  1. Dec 11, 2023 at 6:09 AM
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    deets on the Lexus plugs please... getting ready do do the same maintenance on my truck.
    OBXPaul likes this.
  2. Dec 11, 2023 at 6:26 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    sure, there’s a drain and fill, they’ll be 12mm or 14mm sockets instead of the Allen, highly rec, I put them on all of mine (along with a fumoto)
    Part #s: 90341-24016 and 90341-18060
    Also this gasket kit is way cheaper than buying from Toyota. Comes with gaskets for diffs and T-case, I usually reuse the transmission flat steel washers, but you can also buy two of those kits as the transmission uses the same as the t-case
    flat washers: T-Case and Transmission D&F
    Crush washers: Rear Diff D&F, Front diff Fill
    Copper washer: Front diff drain
    https://www.amazon.com/gp/aw/d/B017V4BAXI?ref=ppx_pop_mob_b_asin_title
    OBXPaul, FLAK-TAC, spin180 and 3 others like this.
  3. Dec 11, 2023 at 6:35 AM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    Thanks, I’m interested.
    OBXPaul and TheFactor[QUOTED] like this.
  4. Dec 11, 2023 at 6:36 AM
    roboturner
    Colorado
    Really dreading doing this, have em all ready to go but keep procrastinating and now it’s cold and snowing occasionally :anonymous:
    OBXPaul and rgljr831 like this.
  5. Dec 11, 2023 at 6:43 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Took my taco in for its 25k floor mat inspection. They were fine…
    Asked for new wiper blades…54 bucks! And the driver side has a smear on it…If they don’t improve by weeks end it’s going back to get ones that don’t smear.
  6. Dec 11, 2023 at 7:03 AM
    D-knoww
    D-knoww D-Know
    Washington state
    Blazin Onion, gourmet burgers (western Wa.) the best.
  7. Dec 11, 2023 at 7:25 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    OBXPaul and K9tacoma[QUOTED] like this.
  8. Dec 11, 2023 at 7:29 AM
    N64_Wallmaster
    N64_Wallmaster Carolina Cajun
    Raleigh, NC
    2017 LTD 4WD
    - Bilstein 5100 Shocks - Icon AAL - Old Man Emu 2885 Springs - 16" TRD Bead lock style alloys - bronze - Falken Wildpeak AT3W 285/75 r16 - IFS Skid Plate; Bare Aluminum - Body Armor 4x4 Revo Rock Sliders - Diode Dynamics SS3 Fog Lights w/ Amber Accent Lights - Tacoma Lifestyle Side View Mirror Sequential Turn Signals - Cali Raised LED Bed Channel Supports; added self-adhesive rubber edge trim - AFE Magnum Pro Dry S Filter - LEER 100R Camper Top - Weathertech Window Deflectors - Bulletpoint Mounting Solutions Dash Mount - TRD Pro Grille with Raptor Lights - Headlight H11 to H9 DIY bulb conversion - Diode Dynamics interior and license plate LED bulbs - FBC license plate light DIR - Replaced chrome LTD mirror covers with oe black - Replaced chrome LTD fog light bezel with oe black trim - Meso Customs map and dome lights - Hot Shot Offroad All Lights On - Metal replacement Toyota oil filter housing - VIOFO A119 Mini 2 dash cam
    You're right - it's called hickory
  9. Dec 11, 2023 at 7:32 AM
    N64_Wallmaster
    Raleigh, NC
    2017 LTD 4WD
    LB's are underrated and underrepresented.
    NickAdams2112 likes this.
  10. Dec 11, 2023 at 8:42 AM
    TekITGuy
    TekITGuy Well-Known Member
    Christopher
    Houston area
    2023 Tacoma SR V6 4x4 Double Cab
    TRD Wheels Toytec lift BFGoodrich KO2 Tires Cali Raised Amber fogs AuxBeam Ditch lights TRD shift knob TRD oil and coolant caps Escort X80 radar and direct wire kit Lasfit low beam headlights Redline Tuning Hood Struts more coming soon...
    Pulled a Bronco Sport out of a ditch which was amusing. Also had a "Maintenance Required" triangle light up on the dash on the way home last night. Oil change time? 9800 miles. Can't remember if that is a free thing at the dealer or should just do it myself.
    Shiro213, OBXPaul and rgljr831 like this.
  11. Dec 11, 2023 at 8:45 AM
    Kbar
    Western WA
    22 OR
    I think they do that every 5k. If you have Toyota care, it’s an inspection and I do t know if f you get an oil change free but yea that light will come on every 5k. It will come on everytime you fire up your rig until you reset it in settings.
  12. Dec 11, 2023 at 8:56 AM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Underrepresented yes, but overrated? Not a chance. After owning one, there is no WAY I could go to a baby bed, especially when I have actual truck stuff to do, including hauling. Rented a 5' bed before buying my DCLB, and it was utterly useless for camping or hauling.
  13. Dec 11, 2023 at 8:59 AM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    New Toyotas come with 2 years/25k miles of manufacturer recommended service. Since that is an inspection every 5k and an oil change every 10k (or 12 months), yes it's free at the dealer.
  14. Dec 11, 2023 at 9:19 AM
    TacoSRSX
    TacoSRSX Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    After driving around with warped rotors for the last couple months, I got around to swapping out pads & rotors this weekend.
    Still had quite a bit of pad life left at 81k but I figured it was worth replacing both anyway.
    I found rusty pistons on the LF caliper, not sure how concerned I should be. Quick search brings up really badly rusted calipers that are still in use so I'm wondering how bad this is?
    For reference, I live in Southern California so rust is usually not an issue.
    OBXPaul, rgljr831, spin180 and 2 others like this.
  15. Dec 11, 2023 at 9:45 AM
    MrMobile
    Greg
    Colorado
    Do you have to replace rotors that are warped or just machine them? Living on a mountain with kids learning to drive I've had it happen more often than I'd like so we just did a normal brake job on it (that is after driving for months with them warped because I knew it was going to happen again).
    I've actually never replaced a rotor so I don't even know what it costs vs. machining (and we drive our cars past 200k miles).
  16. Dec 11, 2023 at 9:47 AM
    embedded rock
    embedded rock Well-Known Member
    Be sure to clean caliper pistons before pushing them into the caliper.
    OBXPaul, rgljr831 and scouterjan like this.
  17. Dec 11, 2023 at 9:48 AM
    TacoSRSX
    Martin
    If you catch it early enough, you can machine the rotors provided they are within spec. At 81k miles, I felt like machining them would be a waste of money as they were pretty bad.
  18. Dec 11, 2023 at 9:53 AM
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    Your very welcome and I think you’ll be very happy in all areas
    OBXPaul likes this.
  19. Dec 11, 2023 at 9:54 AM
    Nadjr
    Nadjr Well-Known Member
    2021 Army Green TRD Offroad
    Busy morning, Cab rack installed, top rack loosened and adjusted so they are plum. Received E-mail from Cali raised my sliders order has been processed.BBD91E30-2D0D-49B5-A6D3-BE21B9DB5BD4.jpg 2CEA6EFF-F03F-4BBA-839E-BBFB6D684EA4.jpg D5DADF82-BF39-468A-92FD-23FCD34748E2_1_201_a.jpg
  20. Dec 11, 2023 at 9:55 AM
    BlarBlarjosh
    BlarBlarjosh Well-Known Member
    Josh
    Southern California
    Oh, what pedals?
