  1. Dec 17, 2023 at 4:38 PM
    Glenny
    Glenny Well-Known Member
    Glenn
    penns valley PA.
    2023 LR trail edition
    none I still have a warranty ;-)
    I think I’m going to try and make one out of welding rods my teacher one time told me I’d never make a living with art welding .
    I have a non welding job that pay my bills and enjoy making art and I can make some good cash making art on the side doing something I enjoy doing
  2. Dec 17, 2023 at 4:40 PM
    apreston1
    apreston1 Well-Known Member
    Liberty Hill, Texas
    Impact wrench
    TreeFortRichard, RIX TUX and rgljr831 like this.
  3. Dec 17, 2023 at 4:43 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    So far, no! Was hoping i would be able to add a custom off screen pic.
    OBXPaul and rgljr831 like this.
  4. Dec 17, 2023 at 4:44 PM
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    Installed color matched door edge guards and Door Sill Applique, weather was cold, so I hope they stick.
  5. Dec 17, 2023 at 4:47 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    shhhhh...No tattle tales...
  6. Dec 17, 2023 at 4:56 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Not !
    MrMobile likes this.
  7. Dec 17, 2023 at 4:57 PM
    canuck guy
    Alberta
    23TRDOR
    your cold is different than my cold
    MrMobile, BC Hunter and musicisevil like this.
  8. Dec 17, 2023 at 4:58 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Was ist los?
    AmateurTaco1313 likes this.
  9. Dec 17, 2023 at 5:03 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    This is the way.
    From MESO's website for the Gashole:
    • Remove Phillips head bolt from inside fuel door (TIP: Use a #3 bit on an impact while holding pressure on the door. Toyota has been known to install these tight).
  10. Dec 17, 2023 at 5:18 PM
    steve1503
    New Hampshire
    2020 SR5
    That may be true, but I still hope it wasn't too cold for them. I did have to put on my flannel shirt.
  11. Dec 17, 2023 at 5:22 PM
    apreston1
    Liberty Hill, Texas
    Did it on my 2015 Tacoma, worked like a champ (BTW; I assume everyone understands this is only to loosen the screw.
    Did the same thing on my 2013 Tacoma. Same flawless results.
    ‘this is also a small 1/4” battery powered impact wrench.
    curious if you can share more info on your comment?
    rgljr831 likes this.
  12. Dec 17, 2023 at 5:24 PM
    canuck guy
    Alberta
    23TRDOR
    disagree
    impact?
    talk about overkill
    post # 272349 is best advice
    "1st take the drill and throw it far away from the truck! Then get a good #3 screwdriver (not #2), tighten slightly and then loosen. Although the head of the screw may already be damaged to much"
    OBXPaul, MrMobile and oostroma like this.
  13. Dec 17, 2023 at 5:37 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Good advice. If a screw has never been removed before you should always tighten first to break the torque pressure.
    OBXPaul and MrMobile like this.
  14. Dec 17, 2023 at 5:45 PM
    oostroma
    oostroma (Boomer)
    Ontario
    Tire lifter.
    Unload the tire, roll off. Roll tire on, slide into place.
    Taco22trdor, Irons, MrMobile and 2 others like this.
  15. Dec 17, 2023 at 5:56 PM
    Aarontheidiot
    Aarontheidiot Active Member
    Aaron
    WA
    2022 Red Tacoma TRD Off-road
    Finally got the rims/tires installed.
    kas2828, jjsooner, BJK1280 and 23 others like this.
  16. Dec 17, 2023 at 6:20 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    @LGE RAW Thank you for the update information. Got mine done. EZPZ. :cheers:
    Edit: Said it will address the lag issues and blank screen as well as Car Play phone call issues. I’ll find out tomorrow on the way to work if it fixed the lag issues.
    OBXPaul and LGE RAW like this.
  17. Dec 17, 2023 at 6:32 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Oh come on, you can drive straight through.:)
  18. Dec 17, 2023 at 6:36 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I was going to, but the temps at the place I am camping for the night are in the 20s.... they might have ice on the lakes so Im going ice fishing :)
    But also its a 16 hour drive and if I do it straight through I will be showing up at my 97 year old grandmas house at like 2am :)
    OBXPaul, rgljr831 and musicisevil like this.
  19. Dec 17, 2023 at 6:41 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    maybe the design done by the TOYOTA engineers is the best
  20. Dec 17, 2023 at 6:44 PM
    SmokyMtnGuy
    SmokyMtnGuy New Member
    2019 VooDoo Blue Tacoma TRD PRO
    Stock at present
    Rix,do you have a V6 or 4 and manual or auto?
