  1. Aug 5, 2023 at 5:58 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I also ordered a set. Will be delivered tomorrow.
  2. Aug 5, 2023 at 6:26 PM
    Mudtoy90
    Mudtoy90 Member
    James
    Calgary, Alberta
    2022 SR5 Magnetic Grey Metallic
    CLD LED headlight conversion Katzkins leather seats OEM TRD Pro grille Leer 100 XR canopy A/C drain line extension OEM LED fog lights OEM Tailgate Keyless lock Dobinsons 3” front lift w/extended travel shocks, Dobinsons 2” rear lift with long travel shocks and full leaf pack and u-bolt flip Diff drop/needle bearing switch out to clamshell bushing/axle shims 17” black Trailite rims 275/70R17 Wildpeak AT3’s Compustar 2 way remote starter Caliraised LED interior lights RokBlokz Corrosion Free rust proofing spray (DIY) Future planned: Sherpa roof rack and topper rack Leer topper Keyless entry Greenlane aluminum stump bumper OK Expedition aluminum full skid plate Greenlane hybrid aluminum sliders Winch Bushwhacker fender flares
    ‘tis the day for bed stiffener installs.
    Installed the stainless steel ones I bought from Greenlane today.
  3. Aug 5, 2023 at 6:30 PM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    Just got back from deployment. Over the last few days I done
    Yokohama Geolander G006 315/75r16
    Dirt King UCA
    Warfab Tie rod sleeves
    Warfab Phantom with tire swingout
    C4 Fender liners
    RCI Transmission skid.
    CMC
    Still need to put the 5.29 Nitros in, rock lights, find a welder to gusset my spindles and a tune.
    6B32BE33-5DCD-4DF4-A108-8EF325E68EDC.jpg 46536521-EF90-4DA7-83C7-03E836AB195B.jpg
  4. Aug 5, 2023 at 6:53 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    What did you have prior? I did the kicker swap. Wondering if these are better?
  5. Aug 5, 2023 at 7:00 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Just the stock tweeters.
  6. Aug 5, 2023 at 7:10 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Not if you apply a protective coat. I have been using mavcoat 1-2 times a year depending on how much snow/salt/brine we get. I'm sure upstate NY, NH, Mass., Michigan, etc. Get it worse with the brine.
    If you keep in top of it you can avoid most of the rust. My truck has almost none underneath.
    habaneroTrd, rgljr831 and LeakyAC like this.
  7. Aug 5, 2023 at 7:33 PM
    robin303
    robin303 Well-Known Member
    Robin
    Houston Tx
    21 TRD Sport
    Xero[QUOTED] likes this.
  8. Aug 5, 2023 at 7:34 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Mine lives outdoors in the rust belt too...rust proofing is a way of life up here lol
    OBXPaul likes this.
  9. Aug 5, 2023 at 7:36 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    c,mon man get out of the basement and see the sunshine
    do you get flat spots on the tires?
  10. Aug 5, 2023 at 8:16 PM
    Built4TheHunt
    Built4TheHunt Bass Fishing and Bowhunting...
    Gavin
    Downstate Illinois
    16 QS DCSB TRD OFFROAD
    Easy day. Topper Tent takes 10 mins to install.
    markram, 17taconut, MTBTACORN and 9 others like this.
  11. Aug 5, 2023 at 8:17 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Changed the oil at 35k miles. Noticed that the last time I had the dealership service the truck at 30k they left the rear bolts in the engine skid loose. Once the warranty is up, I won’t be having Toyota service my truck anymore. Leaving 2 bolts loose makes me wonder what else they leave done improperly.
    markram, Kbar, thomasburk and 4 others like this.
  12. Aug 5, 2023 at 8:19 PM
    SnowWhite23
    SnowWhite23 Well-Known Member
    2023 Tacoma TRD Sport
    Hell no, oil filter or drain plug properly loose too. Can’t trust anyone these days. And why not just do it yourself?
    burnttaco7, Kbar, D.A.S. Taco and 2 others like this.
  13. Aug 5, 2023 at 8:41 PM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    Exactly! I normally do all my own servicing but with the warranty I wanted to have the minimum services done at Toyota to maintain the warranty. Maybe I should double check all their work.
    Side note, took a sample to send off to Blackstone to see how the engine is doing. Anxious to see what the results are.
    Kbar and OBXPaul like this.
  14. Aug 5, 2023 at 8:50 PM
    SnowWhite23
    I allways denied the warranty and do everything my self. That away u kno it’s done correctly.
  15. Aug 5, 2023 at 8:57 PM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    With just over 93k miles on the clock my Taco took its first ever trip out of Florida. Now she’s treked North Carolina, South Carolina, Georgia and Florida. Today she took my 9 year old and I up a steep unpaved mountain road to the top of Currahee Mountain. It was a blast
  16. Aug 5, 2023 at 9:00 PM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    That’s probably not a bad idea. I have lifted the truck so they’d probably attribute any issues to that anyway.
  17. Aug 5, 2023 at 9:24 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    Nope, no flat spots. I park on a lift...
    rgljr831 and 2k2 like this.
  18. Aug 5, 2023 at 10:40 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
  19. Aug 5, 2023 at 11:54 PM
    TacomaWorld2023
    TacomaWorld2023 Well-Known Member
    I did the same. We probably watched the same Classy video lol
    OBXPaul and ClassyTacos like this.
  20. Aug 6, 2023 at 2:46 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    It's been blazing hot lately down here too.
    Looks real good. Be prepared to hammer up the top of wheel well where it folds and hammer back the area above the CMR. These are the common areas where I was rubbing when I ran 35s. 2lbs and 8lbs sledges did the trick.
    kas2828, MTBTACORN, rgljr831 and 3 others like this.
