  1. Aug 5, 2023 at 1:37 PM
    billmc
    billmc Member
    Bill
    PDX
    2022 Tacoma SR 6 cyl 4x4 access cab
    Truxedo tonneau cover, N-Fad nerf bars, mud guards, custom made bed rug,rain guards and LED interior lights..
    IMG_0170.jpg Fixed up the inside of my topper..Everything can be removed in a couple of minutes..ATTACH=full]5503922[/ATTACH]
  2. Aug 5, 2023 at 2:02 PM
    MGMDesertTaco
    Usually there's an adjustment that can be made on the shifter linkage or the hydraulic fluid in the system (brake fluid) needs to be changed or bleed. Most likely an adjustment with the linkage in this instance.
  3. Aug 5, 2023 at 2:16 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    And I thought my 8500 mile '20 was low miles. Maybe it has something to do with steel wheels and manual transmission?
    VTCAL, spin180 and TRDRed like this.
  4. Aug 5, 2023 at 2:28 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    That's it! :thumbsup:
    Since the CDT tweeters are standard 4 ohm, I'd think the DS18s (also 4 ohm) should work fine with a JBL system. Couldn't hurt to try and they could always be returned I guess.
  5. Aug 5, 2023 at 2:31 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Like the side shelf on the right, smart use of space.
  6. Aug 5, 2023 at 3:21 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    When you add the short shifter your loosing leverage to get the shorter throws, so it takes more manly biceps. Reverse is particular difficult.
    This is my fix. It sounds silly, but once you get down the rhythm it goes pretty smoothly.
    You slap that bitch into reverse.
    Currently you are just grabbing the shift ball and trying to muscle it into place. Next time, slap it into reverse. This way you get the momentum of the slap. It will just drop into reverse. It takes a few days for it be natural motion.
    My wife had no problem learning the procedure.
  7. Aug 5, 2023 at 3:22 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    No, I have a 2020 with almost 4200 miles with an auto and TE37’s.
    Cement_wheels[QUOTED] likes this.
  8. Aug 5, 2023 at 3:25 PM
    Dagstacoma
    Dagstacoma Member
    2020 Tacoma TRD Off-Road
    i appreciate the help! I just came back from resolving the issue. I had accidentally left out a black ring (rubber and gasket-like) that layers underneath the blue ring near the middle section of the shaft. Now it’s not nearly impossible to put into reverse.
  9. Aug 5, 2023 at 3:32 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    That would make it more difficult.
  10. Aug 5, 2023 at 4:01 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    I did the last thing I could do to prepare for 35's. Trimmed my front fenders and installed the C4 fender liners. Took about 5 hours in the Phoenix morning heat. Anyone in Phx have some 35's I could borrow for a day? I need to see if my truck will still fit in my garage with them on, ha.
  11. Aug 5, 2023 at 4:15 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Boy does that salt do a number on the steel underneath!
    Abominator, rgljr831 and LeakyAC like this.
  12. Aug 5, 2023 at 4:17 PM
    wcoffman
    Ok, I’m confused. We’re talking about the transmission here, right?
    BC Hunter likes this.
  13. Aug 5, 2023 at 4:38 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    You are correct!
    wcoffman[QUOTED] likes this.
  14. Aug 5, 2023 at 5:07 PM
    my.taco
    my.taco Well-Known Member
    2023 TRD OffRoad, Lights, skid plate & Side bars.
    I want to do ALL the speakers in my truck. I hate the fact that when i open any of the front doors all i see is the bright YELLOW surrounds on the drivers !! WTF, whats wrong with black or dark surrounds. WHY yellow ! lol
  15. Aug 5, 2023 at 5:13 PM
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    [​IMG] Got the TRD Skid plate installed and it was a fun install and love the look and the Extra protection. Very easy install with a floor Jack and used a torque wrench to get everything to spec.
    Just a quick picture :thumbsup:
  16. Aug 5, 2023 at 5:15 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Right, and that's with regular washes in the winter.
    Ahh. It'll buff out. :D
    rgljr831 likes this.
  17. Aug 5, 2023 at 5:15 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Did she have lots of practice?
    Oh ha that would do it.
    :D
  18. Aug 5, 2023 at 5:31 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    I say stop the rustbefore it gets any worse
    2k2, rgljr831 and bkhlrTaco's[QUOTED] like this.
  19. Aug 5, 2023 at 5:40 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Jumped on the bandwagon and did the DS18 install.
  20. Aug 5, 2023 at 5:46 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's a tacoma thing, you just can't understand.
    seriously. the f150, silverado, and ranger never had them.
    really though, i'm happy they're offered, as i love the additional tiedown points. though juries out on the actual stiffening functionality.
