  1. Oct 28, 2023 at 9:15 PM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    Below zero all day here, so no work on the truck, but used the Taco to bring home construction debris from our new office.
    While loading, I noticed that Tacos are fairly popular here.
    3GTCMLMTD, OBXPaul, Irons and 4 others like this.
  2. Oct 28, 2023 at 9:46 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Finally took her onto the freeway today after deleting the sway bar yesterday. Body roll is negligible on the freeway as well. Once I receive and install the extended front brake lines I will test it off road. Will report back with findings. :mudding:
    spin180, gabbo2112, 3GTCMLMTD and 4 others like this.
  3. Oct 29, 2023 at 4:31 AM
    Magneto Burrito
    Magneto Burrito Active Member
    Wes
    2016 SILVER DBL CAB TRD OFF ROAD
    Huskys, Clazzios, AVS, RCI 18' Adjustable Bed Rack, RCI Tonneau Cover Adapters, Softopper, OEM Bed Mat,
    New Ko2's just in time for winter weather in Colorado
  4. Oct 29, 2023 at 5:44 AM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Bet it goes in and out of 4HI much easier.
    3GTCMLMTD, rgljr831 and OBXPaul like this.
  5. Oct 29, 2023 at 5:57 AM
    Dorf510
    Dorf510 Well-Known Member
    Tyler
    Vista, CA
    18 TRD 4x4
    Dayton wires, flux-capacitor, port-a-potty
    Installed a brand used Pelfreybilt bumper, and changed the BD bezels and mounts to fit the square foglight holes. have to get the front valence wrapped(i retained my OEM white bumper, seller had a spare valence), Winch inbound.IMG_2709.HEIC.jpg
    9mmMike, 2Nice, spin180 and 13 others like this.
  6. Oct 29, 2023 at 7:38 AM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    Just thought a frosty taco would be a good breakfast post for the forum...
    71tattooguy, E.T., 23 SR5 LB and 20 others like this.
  7. Oct 29, 2023 at 7:57 AM
    MarkusJ
    MarkusJ Well-Known Member
    Mark
    2024 Sport 4x4 Premium package- Underground
    Just got it
    Any pictures of the cable run and zip tie locations? I’m doing this next week. Thanks!
  8. Oct 29, 2023 at 8:00 AM
    McHale
    McHale Well-Known Member
    2023 Toyota Tacoma TRD OR MGM Access Cab
    I don't but it's pretty much self-explanatory when you get under there. As soon as you drop the cable through the frame, you're going to bring it to the passenger side and zip tie it to the existing cables there. You're literally following an already established run. You can't miss it.
  9. Oct 29, 2023 at 8:02 AM
    MarkusJ
    Mark
    Just got it
    Thanks, I watched a few YouTube videos on it, shouldn’t be that bad. Any other things I should know before install?
    McHale[QUOTED] likes this.
  10. Oct 29, 2023 at 8:07 AM
    Vjustinc
    Vjustinc Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    Ooohh! Might wanna keep this in my back pocket for next year! How did you do it? Just make a hole underneath?
  11. Oct 29, 2023 at 8:08 AM
    McHale
    The instructions call for some 3M frame treatment (I forget the specific name of it) that you put into this clip you attach to your frame. I didn't have any and didn't want to wait so filled it with silicone and sprayed it with cosmoline. No idea if that will make any difference but you should figure out what you're going to do with that. I'm betting many people didn't use anything.
    Once you take the tailgate apart and give it a good look over, you'll see how it works. Probably the most complicated thing was installing the two 2 hole clips that go in the bottom of the tailgate and the underside of the bed.
    Mine didn't come with instructions. I just pulled them up on my cell phone and kept it handy for when I plugged in in the passenger side footwell.
    Seriously, the entire install is really easy. Now that I've done one I could probably do it in less than 30 minutes without breaking a sweat or looking at instructions.
  12. Oct 29, 2023 at 8:40 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Just did this. Worked out GREAT.
    Shout out to @Shiftin2Sixth for meeting me in San Diego and selling me the Meso volume fix. I added the AJT Design steering wheel sides. I trimmed the rubber near the volume up led and then some..... turned out 98% perfect. I cut off the rest of the rubber led covers just because.
    It lites up just fine in the dark,I really don't look at it anyway when driving...
    Unhooked the battery for 15mins beforehand.
    Changing out the parts and chopping the rubber took a total of 15min.
    I used a T-30 Torx, small flat blade screw driver and a Phillips screw driver.
    Questions or comments welcome.
    Pscdouglas, E.T., RCrumb and 16 others like this.
  13. Oct 29, 2023 at 8:44 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    What was the purpose of trimming the rubber?
    rgljr831 likes this.
  14. Oct 29, 2023 at 8:50 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    It provided more illumination to the volume up portion of the button. so it doesnt look like this.
  15. Oct 29, 2023 at 9:03 AM
    McHale
    Those radio knobs...
  16. Oct 29, 2023 at 9:09 AM
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    Maddog-51[QUOTED] and Jerry311SD like this.
  17. Oct 29, 2023 at 9:13 AM
    rgljr831
    Ron
    @wh11 were you able to remove the extractor?
  18. Oct 29, 2023 at 9:52 AM
    McHale
    Behold, the non-OEM skid plate. Kind of a PITA to install, I swear I'm like one turn away from snapping the heads off the bolts, but it's on. Until I have to change the front diff fluid, it ain't going anywhere.
    spin180, 3GTCMLMTD, andthen and 6 others like this.
  19. Oct 29, 2023 at 10:19 AM
    McHale
    Here's the thread I created on the Rough Country with a handful of pics. Great company and support but the new rails killed it for me.
    https://www.tacomaworld.com/threads/rough-country-low-profile-12-hour-shelf-life.815924/
    3GTCMLMTD and TRDRed like this.
  20. Oct 29, 2023 at 10:33 AM
    MadJacks
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    Forgot I recently installed the Form Lighting tailights. Love the start-up sequence and I love that I can activate the sequence anytime. Don't love that I can't see them when driving :facepalm:
    spin180, 3GTCMLMTD, andthen and 10 others like this.
