  1. Jun 14, 2023 at 2:40 AM
    Taco22trdor
    Taco22trdor Well-Known Member
    East Tennessee
    2022 Tacoma TRD Off Road White
    Do you make those mounts?
  2. Jun 14, 2023 at 3:56 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    BOMBS, TacoPacific, Dryvah and 30 others like this.
  3. Jun 14, 2023 at 4:24 AM
    Hansamzac
    Hansamzac Well-Known Member
    Central Ohio
    2022 Tacoma TRD OR Lunar Rock
    BakFlip M4 tonneau, debadged, LED interior lights, LED bed light, Rhino mud flaps, window tint, blacked out chrome bumper, Clazzios
    No existing wires for my truck. The heating pads come with a harness that has quick connections for both seat pads along with control switches and power wiring.
    I've yet to wire mine in as both seats are ready. It appears a fuse tap for the open sunroof fuse, a ground and another wire for power when lights are on. I'll be doing some YouTube searches before I make those connections.
    TRDRed, 51Beets[QUOTED] and rgljr831 like this.
  4. Jun 14, 2023 at 4:31 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Hey, I need to do this exact same thing on my 20. Would appreciate if you could share where you got the replacements and run into any problem installing?
    Order placed, for local pickup at Dealer. Thanks!!! $7.80 +tax.
    MrMobile, Kefka and rgljr831 like this.
  5. Jun 14, 2023 at 5:03 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Are you connected to the tiger mountain repeater? It’s a great repeater for the west side of the state.
  6. Jun 14, 2023 at 6:31 AM
    TekITGuy
    TekITGuy Well-Known Member
    Christopher
    Houston area
    2023 Tacoma SR V6 4x4 Double Cab
    TRD Wheels Toytec lift BFGoodrich KO2 Tires Cali Raised Amber fogs AuxBeam Ditch lights TRD shift knob TRD oil and coolant caps Escort X80 radar and direct wire kit Lasfit low beam headlights Redline Tuning Hood Struts more coming soon...
    Stared at the volume knob sitting at a traffic light, confused as hell. My other half had just called and not being able to hear her, I turned the volume up all the way to "max," and yet could still just barely hear her. I had the driver window cracked, so I raised it back up, which only marginally helped. I don't understand this, my 21' 4Runner at half volume was more than sufficient. Will investigate after work.
    rgljr831 likes this.
  7. Jun 14, 2023 at 8:06 AM
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
    Here is the link to where I bought them, would have gone with stealership but they make up for the low item price by jacking up the shipping cost.
    https://www.ebay.com/itm/221970829093
    Install was easy, watched a youtube vid for a refresher.
    thomasburk[QUOTED] and rgljr831 like this.
  8. Jun 14, 2023 at 8:21 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Six dollars ($6) a piece from a local dealership for me. Luckily no shipping cost added.
    My originals also lasted 5 years. Always cleared the glass perfectly - right up until one ripped lengthwise. So I went OEM again. Will see if they repeat their performance for another 5+ years.
  9. Jun 14, 2023 at 8:33 AM
    wicked4xyota
    wicked4xyota Member
    2019 TRD OR DCLB
    Just mocked a shifter rod for crawl box going in. Bent the rod into shape, the bolt will be welded on to be able to thread the shift knob on. I will be posting the build, progress on @4x4slowcoma in instagramIMG_8966.jpg IMG_8965.jpg
  10. Jun 14, 2023 at 8:34 AM
    beardedboomer
    beardedboomer Well-Known Member
    Josh
    Tacoma, WA
    2023 MGM Tacoma 4x4 OR
    Yep. The two mounts for the recovery boards are a few years old, having made them for my old Crosstrek.
    The two antenna mounts were recent creations; drawn up on adobe illustrator, briefly rendered in TinkerCad, then sent off to SendCutSend for waterjet, bending, and powder coat.
    Just don’t buy the bed nuts from Cali Raised LED. Half my order wasn’t threaded, covered in metal shavings and dust, incorrectly sized holes created, or a combination there of.
    Taco22trdor[QUOTED] likes this.
  11. Jun 14, 2023 at 8:35 AM
    beardedboomer
    Josh
    Tacoma, WA
    I think I have it saved, but can’t confirm if I’m being received or are transmitting correctly. Would need to spend some time with someone to verify freqs and codes.
    TacoGeeloor[QUOTED] likes this.
  12. Jun 14, 2023 at 9:35 AM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Next time try turning up the volume on the phone itself. I bet that fixes it.
  13. Jun 14, 2023 at 9:46 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Just for your information, if you're buying online you can select to have your Toyota part shipped to your dealer and then you can pick it up for no shipping charges added. Check out my post above I got the OEM blades from Toyota online for $6.80/pair plus tax.
  14. Jun 14, 2023 at 10:42 AM
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    Well today I got to vent about TacomaLifestyle and had to publicly call them out on here to FINALLY get a response from them (But still no resolution). Because emailing them repeatedly didn't seam to work... Productive day I guess?
    soundman98 likes this.
  15. Jun 14, 2023 at 11:04 AM
    GunthorNC
    Hey Carson, I got your calls and text's. There's no need to move this conversation behind closed doors. We tried private communications with the multiple cancellation emails I sent prior to this. Please send me a prepaid return label for the item I have repeatedly tried to cancel, and issue a full refund. You can wait until the item arrives back to you to issue payment. that's fine..
    https://www.tacomaworld.com/threads/tacoma-lifestyle-review.780921/page-5#post-28833502
    Paragraph 2 from my last reply in that thread cover's what I'd need to have this "fixed asap." Thank's. I'm actually really looking forward to being able to just shut up and go away.
    There was also a part in there about a different order that I have with you, that is weeks behind to ship, and I would like to cancel that order too so that I can go with a different vendor. (Before you ship it to me this time please, I REALLY do not feel like paying restocking fee's.)
  16. Jun 14, 2023 at 11:15 AM
    GunthorNC
    They made me right.
  17. Jun 14, 2023 at 11:17 AM
    McPickle
    McPickle IG: @ThatTopoTaco
    Dillon
    East Valley, AZ
    2019 TRD OR DCSB in MGM
    OBXPaul, MTBTACORN, rgljr831 and 3 others like this.
  18. Jun 14, 2023 at 11:56 AM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Sedona is an amazing place. I purposed there a couple of years ago. Cant wait to go back.
  19. Jun 14, 2023 at 12:14 PM
    TekITGuy
    Christopher
    Houston area
    I did. IPhone 11 Pro. No change. Made sure phone output paired to the truck of course. Nav is also hard to hear, like too low to be audible. On the flip side, music streaming works great, good volume range as well as with ordinary radio stations.
  20. Jun 14, 2023 at 12:26 PM
    wicked4xyota
    wicked4xyota Member
    2019 TRD OR DCLB
    IMG_8969.jpg Comin along. Just visualizing.
    BOMBS, soundman98, DuffyBank and 19 others like this.
