  1. Oct 2, 2023 at 5:38 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Checked the lug torque on the new Methods after a 800 miles. Wanted to check it sooner but I had to make an urgent run to Longview hospital yesterday. The whole way there and back, I was kicking myself for not checking them earlier. They all clicked fine at 85 fp so no worries.
  2. Oct 2, 2023 at 5:41 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    I find that as long as you are dealing with good shape (non-corroded and/or rusty) parts that as long as you properly torque in the star pattern as well as one more time around they never loosen up
    OBXPaul and Kbar[QUOTED] like this.
  3. Oct 2, 2023 at 5:54 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    IMG_7553.jpgPulled the oem pan today bc stripped drain bolt and replaced it with all new plugs and gasket from dealer IMG_7554.jpgIMG_7555.jpg IMG_7556.jpgIMG_7557.jpg sprayed pan bolts down with wd 40. Cleaned the magnets and filter everything looked pretty good.. hand started each pan bolt then torqued them in star pattern to 9ft lbs. pinned the thermostat shifted through the gears and let it warm up to temp check mode then filled 3.9qts after check plug finished draining with Amsoil ATF image.jpg
    Drove until it got up to operating temp crawled under to check for gasket leaks and plug leaks. Everything looks perfectly normal
  4. Oct 2, 2023 at 6:02 PM
    CLVol1255
    Tennessee
    2017 TRD Sport DCSB
    IMG_7533.jpgDid a coolant flush and fill over the weekend twice IMG_7536.jpgburped system and filled it with Toyota super long life antifreeze/coolant image.jpg
  5. Oct 2, 2023 at 6:51 PM
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    Well I got this for my taco and guess you can say for me to :D
    Picked up an impact driver and some accessories for future mods. Wished I would have had one when I installed my TRD Skid plate although a simple job it would have been even easier. I’ll probably use it for the K&N intake for the 3 screws holding the air box in place :rofl:
    Anyway I’m sure it will come in handy in the future :thumbsup:
    spin180, vivid02, burnttaco7 and 11 others like this.
  6. Oct 2, 2023 at 6:57 PM
    skyitalia5
    skyitalia5 Well-Known Member
    Joe
    Seymour, CT
    2017 TRD Sport DCLB BBP
    TRD Pro Skid Plate TRD Pro Grille TRD Pro 17" SEMA Wheels Kicker Tweeter, Front/Rear Door Speakers
    Hi all, looking to upgrade my USB port to USB-C. Are there any threads on this already?
  7. Oct 2, 2023 at 7:02 PM
    Kbar
    Western WA
    22 OR
    Did you buy Amazon brand drill bits?:rofl: :boink:
    Jk. A friend of mine got that same kit and likes it. Lemme know how they hold up
    TheFactor likes this.
  8. Oct 2, 2023 at 7:27 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I hope you renewed the filter..........
    RIX TUX likes this.
  9. Oct 2, 2023 at 7:47 PM
    TheFactor
    So Cal
    :rofl::rofl:
    You know I actually did by mistake thinking they were deWalt lol Those late night purchases will get you every time :annoyed:
    It actually looks pretty good though and has a lot of other sockets and other goodies to. They do look well made but we shall see :thumbsup:
    The DeWalt accessory kit does look like better quality no doubt.
  10. Oct 2, 2023 at 7:54 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    is there one in your console?
  11. Oct 2, 2023 at 8:11 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    I’m pretty sure you can swap the one that is in the center console with USB A connections for this one with USB C but I understand that it gains you nothing in respects to higher wattage output.
    I just installed this in my center console instead: https://a.co/d/9fyTBbT
    spin180, vivid02, skyitalia5 and 3 others like this.
  12. Oct 2, 2023 at 8:30 PM
    Sslanina
    Sslanina Member
    Tucson, Az
    Lockable, airtight storage box mounted in my longbed. This still allows for good visibility when driving and a usable bed area. Easy to access from the windoors on my leer camper. IMG_2975.jpg
  13. Oct 2, 2023 at 8:37 PM
    MGMDesertTaco
    skyitalia5[QUOTED] likes this.
  14. Oct 2, 2023 at 8:53 PM
    CaptSourPatch
    CaptSourPatch Well-Known Member
    PNW
    2023 Lunar Rock TRD OR
    Stock. For now.
    You haven’t done the pinch welds in the fender?
  15. Oct 2, 2023 at 9:21 PM
    RIX TUX
    mine has a usb-c in console
    from the manual:
    The USB charging ports are used to supply 2.5 A (Type A) and 3.0 A (Type C) of electricity at 5 V to external devices
    skyitalia5, 3GTCMLMTD and TRDRed like this.
  16. Oct 2, 2023 at 9:24 PM
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    So between 12.5 watts and 15 watts. The one I just installed has 2 USB-C’s capable of 30 watts and a USB-A capable of 18 watts.
    skyitalia5 and OBXPaul like this.
  17. Oct 2, 2023 at 9:29 PM
    RIX TUX
    yep 2016 technology, i use a cig plug that puts out 27 w, the one in the console is good as a back up or good if you are driving 3+ hours
  18. Oct 2, 2023 at 9:46 PM
    jv91
    jv91 Active Member
    What box is this?
  19. Oct 2, 2023 at 9:49 PM
    WaitingOnMyR1T
    Josh
    Portland, Oregon
    OBXPaul and jv91[QUOTED] like this.
  20. Oct 2, 2023 at 10:02 PM
    burzpaw
    burzpaw Well-Known Member
    Zuriel
    '22 Lunar Rock TRD Off Road 4x4
    Oh yea, that was done along with the CMC by @Shmellmopwho :D
