  1. Aug 17, 2023 at 12:01 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Uh oh.................
    Got a box with the all-too infamous KTJO drivers side grab handle.
    We'll see what I roll with this crap shoot. Ive seen peeps get perfect installs out of these things that look perfect as well. Then, there are the guys who have blemishes colored in w/marker from the factory, & fiber hairs sticking out of them, on top of not fitting correctly, but it seems the only game in town.
    Ill post what I rolled........
    markram, BJK1280, OBXPaul and 6 others like this.
  2. Aug 17, 2023 at 12:13 PM
    OldSaltyDog
    OldSaltyDog Well-Known Member
    Hampton Roads VA.
    2022 DCSB Limited Nightshade Edition in Magnetic Grey
    None to speak of, just enjoying it for the moment.
    Just ordered one for myself as well good luck I hope I get a good kit!
    markram and Out2gtcha[QUOTED] like this.
  3. Aug 17, 2023 at 12:14 PM
    Out2gtcha
    Brian
    Omaha, NE
    Same, same!
    Im hoping I got a good one too..........
  4. Aug 17, 2023 at 1:01 PM
    Okkine 2.0
    Okkine 2.0 Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    Actually, that's a pretty good idea!
    TRDRed likes this.
  5. Aug 17, 2023 at 1:51 PM
    [TACOMA]
    [TACOMA] Well-Known Member
    SoCal
    '17 DCLB Sport in QS
    TRDRed likes this.
  6. Aug 17, 2023 at 1:59 PM
    OscarWildwood
    OscarWildwood Well-Known Member
    Jay
    2023 Ice Cap Tacoma SR5 DCSB
    Looks great! Were your dash and door panels already black or did you have to change that as well?
    Edit: ah now that I have better lighting I see it’s probably just the stock grey
  7. Aug 17, 2023 at 2:54 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    It honestly depends on your wheel offset. I've had minor scrub radius rubbing on the driver's side front bumper when there is a passenger or 2 in the truck with me.
    My wheels are -25mm offset though... So depending on your wheel offset you could encounter minor points of contact.
  8. Aug 17, 2023 at 3:25 PM
    Nadjr
    Nadjr Well-Known Member
    2021 Army Green TRD Offroad
    That's true, I picked Method wheels with 0 offset just like stock so they would fit
  9. Aug 17, 2023 at 4:19 PM
    tjv504
    tjv504 Taco n00b
    Tom
    NOLA
    2023 Tacoma TRD Sport Lunar Rock
    Pro Grille, TRD skid, Spidertrax 1.25" spacers, Cali Raised cat shields, Seat Jackers, 67Designs Taco Rail, WeatherTech floor mats + bug deflector + side window vent shields, demon (nipple) rings, Hitchhiker's Guide to the Galaxy reference on the tailgate, Tyger tri-fold tonneau cover
    Picking my Taco up next week. What were the stock tires it came on? Debating swapping them immediately depending on what they are...
  10. Aug 17, 2023 at 4:21 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Depending on which wheels your truck came with, stock is up to +30
    BC Hunter and Tacospike like this.
  11. Aug 17, 2023 at 4:26 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I got that rail when I first got my truck in 2018 thinking that toyota never should of removed it... 5 years later I have used it like 3 times.
  12. Aug 17, 2023 at 4:27 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    It depends on the trim (so does the wheel style and size). The TRD OR comes with Goodyear Wrangler Territory ATs on 16" wheels.
    scouterjan, Taco22trdor and BC Hunter like this.
  13. Aug 17, 2023 at 4:28 PM
    Okkine 2.0
    It's been driving me crazy that the rear window button, which gets used every time I enter or exit the vehicle, is in the most inaccessible location behind the shifter, while the BSM & wireless charger button, which will literally never be pressed, are in the most accessible slots.
    Today I decided to swap them around.
    Took a little longer than expected, since Toyota put grooves in the switch to prevent them from being moved (I don't understand what they have against this), so those had to be shaved off, but it was otherwise pretty straightforward.
    I was concerned that it wouldn't work without the little bevel they put into the factory slot, but there's still plenty of room for the button to be depressed.
    The wire is a little tighter than I would like, so I'm going to look around for an extension for the wiring harness. I don't really want to splice wires while it's still under warranty.
    While I had my hands in there, I also took the opportunity to unplug the light in the wireless charger cubby (aka the really expensive pen & spare change holder), since this cab is way too bright as it is.
    I was going to move the USB port over towards the cigarette lighter, but apparently they used a different sized slot for that.
    andthen, Brehm14A, RCrumb and 11 others like this.
  14. Aug 17, 2023 at 4:28 PM
    tjv504
    tjv504 Taco n00b
    Tom
    NOLA
    Mine's the TRD Sport 2WD (17"). Hoping for AT anything tbh
  15. Aug 17, 2023 at 4:31 PM
    Tacospike
    Two Trucks
    An extension for the window switch? I know of a place for harnesses. I did it with my tundra.
  16. Aug 17, 2023 at 4:40 PM
    Okkine 2.0
    Actually, I really like that. Unfortunately, I don't think there's room down there with the manual transmission. Up top, beside the button for the sunroof would be good, too.
  17. Aug 17, 2023 at 4:48 PM
    Tacospike
    Two Trucks
    Here is the harness.
    https://accessorides.com/products/r...ra-2010-2017-plug-play?variant=32416113524782
    I doubt the connection would be any different from the tundra but not 100%. Could email and ask? link a couple together for a desired location
    OBXPaul and TRDRed like this.
  18. Aug 17, 2023 at 4:57 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    musicisevil likes this.
  19. Aug 17, 2023 at 5:03 PM
    Tacospike
    Two Trucks
  20. Aug 17, 2023 at 5:08 PM
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    I did but for some reason only saw the 8” and 44”
    Tacospike[QUOTED] likes this.
