  1. Jun 17, 2023 at 10:59 AM
    bismarck
    bismarck Well-Known Member
    2023 TRD Off Road
    yeah.
    ever since i saw the youtube by project farm, i'd rather protect it by limiting a little air than introduce all that garbage into the engine.
    TartanEagle and rgljr831 like this.
  2. Jun 17, 2023 at 11:02 AM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    The GM Mechanic meant well, but clearly has limited knowledge. That said, I've read about the added charcoal filter too, but have never seen one. It's usually a "friend of a friend said" story for some reason.
    The K&N question always opens up a can of worms. I've used both oil treated (K&N, Spectre and others) as well as normal paper filters over the years (Wix ranks very high in most tests). Others may have different experiences, but the K&N didn't improve anything including performance for me on any vehicle, normal as well as cold air intake - although I've never tried one in our Taco. It did have a negative effect on the MAF sensor on two cars. Our Taco came with a Toyota TRD paper filter and it's working fine. Good performance with an average 18 -20 MPG (with an OTT tune).
    You basically already have a cold air intake. A quality paper filter, changed regularly, should be fine IMHO.
    Let the debate continue. :crapstorm::rofl:
  3. Jun 17, 2023 at 11:11 AM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    That's a great idea running the aux power from the FBC harness. I have the same harness. Did you need an additional pigtail? If not, which wire did you tap into?
  4. Jun 17, 2023 at 11:20 AM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Installed a set of Sumo Springs front bump stops. I found I needed to cut off some of the threaded rod on the Sumos to make install easier. I matched the length to the stock bump stops. For me, even lifting the tires off the ground, I needed some additional room as the Sumo bolts are so long. With the tires off, my ODC kicked in, I cleaned up the wheel wells and sprayed some Amsoil Mud Slinger to make cleaning easier after the next trail run. I could feel the difference on a text ride after install. Especially over potholes and the occasional speed bump.IMG_0920.jpgIMG_0921.jpg
    runmc, MTBTACORN, -Rorschach- and 8 others like this.
  5. Jun 17, 2023 at 11:24 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The pigtail Dave ships with is a GM weatherpack 2 pin. Intended to be used on the Baja designs S1 with meso HitchPod. There May be other options, I haven’t looked in a while. Not sure how yours is if you have the aux option. I have the ability to make my own Deutsch connectors, which is what the Rigids come terminated to. So I snipped off the weatherpack and spliced those two wires to 4 wires, and terminated a Deutsch on each set, at the proper length for each respective light. Wrapped in tape and loom, zip tied and plugged them in.
    I bought a manual switch but I may never use it. The use case for them hooked to the harness as is is perfect. I don’t really ever need the manual option, though it would be cool to have set up just because. But I’m lazy and I haven’t figured out my fuse and relay panel setup yet so I have no good way to execute it for now. Ultimately the Dave harness functions as needed so I’ve left it like that for now.
  6. Jun 17, 2023 at 2:50 PM
    Crow41
    Crow41 Well-Known Member
    Lehigh Valley PA
    correct
  7. Jun 17, 2023 at 4:06 PM
    birdkilla2k1
    birdkilla2k1 Active Member
    Stu Pedasso
    Maine
    2023 TRD Pro
    I finally brought it home…my journey started back in early February.
  8. Jun 17, 2023 at 4:15 PM
    Hansamzac
    Hansamzac Well-Known Member
    Central Ohio
    2022 Tacoma TRD OR Lunar Rock
    BakFlip M4 tonneau, debadged, LED interior lights, LED bed light, Rhino mud flaps, window tint, blacked out chrome bumper, Clazzios
  9. Jun 17, 2023 at 4:46 PM
    Stuck Sucks
    Stuck Sucks Aerodynamic styling with functional design
    Jim
    Pacific Plate
    Had all four shocks rebuilt. Plus, some other maintenance was necessary. Now, the truck is like riding on a BarcaLounger.
  10. Jun 17, 2023 at 4:57 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    Congrats! I wanted 10 months for mine; maybe things are getting better.
    rgljr831 and Out2gtcha like this.
  11. Jun 17, 2023 at 5:08 PM
    Tony382
    Tony382 Well-Known Member
    2022 Tacoma TRD Sport
    haha! I actually have though about going that route now. I have the S&B dry filter intake. It looks and sounds awesome around town. On the highway not so much.
    TRDRed[QUOTED] likes this.
  12. Jun 17, 2023 at 5:42 PM
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
    Spent the last few days wire wheeling and touching up my new to me Bruteforce fab rear bumper. Today I took the plunge and cut the bedsides up! This bumper is really nice. Need to loosen the bolts and readjust it tomorrow, will probably also reconfigure my leaf springs to accommodate for the extra weight.
    Also got spindle gussets and cam pocket reinforcement done from BuiltRight,(the truck shop sd) haven’t had a chance to pull the front wheels off to check them out yet. they look beefy as hell from underneath though
    dleriche, andthen, runmc and 9 others like this.
  13. Jun 17, 2023 at 5:49 PM
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
    Using this as motivation to move the tow hitch higher on my “must install” list
  14. Jun 17, 2023 at 6:12 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    theres tacos without a tow hitch?
    Kolache007 and rgljr831 like this.
  15. Jun 17, 2023 at 6:16 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    I think he’s referring to the hitch not the hitch receiver, although I could be wrong but I believe all tacos come with a hitch receiver. Again, I could be wrong, not sure about the base SR model :anonymous:
    Signatureinc likes this.
  16. Jun 17, 2023 at 6:20 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Actually the San Antonio plant only makes Tundras and Sequoias. Tacomas are made in Baja (DCSB) and Guanajuato (everything).
  17. Jun 17, 2023 at 6:27 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    They make more than just DCSBs there.......
    My DCLB is a Baja made truck.
    BC Hunter[QUOTED] likes this.
  18. Jun 17, 2023 at 6:30 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    I got half of the 60k maintenance done today.
    -oil/filter change
    -new front brakes/rotors
    -new intake air filter
    -rear differential fluid change…
    I’ll finish the rest this week
  19. Jun 17, 2023 at 6:47 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    at least 2 gallons left
  20. Jun 17, 2023 at 6:59 PM
    rgljr831
    Ron
    My ‘17 AC was assembled in San Antonio. My ‘21 DCSB was assembled in Baja.
    TartanEagle and RIX TUX like this.
