.5 Inch Lift Rear Expansion Pack Interior LED Light Kit Interstate AGM 24F Battery KC Hilites Under Hood Light Krazy Beaver Shovel and Cover License Plate Frames Magnuson Supercharger/Mishimoto Radiator MMRAD-TAC-16 MAXTRAX Xtreme MAXTRAX Xtreme Mounting Pin Meso Customs Gasshole Meso Customs Vent Ring Kit MESO Overhead HexRack - Sunroof Nilight 3PCS 60 Inch Bed Light Strip Nitto Ridge Grapplers 285/70R17 Quick Charge 3.0 Dual Charger Socket RedArc Dual Input + 40 Amp Fuse Kit Relentless Fab Tacoma Tail Gate Reinforcement Rhino Rack Stow It Utility Holder Rhino Rack Stow It Utility Holder Rhino Sunseeker 2.0m Awning Rhino USA D Ring Shackles Rhino USA Trailer Hitch Lock ROAM Vagabond Rooftop Tent ROAM Vagabond Rooftop Tent Annex RSI SmartCap Evo Sport RSI SmartCap Platform Rack SDHQ Battery Terminal Kit Seven Sparta Grill Led Lights Shift Knob Adapter SmartCap EVO Security Screen - v2 Smartcap MOLLE Panel Steering Wheel Cover Steering Wheel Emblem SumoSprings Front SumoSprings Rear Supreme Suspensions Front Tow Hooks Switch-Pros 9100 Switch-Pros Power Tray Wiring Bundle Tacoma Door Clean Up Kit Tacoma Door Sills Tacoma Lifestyle Sequential Turn Signals Tacoma Tailgate Inserts Tail Gater Tire Table Total Chaos Bed Stiffeners Toyota Cargo Net Toyota TRD Pro Shift Knob TRD PRO 17 Matte Black Alloy Wheels TRD PRO CAI Box & Accelerator TruckVault - Utility Height Uptop Alpha Rack - 38" Extreme LEDs Uptop TracMOUNT Vanultra Quick Release Tent Mounts with Lock Vinyl Letter Decals for Tailgate Handle Vinyl Letter Decals TRD Pro Bedside Vinyl Letter Decals TRD PRO Grille VLEDS Dual Output Front Footwell Kit VLEDS VTAILS Taillight Conversion Kit WeatherTech Bug Deflector WeatherTech Rain Guards Wescott Tacoma Fox TRD PRO Lift Kit
    Trimming the hose would probably help, but it snakes down without a problem. It was REALLY difficult to get everything attached though. Attach the reservoir first with the new bracket. Then attach the FRONT bolt on the tray. Then you have to jam the tray back all the way to be able to get a socket around the back bolt. I couldn't reach under there with a wrench. What I don't like is that the reservoir pushes up hard against the plugs of the SP now (see pic). I'm going to remove the reservoir and bend the OEM bracket to push it back a bit. You can pull the plastic reservoir up and out of the OEM bracket easily since it just slides in. For now it seems to be ok. Good luck!
    andthen likes this.
  2. May 31, 2023 at 11:15 AM
    DuffyBank
    DuffyBank Well-Known Member
    oil and filter change
    rgljr831, BC Hunter and wcoffman like this.
  3. May 31, 2023 at 11:25 AM
    JLD124
    JLD124 Some Guy
    Josh
    Out West
    22 OR 6MT
    I have an exhaust tip in the pile but I’m good without it
    rgljr831 likes this.
  4. May 31, 2023 at 11:30 AM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I've fitted "sheep fleece" seat covers on my 2021 Sport.
    The seating was not a problem for a recent cross country and back jaunt,
    We drove 9000 miles, about 400 miles per day. Tented at night, (i.e. slept on the ground with a therma-rest pad)
  5. May 31, 2023 at 12:11 PM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Installed the rear blue Sumo Springs last weekend. I can definitely tell a difference in how the truck rides. Sometimes better, sometimes worse depending on the road conditions. I’ll be loading the truck up with landscape timbers and fence parts soon, so I figured these will help.
