  1. Jan 19, 2024 at 6:16 AM
    TCB2020
    TCB2020 Well-Known Member
    2020 Tacoma TRD Sport
    None
    I've been thinking about getting those. How do you like them so far?
    InfernoTacoCO[QUOTED] likes this.
  2. Jan 19, 2024 at 6:20 AM
    TCB2020
    None
    I purchased #40 and #55 Torx sockets yesterday in anticipation of installing bed stiffeners in the next couple of months. Total Chaos and one other whose name I can't recall at the moment but they about $20 more than the TC's and have 2 "ribs"?? running along the edges of the brackets whereas TC only has one.
    rgljr831 likes this.
  3. Jan 19, 2024 at 7:25 AM
    TRDTaco420
    TRDTaco420 Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
    Battery test failed at the dealer, but I can put a battery in easy enough so I went to crappy tire.
    The little white under tray is a cute touch from Toyota.
    spin180, markram, OBXPaul and 7 others like this.
  4. Jan 19, 2024 at 7:28 AM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    When I installed my Mini 2 I had planned on using the Donger unit but instead decided to use the Garmin Parking Mode Cable. I have used the parking mode cable in the past with the Dash Cam 46 and it works really well. The cable allows you to set a voltage so that when your battery hits a certain voltage it will shut off the camera so that it doesn't fully drain your battery.
  5. Jan 19, 2024 at 7:48 AM
    TRDTaco420
    The Bear
    Kewl shizz
    I picked up these a long time ago to cover the Chrome...
    @RIX TUX
    spin180, OBXPaul, Jerry311SD and 6 others like this.
  6. Jan 19, 2024 at 8:10 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I put those metal sleeves on all the controls. Easier to grip in the winter time especially.
    E.T., spin180, OBXPaul and 4 others like this.
  7. Jan 19, 2024 at 8:38 AM
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    I had 2 30” light bars on my semi and a 50” on the roof of my wifes jeep and I bought button head Allen key bolts for them. Got them on the perfect spot and tightened the shit out of them with lock tight. Then drilled the Allen key hole out.
  8. Jan 19, 2024 at 9:30 AM
    1TACOTONY
    1TACOTONY Well-Known Member
    Tony
    MICHIGAN
    2017 Inferno TRD Sport 4x4 M/T
    MISC. MODS WEBOOST overland cell booster Blacked out badges Black bedside decal Uptop overland alpha roof rack with inferno armortek and baja designs scenelighting EYECATCHER PRO Tacoma tailgate letter inserts Trd Pro grill with raptor lights(REMOVED) DB CUSTOMS Toyota halo grill with backlighting TRD color match grill badge Color matched Trd Pro shifter Tinted windows Front and Rear MBRP 3" side exit exhaust w tip OCD center console organizer Meso Customs Flip Fob Key Meso Customs blacked out climate control rings Meso Customs blacked out vent rings Meso Customs blacked out 4x4 ring Meso Customs coin organizer M/T Meso Customs blacked out steering wheel emblem overlay Meso Customs blacked out handle covers Meso Customs Overhead hex rack (sunroof model) KTJO4X4 HUD FOR TACOMA Trd pro skid plate Tufskinz glovebox insert ch4x4 custom switches w/ cubby panel Lil B's bed stiffeners with bottle opener Inferno Door sill guard inserts Rear passenger dual USB charge port Rear window switch relocation mod Taco Time plate frame AVS low profile in channel vent shades URD short throw shifter kit Cravenspeed Gauge mount JLT oil catch can N2 Designs remote start with smartphone module Trailer hitch step guard with locking pin Hondo garage unholy mount with ohnap magnetic mounts(driver and passenger side) Diamondback HD smooth bed cover Uptop Overland Diamondback truss rack system Ikamper Skycamp 3.0 mini with insulation liner Wolfbox G900 mirror and dashcam front and rear camera Seat jackers front and rear driver and passenger side Front seat jacker multi panel mounts driver and passenger side ////// (AWAITING ARRIVAL) None