  1. Oct 17, 2023 at 1:24 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I’m waiting for my stock 70s to wear out so I can put on 75s. :thumbsup: At the price of tires, I can wait.
  2. Oct 17, 2023 at 1:44 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    I couldn’t wait. But I got the spare et al mounted for a grand. $200/ea installed with road hazard seemed good enough of a deal.
    I’ve seen the wildpeak drop to $150 each on Amazon. Not sure how much it’d be for the install
    anyways just mean keep an eye out, never know what you’ll find
  3. Oct 17, 2023 at 2:28 PM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost, Diode Dynamics SS3 Ditch Lights, Prinsu Pro Roof Rack with Heretic 6 series 40 inch light bar
    Congrats on the Smartcap. I recently got mine and promptly got into an accident and had to remove it to fix the truck. Now that it's back on, I had to deal with water leakage. Is it coming from the cap itself or from under the bed cover or the gap between the side panel and the back panel? If from the cap, check the torque of the bolts. Should be 3.7 ft/lbs. I needed to go slightly higher to stop it where it was leaking from. If you put too much torque on it, you risk the chance of stripping the threaded part from fastener block.
    If the water is coming from the gap between the truck bed panels, if you remove the cap you can slide in some rubber gasket material to fill it, or if don't want to remove the cap, use black silicone to fill that gap. I used the silicone.
    I also had water leakage coming from the sliding window. For that one, the window wasn't closed completely. It looked like it was but it wasn't locked all the way. The water traveled along the window seam to the little half moon cutout where it dripped down from there. The window just needed to be closed properly.
    So far its passed the water hose test where I hosed it down for 15 minutes with no water leakage. I'll need a good rain storm to know for sure.
    A big problem with the Tacoma is that there are a lot of holes under that composite bed rail cover. I had the body shop cover the top of the bed rail with an aluminum foil tape (there are posts in TW from others that have done that). It will also help with dust. That said, the tape only stops any splash that is coming from under the truck. Water can still come through by just sliding between the bed rail and the composite cover. If ever a reason to remove the cap and those rail covers, I'll lay down some kind of silicone barrier between them.
    Hope this helps
  4. Oct 17, 2023 at 2:47 PM
    chinoxmk22
    chinoxmk22 Well-Known Member
    Mario
    2023 Tacoma
    where did you buy your new one?
    ensaladas[QUOTED] likes this.
  5. Oct 17, 2023 at 3:02 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
  6. Oct 17, 2023 at 3:11 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    No pics to offer, but others have put up the same stuff, before.
    Installed a pair of ThinSkinz covers on the rear doors, to protect them from the pups. I had tried fabric ones that came with a couple of seat protector hammocks that I bought, but they never stayed in place, once the dogs started bouncing around (3 Pekinese). These covers have a very satisfying click when they seat in place, and I feel confident that they will be a good long term solution to the problem. Once in place, the door levers are still accessible, and the window switches are protected by sprung flaps over them, that will keep the dogs from hitting them, but still allow access for passengers, when you have them.
    https://thinskinz.com/products/thinskinz-tacoma
    I also installed the Cartrim Drivers window control module so that I now have auto up and down windows all the way around. The switch came with a plastic pry bar for removing the armrest bezel. Very easy conversion, remove bezel, unplug two connectors, unscrew three screws holding the module to the bezel. Reassembly is the reverse, with the new switch module. About 10 minutes, including testing the new switch. The toughest part was convincing the connector to come off the back of the original module. I'll repeat the warnings from others that the rear doors DO NOT have all the pressure sensitive safeties of the front doors, so this may not be for everyone, but after discovering that the Thinskinz cover the rear window switches, I'm comfortable with that, now.
    https://cartrimhome.com/All-Auto-Up...acoma-2016?search=toyota tacoma window switch
    spin180, RCrumb, Taco22trdor and 5 others like this.
  7. Oct 17, 2023 at 3:29 PM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    From a local dealer. Along with these bad boys. :bananadance:
    spin180, hopwheels, Shayne and 12 others like this.
  8. Oct 17, 2023 at 3:32 PM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Looks great! Would love to see some more angles if you have them.
  9. Oct 17, 2023 at 4:56 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Nope. That's about it. Wildpeaks were $200 each so I decided not to get them again at that price. I really thought hard on the rubitrek but they were about $160 each which was still a little high for me. I have a feeling I'm going to regret not getting these.
    I wound up getting some GT Radial Adventuro ATX tires for less than $500 it was a good price and they "seem" like they will be a good SL tire with good on road mannerisms... Hopefully they do as well as the wildpeak.... Although I doubt they will measure up.
    rgljr831 and embedded rock like this.
  10. Oct 17, 2023 at 7:25 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    SUPER excited about these SUPERBUMPSTOPS……
    Going on this weekend and testing them out at Hollister Hills :D
    spin180, Shayne, 17taconut and 6 others like this.
  11. Oct 17, 2023 at 7:57 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    $100 OEM or $20 copy?
    TRDRed likes this.
  12. Oct 17, 2023 at 8:04 PM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    hang in there. I'm a cancer survivor myself.
  13. Oct 17, 2023 at 8:26 PM
    Athena32
    Athena32 Systems Engineer
    Nate
    Colorado
    2021 Tacoma Super White DCSB OR 6MT
    Parts have started to arrive for the winter light upgrade. OEM LED headlights coming on Thursday, awaiting a BAMF light bar to ship, and I have a harness being built that'll allow the SS5 lights to be controlled manually via a switch or automatically via the high beam stalk.
    Kbar, TRDRed, 3GTCMLMTD and 4 others like this.
  14. Oct 17, 2023 at 8:32 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Swapped the wife’s BFG K02 tires on TRD OR 16” rims for some Nokia Nordman 7 tires on TRD 17” Sport rims. All are 265 width and 32” OD, so should be identical drivers.
    Hoping for a better winter on hard-packed snow in the mountains. The BFGs were acceptable brand new (September) last year but thinking we need her on real winters this year.
    Will update as weather happens.
    spin180, Kbar, TRDRed and 3 others like this.
  15. Oct 17, 2023 at 11:28 PM
    TRD_Goodson
    TRD_Goodson Goody
    Eureka, Missouri
    2019 Tacoma DCSB
    Long Travel 3rd Gen
    Mirror Images Inc. in Wilmington NC. Applied a ceramic coat, debadged and underbody cleaned. #NoRust
    spin180, TRDRed and OBXPaul like this.
  16. Oct 18, 2023 at 1:50 AM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    Thank you very much!! :hattip::cheers:
  17. Oct 18, 2023 at 3:00 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I got a pair of heated seats in just in time for the trip to Destination Offroad. Comfy, much lighter, less bulky so more space, loving the side bolsters and they match.
  18. Oct 18, 2023 at 3:46 AM
    Antogreg
    Antogreg Member
    Long boiiiiiiiii looks great with the cap
    rotorblade[QUOTED] likes this.
  19. Oct 18, 2023 at 3:56 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Jacking Points of contact,
    S out of the blue i had to jack up my truck yesterday due t a flat tire and wanted some advice, i used a cross-memeber under the front of the truck close to the drivers side of the vehicle, can anyone give me advice as to where a jack should go for the front of the truck as I had to change a front tire due to a unusually, large bolt i found stuck in the tire.
    i had side steps on s i can't use the oem jack, where do i put the floor jack or oem jack in the front end?
    rgljr831 and 23 SR5 LB like this.
  20. Oct 18, 2023 at 4:07 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Nice !! That's going to be a great trip, that is a beautiful area this time of year. How long will you be in those trails? Looking forward to some pics afterwards.
    OBXPaul likes this.
