  1. Jul 16, 2023 at 1:49 PM
    paulisinataco
    paulisinataco Well-Known Member
    Utah
    2022 sr access cab 4x4
    Put these steps on today
  2. Jul 16, 2023 at 1:55 PM
    thelostground
    thelostground Member
    East Bay, CA
    2021 DCLB OR
    Too many to list...
    Close, it's cement. Here's a wider shot.
    RCrumb, 4xThad, TacosMan and 6 others like this.
  3. Jul 16, 2023 at 2:09 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    20230716_140342.jpg Because of local forest fires most back country roads are closed, so gave my OR a coat of Chemical Guys Butter Wax
    markram, RCrumb, Glenny and 7 others like this.
  4. Jul 16, 2023 at 2:34 PM
    habaneroTrd
    habaneroTrd Well-Known Member
    2018 Tacoma Trd OR DCSB
    Installed these C4 fab sliders fresh from the powder coat , found them on marketplace for a price I couldn’t pass up. Super stoked with the way they look.
  5. Jul 16, 2023 at 2:42 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Where'd you order the flow accelerator from?
  6. Jul 16, 2023 at 2:42 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    isnt it easier just to convert those ancient scrolls into some sort of modern mp3?
    musicisevil likes this.
  7. Jul 16, 2023 at 2:52 PM
    k3ith99
    k3ith99 Well-Known Member
    2017 Tacoma TRD
    I just finished with the led interior and license plate upgrade. I did it because the dome light was burned out anyway. Tacoma led map lights.jpg Tacoma led map lights.2.jpg
    And then I read about the problems caused by led "upgrades." We shall see. . .
    markram, RCrumb, Glenny and 9 others like this.
  8. Jul 16, 2023 at 3:00 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    It's been more than a year since I changed mine to LED.
    I didn't disconnect the negative cable on the battery either. I used non-metal objects to disengage bulbs and tape to pull away bulbs that were tough to wedge out.
    fellow_expert likes this.
  9. Jul 16, 2023 at 3:01 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    If you put an s ton of wax on them they turn out super cherry
    OBXPaul and my.taco[QUOTED] like this.
  10. Jul 16, 2023 at 3:06 PM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    On my 2019 sport double cab, do I have to mess with the headliner in anyway, or will I be able plug and play? Thanks
  11. Jul 16, 2023 at 3:21 PM
    k3ith99
    2017 Tacoma TRD
    I didn't disconnect the negative cable either. All power was off when I removed and replaced the bulbs. I only had one vanity light led installed backwards, but I reversed it and everything works. License plate leds were kind of a pain to remove/replace, but those eventually went in. The only problem is that the dome light will not go off after the doors have been closed. But that was the problem even before I did the upgrade. I think it's been that way ever since I bought the car.
    OBXPaul and TacoTime55[QUOTED] like this.
  12. Jul 16, 2023 at 3:31 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    @k3ith99
    The dome lights should fade to dark once you step away with FOB...that's how my 2021 works.
    Earlier models I can't speak to.
    So, do you just turn off the dome light completely to prevent the battery from draining?
    OBXPaul likes this.
  13. Jul 16, 2023 at 3:37 PM
    k3ith99
    2017 Tacoma TRD
    I'll have to try the stepping away with the fob trick. Hopefully that works.
    I usually keep the map and dome lights off. If I need light at night I'll hit the map light. And then turn it off again before I leave the truck.
    OBXPaul likes this.
  14. Jul 16, 2023 at 4:22 PM
    my.taco
    my.taco Well-Known Member
    2023 TRD OffRoad, Lights, skid plate & Side bars.
    This is one of the few things i changed on mine too, 2 days in. I also changed the front headlight low & high beams to LED & also changed the turn signal bulbs to led, then i bought the LED sequential Mirror lights.
  15. Jul 16, 2023 at 4:28 PM
    batmanis243
    batmanis243 Member
    Nc
    2022 red trd sport
    For the most part great my dad been going to them for years now the only issue I had was when I went for a oil change they broken one of the clips off the hubcap but they replace it. I had issues with the dealer in Raleigh would never do Business with them again.
    OBXPaul likes this.
  16. Jul 16, 2023 at 4:29 PM
    delz05
    delz05 Well-Known Member
    Just completed the bed lights, Spiker Engineering Hood struts, matte black overlays, gloss black TRD repro 17" wheels with Falken 265/70/17 AT3's, gloss black wheel lugs... all added to my new 2023 Wind Chill Pearl White Limited.
    TRD Pro grille and Hellwig rear sway bar next in line, as time allows...
  17. Jul 16, 2023 at 4:39 PM
    thelostground
    East Bay, CA
    2021 DCLB OR
    Too many to list...
    I shopped around a bit and landed on toyotapartsdeal.com
    bkhlrTaco's[QUOTED] likes this.
  18. Jul 16, 2023 at 4:56 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    What problems? Or, where did you read about it?
  19. Jul 16, 2023 at 5:03 PM
    k3ith99
    2017 Tacoma TRD
    Funny, I'm thinking of doing that too. I'll wait a bit and see how this goes first.
  20. Jul 16, 2023 at 5:08 PM
    k3ith99
    2017 Tacoma TRD
