  1. Jul 23, 2023 at 7:39 PM
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    Expedition Essentials 3TPAM with SPOD, Go Pro, GMRS and phone.
  2. Jul 23, 2023 at 7:41 PM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    Doubt Shane ever bought nor lease one.
    luckbox91[QUOTED] likes this.
  3. Jul 23, 2023 at 7:58 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    I’m gonna ask a really dumb question. I can research this elsewhere, but here’s a good a place as any.
    What’s with the air compressors people are putting under the hood? What function do they serve?
    Blast away
  4. Jul 23, 2023 at 8:00 PM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    I still want to hear from someone who has one of these pumps. No decision yet.
    TacoGeeloor[QUOTED] likes this.
  5. Jul 23, 2023 at 8:03 PM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    It you press them (and sometimes massage them in) they will stick to the headliner.
    rgljr831, OBXPaul, TRDRed and 7 others like this.
  6. Jul 23, 2023 at 8:05 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Air locking diffs
    Tire inflation
    OBXPaul and Kbar[QUOTED] like this.
  7. Jul 23, 2023 at 8:06 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Pulled my blown motor out, and got the junkyard one loosely bolted in. Probably finish the rest later in the week, and hopefully be driving it next weekend
  8. Jul 23, 2023 at 8:08 PM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Lots of folks air down their tires for off roading, it helps to provide a smoother ride on rough trails, helps with added traction and less likely hood of a puncture.
    Once you’ve aired down for a trail, you have to air back up for the road to avoid a dangerous situation with underinflated tires at highway speeds.
    Air compressors, like the ARB units you’ll typically see, are a faster, more reliable way to air back up (compared to a standard cigarette lighter plug in air compressor).
    My pregnant wifey airing up…because it’s so easy and fast with a good setup.
    Some also use it for air lockers, air tools and air suspension, amongst other things.
    rgljr831, Haymaker, markram and 13 others like this.
  9. Jul 23, 2023 at 8:11 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    some are wired already and some are not
    Out2gtcha[QUOTED] likes this.
  10. Jul 23, 2023 at 8:12 PM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    Put on the last of the armour today. Had some help with the bumper and then installed the lights afterwards. Just waiting on a harness for the light bar and then it will all work!
    Also, I just spliced the fog lights into the stock wiring. No power source, no fuse. Just two wires for each of the fog lights and I just combined them and "shoved" them into the stock wiring that is for the stock dog harness. Maybe they could be brighter? Seem blinding to me :)
  11. Jul 23, 2023 at 8:13 PM
    RIX TUX
    open door or switch
    OBXPaul and TRDRed like this.
  12. Jul 23, 2023 at 8:23 PM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    Kevin are you gonna use the mini ex to pull the motor?
  13. Jul 23, 2023 at 8:28 PM
    RIX TUX
    right on man
  14. Jul 23, 2023 at 8:36 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    Wow. I expected to see some snow up that high still with the winter we had. I hope to do Webster some day, but your experience is reminding me to do it with friends. I'm under the impression it's tougher than Imogene.
    Time to hunt down a thread of good Colorado trails; time to explore some more (safely).
    Glad that you and your truck are out safely.
  15. Jul 23, 2023 at 8:38 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Nada, was classy and used a forklift haha. I have used the mini to pull all the motors in the past though :rofl:
    OBXPaul and E.T. like this.
  16. Jul 23, 2023 at 8:55 PM
    Miles009
    Miles009 Well-Known Member
    Miles
    2019 TRD sport
    OME 887 w/ AAL
    Mine was integrated tailgate lock. Morning after signing a 31k loan for the truck I come out to a hobo using my tailgate as a bench to shoot up. Seattle for ya
    RIX TUX likes this.
  17. Jul 23, 2023 at 8:55 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Bangbangs, pointy stabbies, tacos AND cats? Did we just become best friends!?
    What’s in the leather slip pouch?
    TheFactor[QUOTED] likes this.
  18. Jul 23, 2023 at 9:17 PM
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    lol Yes :D
    It’s a modern traditional Slipjoint by LionSteel
    Made in Italy designed after the Barlow pattern. M390 blade steel and it’s a great slicer definitely a handy every day carry. I actually collect knives so I really enjoy them.
    Here’s a beautiful fixed blade made by Bark River called a Bravo 1 with Crosscut Mammoth and Mosaic pins.
  19. Jul 23, 2023 at 9:29 PM
    TheFactor
    So Cal
    I’ve learned pictures can be very deceiving and I bet getting that truck out of there without rolling it was much more challenging then it appears. I’m sure that angle is a lot more steep than the picture dictates.
  20. Jul 23, 2023 at 9:34 PM
    musicisevil
    Alaska
    2019 TRD Sport
    Oof. That bug bit me too…
    That lionsteel is slick and I’m a sucker for mammoth fixies. That BRK is gorgeous!
    I have a lil fat Busse in mammoth tooth. The local stabbery put some blue mammoth ivory on one of their house blades and redid the inlays on my sebenza with something similar. Same place also does insane ano work. They collaborate with an artist to make stuff like that titanium scaled bug out.
    No safe queens! Use ‘em or lose em!
    In an attempt to keep it vaguely truck related here’s my ghetto diy molle mount for my truck knife while I wait for a rigid panel to come back into existence:
