  1. Jun 30, 2023 at 7:13 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I've always ran 91 octane so can't vouch for it being better because I don't use the others.
    These last posts are right, though. It's a truck. Didn't exactly purchase it for fuel economy.
    I travel a whole 10mi/day so a tank lasts me forever.
    The only reason I'm monitoring it now is, for 1 this site made me more conscious about it. and 2 I'm watching to see if changes I've made affect it.
    The "scoop" I'm referring to is the intake accelerator that sticks into your fender.
    RCrumb, OBXPaul, AwesomeLaw68 and 3 others like this.
  2. Jun 30, 2023 at 7:48 AM
    YatYas1833
    YatYas1833 Well-Known Member
    22 WHITE TRD OFFROAD 4x4 DCSB
    King 2.5’s with adjusters from accutune front and rear, 88 rotors rear add a leaf, Camburg X-joint UCA’s, Factory style trd pro 16” wheels with 0 offset, 285/75/16 KO2’s, pro grille, Front bumper viper cut, trd front skid plate, full RCI under skid plates, Cali raised trail sliders, exhaust cut dump, KDMax 10.0 tune
    Thank you sir!
  3. Jun 30, 2023 at 8:41 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    etsy has the steering wheel black out emblem for like 15.00 and don't forget the sticker for the glove box key hole
    Kolache007 and TRDRed like this.
  4. Jun 30, 2023 at 8:43 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    If somebody does something to their truck and they notice an increase or decrease of gas mileage they're getting, isn't that basically what they did to their truck today.? Isn't that the point of this thread?
    And because of the name of the thread, isn't this post off topic?
    :notsure:
    This is just an observation, nothing more.
  5. Jun 30, 2023 at 8:43 AM
    AwesomeLaw68
    Lawson
    Brand new.
    did you notice any difference cutting the scoop off? I installed a gutter rain guard to prevent chipmunks from crawling in my airbox.
  6. Jun 30, 2023 at 8:46 AM
    AwesomeLaw68
    Lawson
    Brand new.
    How do you reset your ecu, especially if i am not using a pedal commander?
  7. Jun 30, 2023 at 8:47 AM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Not sure about the Leer, but the BakFlip folds all the way up against the back window so you have access to the entire bed in a few seconds. Also like the look of the flush-mount.
    LeakyAC likes this.
  8. Jun 30, 2023 at 9:06 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    That is good thinking. Great awareness. Too many install them for "appearances" and not functionality. Keep them where you have them and don't hit any critters!
    Might have to change their name away from ditch lights though. :)
    rgljr831 likes this.
  9. Jun 30, 2023 at 9:32 AM
    AwesomeLaw68
    Lawson
    Brand new.
    Question,
    Im asking here as I searched the site and can't find the answer.
    So , Please explain in easy to understand terms. Thanks.
    If i want to change my wheel and tire size, and have Tire pressure monitors installed, How do i get the Tacoma to see the new tpm sensors working with the vehicle and what do i do with the old sensors so the vehicle stops seeing them? I am going to order a set of wheels and tires from Custom offsets. or tail built offroad.
  10. Jun 30, 2023 at 9:47 AM
    NachorTaco
    NachorTaco Well-Known Member
    Albuquerque
    2018 Silver Tacoma TRD OR
    Lomax bed cover
    Yeah the install was easy, straight forward, I did have a problem with the driver side back hood hinge bolt but finally got that in. If I didn't have to mess with that bolt it would have taken about an hour, that's including all the zip ties and replacing the switch in the cab. Just take out the front hinge bolt, put the bucket in place, hand tighten it, then take out the rear hinge bolt and slide it in to place then tighten everything up.
    TekITGuy[QUOTED] likes this.
  11. Jun 30, 2023 at 9:48 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    When you take your new setup to your shop for install, they will remove your existing TPMS sensors from your current setup and then move them to the new set. At least that is what Discount Tire did for mine. Not sure what everyone else is seeing.
  12. Jun 30, 2023 at 9:51 AM
    NachorTaco
    Albuquerque
    Lomax bed cover
    You are correct, They were point more forward when I took the picture, since then I have angled them more out to the sides, took awhile to get the angles right but looks and works like it's supposed to now.
    OBXPaul and TartanEagle[QUOTED] like this.
  13. Jun 30, 2023 at 9:56 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    It's the top pic in my post. DISCONNECT BOTH! battery terminals and hold them together for about 15min.
    I don't see many comments on resetting ecu. Everyone jumps into testing voltage and scanning 1st.
    When cable goes out 1st thing you do is reset the modem.
    When your phone/pc do an update it asks to do a restart.
    Whenever you call any tech support, 1st thing they ask, Did you restart your computer?
    Todays vehicles are no different.
  14. Jun 30, 2023 at 9:57 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    ^^^THIS
    OBXPaul and TRDRed like this.
  15. Jun 30, 2023 at 10:00 AM
    flakbait
    flakbait Well-Known Member
    2022 TRD OR DCSB 6MT
    35% Tint, OEM Floor Mats, Bed Lights, Door Sill Protectors, Bed Mat, A/c Drain Mod, Gas Cap Holder, LED Reverse Tail Lights, Pace Edwards Ultragroove Tonneau Cover, Yakima Crossbars, Black "Tacoma" Inserts, Black Emblems, Center Console and Glove Box Organizers, Paint Matched Bumper Caps, Chalk Bag Bottle Holder, OEM Bed Step, OEM Black Housing sr5 Taillights, Diode Dynamics Hitch Pod, Interior LEDs, Footwell Lighting, OEM Remote Tailgate Lock, VTAIL Taillights and Plenty More to Come!
    Installed some black and red sr5 taillights. Bye-bye chrome!
    Bagman, Pentangler, Khakiman and 20 others like this.
  16. Jun 30, 2023 at 10:08 AM
    TRDRed
    Me too! :thumbsup: Twinsees. :rofl:
    Have the black TRD 4x4 bed decals ready to install next.
  17. Jun 30, 2023 at 10:14 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Removing the intake accelerator, alone, didn't notice much change.
    I can't remember the formula but for every bend in a pipe you can add x-amount of feet in piping. example. 1 90deg bend is equivalent to having an extra 10ft of pipe.
    I'll be moving to my exhaust next. Try and open it up a little.
    Good flow in, Good flow out.
    The less restrictions the better
  18. Jun 30, 2023 at 10:35 AM
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '25 DCSB Sport
    NO MORE CHROME!
  19. Jun 30, 2023 at 10:38 AM
    AwesomeLaw68
    Lawson
    Brand new.
    WICKED COOL
    TRDRed likes this.
  20. Jun 30, 2023 at 10:41 AM
    AwesomeLaw68
    Lawson
    Brand new.
    In pool plumbing for every elbow in 1 1/2" pipe is equal to 10" of pipe due to cavitation, so less elbows makes the water flow well.....
    How can you make the truck sound louder without changing the whole exhaust out ? like giving it a little growl ?
