  1. Jul 18, 2023 at 1:09 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Wondering the same now. I tried it a number of times but was only treated to the light show. Will be getting our new Venza back from the dealer today (they're trying to figure out why the infotainment system keeps freezing/shutting down), so maybe I'll ask one of the service folks.
    OBXPaul likes this.
  2. Jul 18, 2023 at 1:37 PM
    JS11B
    JS11B Member
    '23 TRD OR
    After reading your post, I tried it 3 times & works as indicated. Not sure where the hell I read 4 times, which also works. Forgive my newness haha
  3. Jul 18, 2023 at 1:51 PM
    TRDRed
    Yep, tried it fast, slow and in-between. Just get the series of 7 light flashes and then nothing. The only "chirps" are the normal lock sounds though.
  4. Jul 18, 2023 at 2:05 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Mail call today:
    -5100's front and back
    -KYB top hats
    Doing a no-lift suspension upgrade / refresh soon
    Awaiting some oem Toyota LCA and UCA bushings + new hardware bits
    Even though it's an access cab and I'm not lifting it, I'm debating if it's worth doing the ECGS bushing if I'm gunna have the entire front end apart?
  5. Jul 18, 2023 at 2:59 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    I did it on my 2.7 AC with 5100's set at .65 a few weeks ago i figured i already had it apart why not would rather not have an issue in the future. I also put a small bead of weld on the lca tabs to hopefully prevent them from bending. With the no lift option on the bilsteins i doubt you will have an issue. I normally see the issue with 1.5'' and up in the front it was just cheap assurance for me.
    OBXPaul and LeakyAC[QUOTED] like this.
  6. Jul 18, 2023 at 3:11 PM
    LeakyAC
    My truck has 110k on the odo.. i'm wondering if I could do more harm than good by doing the ECGS swap in case the diff opening and flange area are kind of rusty or otherwise not pristine? With vehicles I've learned that "if it aint broke dont fix it" usually works out best. But should the needle bearing wear out I'll be doing most of this work twice over..... decisions! lol
  7. Jul 18, 2023 at 3:30 PM
    TRD_Seeds
    TRD_Seeds Well-Known Member
    York, PA
    2019 Cement Tacoma TRD OR
    Very nice! Love seeing homemade setups. I did something similar so I'm able to throw my bike on top of the stock tonneau.
    markram, RCrumb, tvterry and 5 others like this.
  8. Jul 18, 2023 at 4:03 PM
    Nyrob
    Robert
    2021 SX 2.7 AT 4WD
    Agree i usually have the same mindset, but i also hate doing things twice. My truck only has 22k on it and i will say its amazing how much tighter the bushing is on the axle vs the bearing i pulled out. I was toying with it on the bench once i got the bearing out, i would consider mine almost new at that mileage and there was a significant amount of play vs the bushing. its a pretty simple install i picked up the removal and installation tool wound up selling them here in the marketplace after, hardest part was prying the axle out.
  9. Jul 18, 2023 at 4:06 PM
    Talon2006
    Talon2006 Well-Known Member Vendor
    Did a little skid plate install today.
  10. Jul 18, 2023 at 4:59 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I got the 20 OR too, I heard that my remote start would expire in one year, sooo, I installed the remote X, was about $100 and easy install, and I can continue to remotely start.
    I think it was really sneaky of Toyota to expire that feature within one year, I wonder if this is mentioned in the owners manual?
    OBXPaul and TRDRed[QUOTED] like this.
  11. Jul 18, 2023 at 5:02 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Service guys don't like you. They're obviously taunting you.
  12. Jul 18, 2023 at 5:30 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    I press my lock button three times (slowly) then hold (light show then it starts). Works every time.
    Edit: Once the light show starts, keep the button depressed until it starts.
    Scotfree, OBXPaul and TRDRed like this.
  13. Jul 18, 2023 at 5:36 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    I went through the remote start with the dealer. They say due to complaints, you can start car with your key fob for 10 yrs before you pay. I had all the app shit removed from my truck. Press the lock button 3 times rapidly, not waiting for beeps or lights, again, not waiting- when you press & hold the 4th time, hold it until it starts. Only works from 100 ft or less & probably not through walls & obstacles. Also- there's no indication on your fob your car is started & running. Useless IMO.
    thomasburk, OBXPaul and musicisevil like this.
  14. Jul 18, 2023 at 5:39 PM
    rgljr831
    Ron
    Refer to the owner’s manual. Connected services only apply to the app……
    MrMobile likes this.
  15. Jul 18, 2023 at 5:39 PM
    my.taco
    my.taco Well-Known Member
    2023 TRD OffRoad, Lights, skid plate & Side bars.
    Now THIS is a nice sexy skit plate install!! DAMN !!!! its like ART !!
  16. Jul 18, 2023 at 5:47 PM
    Evilsplashy
    Evilsplashy Member
    Virginia
    2023 Lunar Rock TRD OR DCSB
    Today I installed the world famous LED lights in the interior. All I have to say is WOW. Completely changed the interior.
    Qbrute, markram, RCrumb and 16 others like this.
  17. Jul 18, 2023 at 6:07 PM
    LeakyAC
    Btw did you run a spacer or AAL in the back with the fronts set at .65? Or just oem leafs and the 5100s?
    OBXPaul likes this.
  18. Jul 18, 2023 at 6:07 PM
    LeakyAC
    Wow that's actually a huge difference! Super clean
    OBXPaul and Evilsplashy[QUOTED] like this.
  19. Jul 18, 2023 at 6:21 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Installed the Morimoto third brake light. What a pain in the ass. To make it worse the hyper flash module I paid extra for shipped separately. Figured that out halfway through installing.
    before
    After
  20. Jul 18, 2023 at 6:32 PM
    Concrete_taco
    Concrete_taco Well-Known Member
    CA
    2020 TRD Off Road
    Same on my 2020