  6. May 31, 2023 at 12:31 PM
    SRIRACHA1006
    SRIRACHA1006 Member
    2023 Tacoma SR5 SX
    brother please share the link for those rain guards please
  7. May 31, 2023 at 12:37 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Are the rear resi's clocked correctly? Looks like the axle will crash into them at full tuck?
  8. May 31, 2023 at 1:02 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Petroleum based tire products do the damage. Tire shine helps protect from UV rays if you get the right stuff. Find the water based products. They are out there. If they are brown then scrub them.
  9. May 31, 2023 at 1:40 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Rear fog light with manual on/off switch, turning signal, & brake light.
    BOMBS, habaneroTrd, venezian and 8 others like this.
  10. May 31, 2023 at 1:49 PM
    Shiro213
    Shiro213 Well-Known Member
    Columbus, OH
    2019 Cement TRD Sport Manual AC
    Did the covers by chance extend the bottom seat any? I really just want that longer.
  11. May 31, 2023 at 2:22 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Rustoleum
  12. May 31, 2023 at 2:33 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Paint and Amsoil MPHD (heavy duty metal protector - waxy).
    Five years now in humid GA and zero rust!
  13. May 31, 2023 at 2:52 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    I used to use Por-15 for rust proofing, works great but I am cheap so once I ran out of the little tin my friend gave me I switched to using rustoleum primer to paint any bare metal.
    One nice thing about using rustoleum primer is the quick dry time.
  14. May 31, 2023 at 2:55 PM
    994door
    994door Active Member
    '19 TRD Off Road
    Changed the serpentine belt today, 2019 w/26k miles. It started chirping a little yesterday and a lot this morning. It also fixed some surging I’ve had for about 3yrs that I thought was just a truck thing.
    rgljr831 and TRDRed like this.
  15. May 31, 2023 at 3:01 PM
    Tacospike
    Two Trucks
    More light
    https://youtu.be/Pit33Lng2so
  16. May 31, 2023 at 4:57 PM
    TuesdayTaco76
    TuesdayTaco76 Well-Known Member
    Moochacho
    California… thanks for leaving
    23 Tacoma TRD OR SB CB (chrome bumper✊)
    Still all in my head… but I’m keeping the chrome bumper!
    What have I done to my third Gen today? Almost shit my seat! Door decided to pop open while I was taking a right turn onto an expressway. Got it shut while not shitting my seat… so I guess me shutting my door while driving is what I did to my 3rd Gen today :rofl:
    and yes, the door was closed before.
  17. May 31, 2023 at 5:02 PM
    Lhd
    Lhd Active Member
    The OC.
    2021 Tacoma TRDPro Lunar Rock
    Tuesday taco that’s funny you say that. I had my driver door fly open on my while getting on the freeway about 2 months ago and I know it was closed latched. I thought it was the strangest thing and it hasn’t happened since. I wonder how many have had this happen with a fully latched door.
    Signatureinc and TuesdayTaco76 like this.
  18. May 31, 2023 at 5:08 PM
    TuesdayTaco76
    Moochacho
    So the door is off about maybe 1/16 of an inch, thinking maybe that could do it? Didn’t think that much of it since every panel on the Mexican beauty is way off. Guess it’s off to my least favorite place to have them try and “replicate” it. IMG_2666.jpg
    jerrybear, rgljr831, andthen and 3 others like this.
  19. May 31, 2023 at 5:20 PM
    Silverhand
    Silverhand Member
    Jon
    2023 TRD Off Road Access Cab, Electric Lime Metallic
    Rail inserts + fishing rod wall holder + a bit of drilling.
    eb_ghost, JDSmith, jerrybear and 19 others like this.
  20. May 31, 2023 at 5:21 PM
    Silverhand
    Silverhand Member
    Jon
    Another view.
    tcastig82, JDSmith, rgljr831 and 11 others like this.
