  1. Jun 24, 2023 at 1:52 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    What happened to the forum??
    Page 13098 and 13099 are mia.
    Mugsy7, drizzoh, musicisevil and 7 others like this.
  2. Jun 24, 2023 at 1:55 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I thought I got banned for a minute
  3. Jun 24, 2023 at 1:58 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    A disruption in the force....
  4. Jun 24, 2023 at 2:01 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I think it's a leap year thing or is it.....
    rgljr831 and thomasburk like this.
  5. Jun 24, 2023 at 2:28 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    :nuclear:
    rgljr831, thomasburk and 2Nice like this.
  6. Jun 24, 2023 at 2:56 PM
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    Kinda what I did but I split the USB ports so I could double my stored music. Found out after trial and error many "adaptors" don't work.
    shiftd, andthen, OBXPaul and 5 others like this.
  7. Jun 24, 2023 at 3:00 PM
    RetGoalie
    RetGoalie Well-Known Member
    Tom
    2023 DCSB Sport
    Undercover armor flex and OEM bed mat
    gr8-wrx, andthen, markram and 7 others like this.
  8. Jun 24, 2023 at 3:37 PM
    ekl0920
    ekl0920 Member
    Edwin
    23' OR MGM
    Do you have any more details on how to replace that light? Not sure where to start beside what looks like you removed the climate control pannel?
    TRDRed likes this.
  9. Jun 24, 2023 at 3:53 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Popped out radio trim bezel then the HVAC control panel below it. Both just pull out without tools or removing any bolts. Then you have to squeeze your hand in the gap until you find the bulb. It's one of those weird OEM style ones that matches no conventional bulb and twists 90 degrees counter clockwise to remove (I looked at the new bulb as a reference). Then just need to remove the plug by squeezing on the part you're supposed to squeeze on. Comes out pretty easy, much harder to fit your hand in to twist the new bulb in. They look exactly alike so pop on your parking lights real quick after putting the new one on to make sure it's blue. One of those installs that you have to do all by feel, but it's not too bad.
    markram, OBXPaul and TRDRed like this.
  10. Jun 24, 2023 at 3:53 PM
    HuskyTaco
    HuskyTaco Well-Known Member
    Z Precision large cup holder. Holds the big hydro flask and short fat yeti mugs. It’s only $50
  11. Jun 24, 2023 at 4:09 PM
    Built4TheHunt
    Built4TheHunt Bass Fishing and Bowhunting...
    Gavin
    Downstate Illinois
    16 QS DCSB TRD OFFROAD
    260k Brake system overhaul. I low key wanted to go with the Powerstop KC136 and stainless lines - but I opted for Import Direct Pads, Fully Coated Rotor and Reman Calipers. The brakes were super easy, in the process I also replaced the passenger side hub assembly because the studs were all jacked up. I also found the passenger side cv shaft had a torn boot so that was replaced. Both SPC upper ball joints have play - ordered new ones, doing some reading looks like the replacements are updated…I hope so. The one thing I would really like to get away from is ET Thread Spline Drive Lug Nuts…but that’s gonna require longer studs.
    Mhorst, Haymaker, andthen and 10 others like this.
  12. Jun 24, 2023 at 4:09 PM
    Taco22trdor
    Taco22trdor Well-Known Member
    East Tennessee
    2022 Tacoma TRD Off Road White
    TacoLarn, Shiro213, chuam and 15 others like this.
