  1. Jun 30, 2023 at 3:01 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Had the BakFlip MX4 installed today. $1149 for the part plus tax, $49 to install it.
    pquintal, markram, RCrumb and 8 others like this.
  2. Jun 30, 2023 at 3:41 PM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Ventshades and LED bulbs.
  3. Jun 30, 2023 at 4:10 PM
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    My leer is 5 yrs old & folds up against back window. The new Leers are flush mount, mine wasn't & that was ok. I couldn't find anyplace local to provide or install the new 3 or 4 panel Leer. The new Leer uses no drain hoses, don't know if good or bad. Looking at the new BakFlip- the latches are plastic while the Leer are metal. I like the releases better on the Leer, the cable on BakFlip looks like you could fish a coat hanger between top of tailgate & cover & snag that cable & open it w/ tailgate locked. BackFlip is definitely lighter. Leer cover doesn't touch cab when opened against window, the BackFlip has rubber strips & is pushed agains't cab when using the prop rods. I'll be honest, I'm not crazy about that at all. I do like the BakFlip keeps the rails, don't know if the new Leer does or not. It didn't 5 yrs ago. It mounted to the rails. Just thinking out loud. A few weeks of use & we'll see if it passes muster. Or I'm missing something....LOL
    Pentangler likes this.
  4. Jun 30, 2023 at 4:14 PM
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    I see these around- what do they do?
  5. Jun 30, 2023 at 4:16 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Full AllDogs Hyperborean lift, RadFlo coils, HD leaf packs full res RadFlo rear shocks, UCAs, full camber/caster alignment, full CMC/pinch and some 5.29 R&Ps.
    Everything is way stiff atm, as I have not added the RCI sliders, armored SSO bumper, RCI rear bumper, nor the tounge weight of our off road trailer. Other than the tad stiff ride, the truck drives like a dream, and goes straight down the road no hands with no floating.
    SUPER happy!
    After the CMC And pinch, there is 0 rubbing, flexed lock to lock.... nice!
  6. Jun 30, 2023 at 4:19 PM
    Out2gtcha
    Brian
    Omaha, NE
    Thanks to Discount Tire for the 285/75/17 KM3s and 17" Method MR312s!
  7. Jun 30, 2023 at 4:51 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Good info on the Leer. :thumbsup: Even though it had some nice padding, I wasn't a big fan of the BakFlip touching the cab when it opened all the way up either. Our Tundra was white and it never left any marks, but it was a concern. Never noticed any water in the bed with the BakFlip but I don't know how much that could be contributed to the drain hoses. I had to lower the OE rails in the Tundra to install the BakFlip. Kind of a pain, but after all was said and done I liked how it looked and worked.
    I'll have to take a look at the newer Leer covers. Always open to improvements!
    EDIT: This one does look pretty nice. Spendy, but no more so than the competition. Based on some YT videos it looks like the Leer utilizes the existing bed rails to attach their rails but once installed you can still use the Tacoma's OE tie downs. Seems pretty nice. I liked the Leer cap I had on a 1st Gen Tundra I had. Good quality. Have to be on the lookout for discounts now! :rolleyes:
    OBXPaul likes this.
  8. Jun 30, 2023 at 5:38 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    With those cutouts I’d be concerned about water collecting inside the frame. Just sayin….of course I could be wrong and it wouldn’t be the first time. :anonymous:
  9. Jun 30, 2023 at 5:43 PM
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    Here's a side by side comparison of the 350 & 650.https://mytruckbedsolutions.com/blo...eer-hf350m-vs-hf650m-tonneau-cover-start-here 350 sits on top of bed & is 3 panels like BakFlip. The 650 is 4 panels & a flush fit like BakFlip. I see no advantage to 4 panels other than flush fit. I wouldn't spend the extra hundred. My 350 on the 2nd gen leaks very little but mostly at front of bed because top of bed is not flat all the way around like the 3rd gen. Mostly leaked running through carwash. I see both the new Leers are no longer aluminum panels. To get the BakFlip, I had to go to the guy who sold & installed my Leer, a 3 hr round trip. They are a Leer dealer but he says they have had several that cracked on the top trim on bed & no longer recommend them. Even their Leer display one cracked- inside & in air conditioning & never wet! Leer 3 yr warranty, BakFlip 5 yr warranty. I will say the 5 yr old Leer is a much more robust build. The BakFlip just feels cheap to me. I hope it holds up to daily use!
    They had a very robust roll up bed cover that was all metal on display that works with racks. It's very heavy & I did like that the cover locked into position every 12". But I'm already giving up a foot of bed over my 2nd gen & that box takes up valuable real estate. Then the price...... The cover alone was near 3k. I asked how many he's sold. None! LOL
    TRDRed[QUOTED] likes this.
  10. Jun 30, 2023 at 5:44 PM
    rgljr831
    Ron
    The installer can calibrate it for the new tire size. Additionally, unless you’re switching from alloys to steelies you don’t need new TPMS. :thumbsup:
  11. Jun 30, 2023 at 5:45 PM
    TRDRed
    Also good info. :thumbsup: Decisions, decisions. o_O
    Steves55[QUOTED] likes this.
  12. Jun 30, 2023 at 5:47 PM
    rgljr831
    Ron
    Welcome to TW! :cheers:
    Chrisindagump[QUOTED] likes this.
  13. Jun 30, 2023 at 5:55 PM
    beaverpelt
    beaverpelt Well-Known Member
    STL
    2023 Tacoma TRD OR
    Just installed the cartrimhome pro grille
    JT_RF, CarverLB, BC Hunter and 17 others like this.
  14. Jun 30, 2023 at 6:15 PM
    PentictonTacoma4
    PentictonTacoma4 Member
    BC Canada
    2023 TRD OR AC
    Just added the Westin HDX step bars. Fit great and easy install. IMG_4893.jpg
    photodoc, TacoTime55, RCrumb and 12 others like this.
  15. Jun 30, 2023 at 7:13 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    its like a game to play when you are driving :popcorn:
  16. Jun 30, 2023 at 7:21 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Mine shows "around" 340 miles to empty, after a fill typically. I get just under 20mpg around town, 21mpg highway.
    2021 Sport.
  17. Jun 30, 2023 at 7:24 PM
    VTCAL
    2021 Sport
    OMG! It's a truck forum! Anyone can talk about anything they like!1687717144335.png
    BC Hunter, Burns, Taco22trdor and 6 others like this.
  18. Jun 30, 2023 at 8:32 PM
    LOLsike
    LOLsike Well-Known Member
    Magnuson Supercharged, Yukon 5.29’s, 37’s, Elka Suspension
    DRT hanger cross brace install
  19. Jun 30, 2023 at 8:34 PM
    05 fish taco
    05 fish taco Member
    Joshua
    North Texas
    ‘16 6sp MT
    Icon coil overs in front, icon res shocks in rear with leaf. RCI bed rack with Thule rtt
    120,000 miles down and a fresh oil change today. The icon suspension is a hell of a ride, 10/10 would buy again. Had to do some light backroading today around the house. EXcited to see where my build goes. Definitely need a front bumper with a winch since most of the time I go on trails I’m by myself 2503050D-0878-4452-B4AC-86FCA8A29C64.jpgCB145E2B-B3EC-48AC-A8EE-D5BC642C2A8F.jpg 1568E30B-CC8A-4BB7-8A45-DBECB4C72E69.jpg
    2Nice, gabbo2112, kas2828 and 13 others like this.
  20. Jun 30, 2023 at 8:37 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    TRDRed likes this.
