  1. Oct 13, 2023 at 8:47 AM
    hoytshooter1
    hoytshooter1 Well-Known Member
    Cave Creek, AZ
    2020 DCSB
    ICON's Method's w/265-70-17 (Gone) '16SR5 Wheels with 255-85-16 Falken MT's AZ pinstriping
    If your going to do the emblems, need black lugs too.....
  2. Oct 13, 2023 at 8:57 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    If you checked when it was hot, it should be filled to the Hot Max line.
    spin180, OBXPaul, Taco22trdor and 3 others like this.
  3. Oct 13, 2023 at 8:59 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Which kit did you get?
    OBXPaul and oostroma like this.
  4. Oct 13, 2023 at 9:38 AM
    TacoWa2022
    TacoWa2022 Member
    Renton, WA
    23 DCLB OR
    Yes, please tell us more about this.
  5. Oct 13, 2023 at 10:06 AM
    hopwheels
    hopwheels Well-Known Member
    Gary
    2021 Cement Tacoma TRD Off Road
    Just gettin’ started
    10-minute cab side rail install turned to 90 minutes to extract another stuck screw. At least it came out. Going to save all the ones I extract and mail them to Toyota for Christmas :)
    spin180, OBXPaul, andthen and 10 others like this.
  6. Oct 13, 2023 at 10:37 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    experimental designs released a product last month that lets you use the locker at anytime not just in 4 low. 2hi with locked diff and traction control off (it turns traction control off automatically when engaged) is some of most fun you can have. slides perfectly on them fast fire roads and no more embarrassing one wheel peels
    https://experimentalinc.com/products/anytime-locker
  7. Oct 13, 2023 at 10:46 AM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Agreed. Bought a set of OE Toyota black chrome lug nuts here:
    https://www.ebay.com/itm/174906398065
    Came in sealed Toyota packaging. Much less expensive than from the dealership.
    17taconut, spin180, andthen and 7 others like this.
  8. Oct 13, 2023 at 10:56 AM
    TRDRed
    Agreed that's low and needs to be topped off. Question is, on a sealed system, why is it low? Worth having a look at everything to see if there's a leak. Could be a very slow leak so probably not dripping, but there would be evidence - at various connections, spray on other parts or frame, etc. Might be a good time to diagnose/fix anything and flush. Unless it's under warranty there's nothing special about the system so to save a pile of money I'd avoid the dealership and use a reputable repair shop (they can get OE parts), but that's just me. ;)
    Let us know how it goes!
    spin180, OBXPaul, Taco22trdor and 2 others like this.
  9. Oct 13, 2023 at 1:21 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Awesome. Was wondering if it was this kit. Looks great except I wish it was full pnp without having to splice the 19 pin. They made a harness for the passenger side, they should have for the driver as well. I'll probably be getting it anyway though once the MK3 stops taking all my available funds.
    OBXPaul likes this.
  10. Oct 13, 2023 at 1:43 PM
    Dozer14
    Dozer14 Active Member
    Central Florida
    Thanks, thats a good way to look at it. Like most taco owners we plan on keeping it forever or close to forever.
    You make a good point about the rain. I am in FL so; we get a ton of rain at times. I will talk to the tuner and check out the different tunes to see what fits best.
    Thanks for everyone's replies. This site is very knowledgeable, active and informative. Along with, a bank account drain.....LOL
  11. Oct 13, 2023 at 2:02 PM
    ITmaD
    ITmaD Well-Known Member
    Atlanta
    Just finished up installing a set of side molle panels from Cali Raised. So much room to mount shit now!
    Note: For people with Gator FX3 Tonneau Cover Part #: GHF-6610426 like myself that lowers the factory rail 2 inches their Bakflip version is compatible with the Gator cause it's pretty much the same design and mounts.
    The section of text under here is for hopefully better search optimization for people with the same question for search engines so that it hopefully brings them here since that information at other sources I found wasn't very direct.
    Do you have a Bakflip bed cover that lowers factory rail 2 inches? Gator Bakflip CaliRaised CaliRaisedled
    YES
    runmc, Yota_MGM, spin180 and 11 others like this.
  12. Oct 13, 2023 at 2:02 PM
    devinzz1
    devin
    2023 aclb trd or mt
    meh its just a single wire t splice. having to add another pnp t harness for a single wire probably would have raised cost quite a bit. full install only took about 30 minutes.
    OBXPaul likes this.
  13. Oct 13, 2023 at 2:24 PM
    MonkeyChief
    MonkeyChief Detachable member
    ACORLR
    WTB Topper Lunar Rock 6’ Leer
    Debadged
    StallinNBallin, Kbar, 2k2 and 23 others like this.
  14. Oct 13, 2023 at 2:35 PM
    EGBTER
    EGBTER Well-Known Member
    Wayne
    Denver CO
    2016 TRD SPORT
    Hit the trail:
    2k2, andthen, hopwheels and 9 others like this.
  15. Oct 13, 2023 at 3:50 PM
    texpnw22
    texpnw22 Active Member
    Texas
    2023 Black Tacoma SR
    AC drain mod. No idea how some of y'all were able to pull the heater hose completely over the old one. I'll check on it every few days.
    spin180, OBXPaul, -Rorschach- and 7 others like this.
  16. Oct 13, 2023 at 4:13 PM
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    Woolwax'd as much as I could before I over heated my aging air compressor.
    Used fluid film previously...
    The ww is definitely thicker, and takes more to cover well, hopefully it will last coated longer than ff
    Sadly, it doesn't smell like a fire roasted sheep while driving down the street
  17. Oct 13, 2023 at 4:24 PM
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    no I not in contact with a turner, but I would like to get a tune if it helps that much. Live in Ocala Fl
    OBXPaul and TRDRed like this.
  18. Oct 13, 2023 at 4:42 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    More info on this? Similar to the gray wire mod on the Gen 1?
  19. Oct 13, 2023 at 5:15 PM
    devinzz1
    devin
    2023 aclb trd or mt
    see previous post. different than previous gens. separate control module is needed.
    rgljr831 likes this.
  20. Oct 13, 2023 at 6:27 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Finished coating and installed bed stiffeners
