  1. Jul 12, 2023 at 6:03 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    :eek:
    thomasburk[QUOTED] likes this.
  2. Jul 12, 2023 at 6:05 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Just pad swap is probably one of the easiest I’ve done. I didn’t bleed the brakes.
    Changing rotors is another level of complexity though.
    AwesomeLaw68[QUOTED] and RIX TUX like this.
  3. Jul 12, 2023 at 6:20 PM
    CaliAcadian
    CaliAcadian Well-Known Member
    Santa Cruz, CA
    2023 Tacoma TRD Pro MT
    the bed seal project continues. Today I...
    - Installed ESI trailgate seals
    - crawled under my truck and seals the openings near my tailgate that goes into my bed with aluminum foil tape. it probably isn't perfect but will surely help
    - Glued cubby hole covers on. Big thanks to @Buhlockaye for the file to print these out. They worked perfectly.
    Next I need to fill some small gaps between my tailgate and bed. Might use GE Advance Silicone II to plug those tomorrow.
  4. Jul 12, 2023 at 6:45 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    well it is daytime:anonymous:
    AwesomeLaw68, TRDRed and rgljr831 like this.
  5. Jul 12, 2023 at 7:21 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Uh yeah, does not compute...
    rgljr831[QUOTED] likes this.
  6. Jul 12, 2023 at 7:34 PM
    51Beets
    51Beets Well-Known Member
    2020 TRD Offroad
    Too much to list
    Damn! I've been wanting one of these too.
  7. Jul 12, 2023 at 7:42 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
  8. Jul 12, 2023 at 7:50 PM
    Thumper23
    Thumper23 New Member
    2018 TRD Sport
    That looks great! I dig that grill emblem too
    kochang[QUOTED] likes this.
  9. Jul 12, 2023 at 8:07 PM
    Dark_Taco
    2023 TRD Pro
    Stock
    Windows tinted. Probably my favorite accessory. Don’t like calling it a “Mod”.
  10. Jul 12, 2023 at 8:10 PM
    amitchr
    amitchr Well-Known Member
    2023 Tacoma TRD Off Road
    Installed DiamondBack Switchback cover
  11. Jul 12, 2023 at 9:13 PM
    JS11B
    JS11B Member
    '23 TRD OR
    VLEDS tucked inside them PRO Tails, both new
  12. Jul 12, 2023 at 9:56 PM
    wicked4xyota
    wicked4xyota Member
    2019 TRD OR DCLB
    Got an exhaust reroute done and wrapped it with exhaust heat wrap
    Ig @4x4slowcoma
  13. Jul 13, 2023 at 4:57 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    I heard that there are two cross members that get removed also, is this true?
  14. Jul 13, 2023 at 4:59 AM
    AwesomeLaw68
    Lawson
    Brand new.
    That looks cool, why did you re route your exhaust?
    Wrapping the exhaust pipe, does that serve any benefit from it?
  15. Jul 13, 2023 at 5:15 AM
    wcoffman
    No
    AwesomeLaw68[QUOTED] likes this.
  16. Jul 13, 2023 at 5:37 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    How did you spread calipers to get new pads in? Just pressure?
  17. Jul 13, 2023 at 6:14 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I use a c-clamp.
    Tnc, MGMDesertTaco, wcoffman and 6 others like this.
  18. Jul 13, 2023 at 6:51 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Excellent, I'll use my c-clamp as well when the time comes.
    wcoffman likes this.
  19. Jul 13, 2023 at 6:57 AM
    wicked4xyota
    wicked4xyota Member
    2019 TRD OR DCLB
    I rerouted it because thats the lowest point under the truck. I added a crawl box that I wanted to weld a plate to the cross member to mount the crawl box for support also similar to this. I only wrapped it so the heat from the exhaust doesnt affect the plastic on the transfer case actuator and the shifter cable.
  20. Jul 13, 2023 at 6:59 AM
    23TacoSR
    23TacoSR Well-Known Member
    If you're just doing a pad slap I hope your rotors aren't excessively mirrored.
    OBXPaul and TRDRed like this.
