  1. Nov 22, 2023 at 9:36 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    Way back in 2022 we had to do it. This is from the 2022 Tacoma Owner's Manual. Probably printed on papyrus, but I use the pdf version.
  2. Nov 22, 2023 at 9:37 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    breaking in and bed in is not the same thing
    OBXPaul likes this.
  3. Nov 22, 2023 at 9:43 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    I guess I meant break in by the owner manual recommendation.
    OBXPaul, MrMobile and RIX TUX[QUOTED] like this.
  4. Nov 22, 2023 at 9:44 PM
    RIX TUX
    Going back a few decades, cylinder liners underwent a single-stage honing process that left a crosshatch pattern on the surface of cylinders or cylinder liners. Sharp, jagged edges created by the newly honed surfaces then needed to be removed or smoothed to provide an optimum seal between the piston compression rings and cylinders.
    This was best achieved with lower quality, usually mineral-based, engine oil allowing the piston rings to bed in against the cylinder, thus creating a tight seal. This bedding in process, basically “controlled wear of engine components,” included a gradual increase in load and revs on the engine over a period of running hours and miles. This was essential to deliver a good seal and cylinder compression and limit engine oil consumption. The engine oil would be replaced with a higher quality semi or fully synthetic oil with friction modifiers designed to lower friction and reduce further wear.
    It is much different now since manufacturers introduced a final stage honing process. Referred to as a plateau hone, this finishing process simulates most of an engine run-in by removing the sharp, uneven ridges created by the primary honing process. It guarantees an almost perfect seal from the outset or at least very close. It also enables manufacturers to use high-quality synthetic oils from the factory without the need for running-in oil. Therefore, any final running in should be completed promptly and not over 1000+ miles, with a risk of bore glazing resulting in reduced power loss and potential excessive oil consumption
  5. Nov 22, 2023 at 10:54 PM
    mtbkman
    mtbkman 2020 TRD Sport
    Metro Detroit
    2020 Trd Sport MT
    None yet
    Hey, What are those side rails on the bed?
    OBXPaul and rgljr831 like this.
  6. Nov 23, 2023 at 5:19 AM
    CarverLB
    CarverLB Who Dat?!
    Bryan
    Long Beach, Mississippi
    2021 Trd Sport 4x4
    Drove it up to the north Georgia hills.
  7. Nov 23, 2023 at 6:31 AM
    Scotfree
    2021 sr 4x4 2.7
    The 7th gen Camry se is pretty rugged.. love that car
  8. Nov 23, 2023 at 6:44 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    I look those tires up in a 285/70/17 and they were $188 per tire. Still a good price but a little bit above $65.
  9. Nov 23, 2023 at 9:43 AM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost, Diode Dynamics SS3 Ditch Lights, Prinsu Pro Roof Rack with Heretic 6 series 40 inch light bar
    I got some new gas for the gas tank today. Not quite sure where the old gas went.
  10. Nov 23, 2023 at 10:00 AM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    :rofl::rofl::rofl:
  11. Nov 23, 2023 at 10:08 AM
    OBXPaul
    OBXPaul Just do what you say you're going to do!
    Paul
    Kill Devil Hills, NC (Outer Banks)
    2016 Black Tacoma Limited, 1983 Blue Deluxe Pickup
    1983 restoration in progress, major mods so far new 6" lift and 35" Mickey Thompsons.
    Happy Thanksgiving to everyone!!
  12. Nov 23, 2023 at 10:15 AM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Thanks! Happy Thanksgiving TW!
  13. Nov 23, 2023 at 10:16 AM
    iLLFadedBowl
    iLLFadedBowl Well-Known Member
    2019 Super White TRD Offroad Tacoma
    Remote start w/ vehicle control and locator, Prinsu rack w/ Cali Raised Light Bar and 360 LED lights, LED Bedlights, Tailgate lock, 3" Lift, Wheels and Tires, Raptor Lights, LED headlights and fog lights, Blacked out LED taillights, Front windshield eyebrow tint, Rough country bed molle, 8-gang switch to control LEDS, Dominator D6 running boards/side steps, Blacked out sequential mirror turn signals
    Early Christmas present to myself. Morimoto LED headlights.
    BigJanko, hopwheels, drizzoh and 32 others like this.
  14. Nov 23, 2023 at 11:10 AM
    E.T.
    E.T. Well-Known Member
    Los Angeles
    2016 MGM OR TRD AC Field Truck
  15. Nov 23, 2023 at 11:38 AM
    ensaladas
    ensaladas DarthT8er
    ‘23 Trail Edition
    Swapped skid plates. The factory jack is perfect for this job solo. Some Toyota online stores are doing 25% off OEM parts + free shipping for BF if you’ve been waiting to snag something. :thumbsup:
  16. Nov 23, 2023 at 12:51 PM
    McHale
    McHale Well-Known Member
    2023 Toyota Tacoma TRD OR MGM Access Cab
    Ordered my DD Max fog lights on Monday. UPS dropped them off last night. Got them installed today. Looking forward to getting them aimed and tested tonight.
    I also picked up the stealth lightbar but it would be dark before I could get finished. Hopefully we get another warm day soon.
  17. Nov 23, 2023 at 1:13 PM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    My cheapest “mod” to date! $6.99.
    hopwheels, markram, RCrumb and 15 others like this.
  18. Nov 23, 2023 at 1:18 PM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    @Discount Tire
    So I've had them (Michelin Defender LTX M/S tires) for a month. Put maybe 500 miles on them. I've used them in the rain. Too early for snow.
    I love them. They are quieter than my previous tires, and they don't screech at all when making turns at a reasonable speed. I did have to drive up-hill off road to remove a fallen limb from an apple tree on my property. These tires have much better traction when compared to my old ones.
    Well worth the price...
  19. Nov 23, 2023 at 2:08 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    It is converted by magic fairy dust into fumes that live in the tailpipe. You should spend several hours a day looking into that tailpipe to see the fumes.
    OBXPaul, TRDRed and rgljr831 like this.
  20. Nov 23, 2023 at 2:23 PM
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    Couple pics - 265/70/16
