  1. Sep 27, 2023 at 8:31 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Most tires with the snowflake symbol indicating ok for snow use are good. You don't have to run dedicated winter tires in snow and ice. I've been using all weather (NOT all season) for around 10 years. They work well and can be run all year. I'm in Alberta Canada with snow 6-7 months and Rocky Mountains. Currently have General Grabber ATX.
    Kbar, OBXPaul, Cement_wheels and 3 others like this.
  2. Sep 27, 2023 at 8:34 AM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    There are a few YouTube videos on how to replace the screen. I believe Chloe Kuo has a video on her YouTube site. Doesn't look to complicated.
  3. Sep 27, 2023 at 8:34 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @17taconut tires are a product of compromise. The Nokian is designed for snow and ice but not specifically for off road. However like most tires light off road would be doable. Most forum members have there snow change overs and A/T tires for summer.
  4. Sep 27, 2023 at 8:39 AM
    17taconut
    Dave
    Baltimore, MD
    I realize it's always going to be a compromise in the long run. I'm currently on the East coast and trying to see what my best "compromise" would be when I need new shoes.
    Kbar, OBXPaul, MrMobile and 1 other person like this.
  5. Sep 27, 2023 at 8:54 AM
    hopwheels
    hopwheels Well-Known Member
    Gary
    2021 Cement Tacoma TRD Off Road
    Just gettin’ started
    Pretty easy actually. The trim pieces just snap off, the gauge cluster is held in by 4, 8mm bolts, and the lens piece fastens to the gauges with 8 screws. There are two wiring harness connectors and a harness clip to remove to allow you to remove the whole assembly and swap the lens elsewhere. The hardest part was applying the screen protector.
    Part no. 83852-04F00
    I ordered from here: https://www.discountpartsmonster.co...tA9oGLCzxX_KwTtqgJ4bX6TCzp5APLCoaAtYvEALw_wcB
    And used this YT video (no affiliation): https://youtu.be/_JYykw4cPSg?si=FtmkQBxfZuEuTULJ
    Hope that helps! Well worth the minimal effort.
  6. Sep 27, 2023 at 8:55 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    And it was good!
    OBXPaul and RIX TUX like this.
  7. Sep 27, 2023 at 9:10 AM
    LeakyAC
    A dedicated winter pavement tire.
    AT and MT tires are horrid on frozen pavement and black ice
  8. Sep 27, 2023 at 9:16 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    In Ontario, we get a slight insurance discount if you swap to winter tires.
  9. Sep 27, 2023 at 9:20 AM
    LeakyAC
    1/10
    musicisevil likes this.
  10. Sep 27, 2023 at 9:28 AM
    Athena32
    Athena32 Systems Engineer
    Nate
    Colorado
    2021 Tacoma Super White DCSB OR 6MT
    I run studded Hakka’s in the winter in CO. They go on at the first snowstorm and come off at the last snowstorm. If you were to run these year-round on pavement and dirt, they wouldn’t last more than 6 months at most. These tires are exceptionally soft because they need to remain flexible at low temperatures to keep grip on ice—remember that these tires were built for Nordic winters. If you subject them to high temperatures and rough terrain, the tread will melt and shear.
    With that out of the way, if you can run these in winter, nothing will stop you. I can traverse mountain passes with confidence so long as the snow doesn’t get higher than the bumper. The 4WD system of the Taco, coupled with some weight in the bed, and proper winter tires make the truck a force to be reckoned with in wintery conditions.
    OBXPaul, LeakyAC, BC Hunter and 9 others like this.
  11. Sep 27, 2023 at 11:39 AM
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
    Probably not the correct area to post so I apologize Tacoma fam…but does anyone have a link or product for a backseat dog divider?
    like what the K9 cops use?
  12. Sep 27, 2023 at 12:02 PM
    Dutch216
    Dutch216 Well-Known Member
    Dutch
    Cleveland Ohio
    2023 Tacoma TRD OffRoad Premium
    Without starting a new thread. Ill put what I want to do to my Tacoma right now. Ive searched and weirdly not found anything. So I know it is here I just dont know the right search words. What I want to do is add a "Roll bar/Sport Bar/Light bar" not sure what to call it.. but it is a bar that attaches to my truckbed and I put lights on top. so I have the OEM stock tri fold metal bed cover and I want that to stay. Id like something like this. sportbar.png
    I got on with support. They said Id have to cut it a little. Would be good to see a thread with this.
    But here is the bigger thing. How do I run electrical to it? Is there a thread to that? I installed a redarc trailer switch so I can probably do that with a light bar switch. How do you run the power to this light? Always wanted a truck with a lightbar.. and Ill get it damn it. :)
    TekITGuy and OBXPaul like this.
  13. Sep 27, 2023 at 12:16 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    That’s good advice
    BC Hunter, corgimas and musicisevil like this.
  14. Sep 27, 2023 at 12:31 PM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Started the lift process with 5100s in the back. Took off the Sumo springs for now. Truck rides so much better.
    I could literally put all of my weight on the breaker bar when I took the lug nuts off. Thank you, Toyota dealer. Took all off and put back on with correct torque amount. 1 last free oil change left at the dealer. Will be doing it myself from that point on.
    2Nice, OBXPaul, spin180 and 2 others like this.
  15. Sep 27, 2023 at 2:53 PM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
  16. Sep 27, 2023 at 2:54 PM
    D-knoww
    D-knoww D-Know
    Washington state
    I had to replace the stock fender decal with one less noisy.
    Kbar, TRDRed, corgimas and 1 other person like this.
  17. Sep 27, 2023 at 2:55 PM
    D-knoww
    D-knoww D-Know
    Washington state
    I guess I should have put one with the origanal TRD 4x4 sport decal also, huh?
    Kbar, TRDRed and Taco22trdor like this.
  18. Sep 27, 2023 at 2:57 PM
    D-knoww
    D-knoww D-Know
    Washington state
    markram, Kbar, Scotfree and 7 others like this.
  19. Sep 27, 2023 at 3:25 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    Although primarily a male audience exists in this forum, we do have females here that can mod their trucks as well or better than most of us (certainly me). And they have some pretty cool ideas I'd never think of if they didn't share.
    Not a mod, not a prude, not offended, not afraid to poke fun, and not going to go all PC. Just raising awareness that if we up the respect a notch we might get to see more ideas big and small.
    Tacorific, The Mink, Kbar and 16 others like this.
  20. Sep 27, 2023 at 3:30 PM
    canuck guy
    Alberta
    23TRDOR
    Totally agree. I'm no prude but vulgarness and gutter talk has no place here.
    Kbar, 17taconut, Nomad26 and 3 others like this.