at this time (AWAITING INSTALL) Uptop overland rack lights dual function white and amber x8 /////// SUSPENSION COMPONENTS FRONT Fox 2.5 extended travel coilover remote resi with adjuster and added protection for the reservoir Sway bar relocation kit Spc adjustable uca (removed) Icon billet UCA Durobump bumpstops Runnin 4 Tacos lower control arm skids REAR Fox 2.0 extended travel remote resi with adjuster and Fox roost guards Toytec (Deaver)3 leaf progressive aal Durobump 4.25 bumpstops with Ubolt flip kit ///// WHEELS AND TIRES FN FX Pro matte black w import equipment center decal BFG KO2 285/70/17 ///// AUDIO Stinger Heigh10 10in multimedia display w/ tacoma flush mount integration kit and wireless AA adapter OEM Audio Reference 450Q w/ subwoofer Soundskin Pro sound deadening doors,panels,counsol and rear wall ///// LIGHTING Rigid Radiance+ Amber backlighting 30" Hidden Bumper Light Bar Rigid Radiance Scene pods with amber backlighting Morimoto XB Led projector Gen 2 Black headlights with sequential turn signal MESO Customs/ Morimoto led sequential tail lights Morimoto XB Led projector fog lights Meso Customs blacked out ultimate turn signals (REMOVED) Meso Customs blacked out ultimate v5 turn signals with white drl and sequential turn signal (INSTALLED) Meso customs puddle lights w switch TRD pro tail lights Mic tuning 2 bar triple row tailgate bar with brake,reverse and sequential turn VLed upgrade vanity lights Meso Customs ultimate map light Meso Customs dual brightness cab light Led upgrade turn,brake,side markers and plate lights (changed to meso customs headlight and taillights) Import equipment 3rd brake light cover Raptor grill lights (REMOVED WITH PRO GRILL) KTJO4X4 door handle lighting Yota mafia KC hilites v2 rock light 6 light kit with auto on feature UPTOP Overland Underhood lighting with Baja designs pods Baja designs rock lights with scenepods 2.0 for roof rack
    It took me alot of research as well. Went through looking at alot of brands and looking at all the specs like Garmin,blackvue and many others. I ended up going with the wolfbox G900 because it checked all of the boxes of what I was looking for. high definition, great fitment,ease of install,clarity of video and didn't have to add another item to the window or a switch as it replaced my factory mirror. Overall very happy with it so far
    OBXPaul and Dtax[QUOTED] like this.
  9. Jan 19, 2024 at 9:39 AM
    TRDTaco420
    The Bear
    Kewl shizz
    Me too
    taco abbo, spin180, OBXPaul and 2 others like this.
  10. Jan 19, 2024 at 9:59 AM
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    OBXPaul, RIX TUX, BC Hunter and 2 others like this.
  11. Jan 19, 2024 at 10:10 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Ya mine failed test (started at home and died at grocery store in -35) and was replaced under warranty. Can't believe how bad the original Toyota batteries are in Canadian winters. You should be good now. I've had good results with crappy tire batteries in past.
  12. Jan 19, 2024 at 10:23 AM
    TRDTaco420
    The Bear
    Kewl shizz
    Even though I have a booster in the truck I did not want to get stuck, even to have to lift the hood in below zero temps. So it was, replace just in case.
    OBXPaul likes this.
  13. Jan 19, 2024 at 10:23 AM
    CmentTacoma
    CmentTacoma New Member
    Scott
    2018 SR Access Cab 2WD
    Added Tacoma emblems and modified SR (formerly SR5) emblem . Also got rid of the steelys and got these 16” wheels for $500
    spin180, Irons, OBXPaul and 13 others like this.
  14. Jan 19, 2024 at 11:04 AM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Sandblasted my new C4 Fabrications-“Overlander Rear bumper” this morning to get a really good profile.. IMG_9719.jpgIMG_9720.jpg IMG_9721.jpg
    then put a prime coat of Plasite 7133 and letting it cureIMG_9723.jpg IMG_9724.jpgIMG_9725.jpgit’ll be cured and ready to sand and top coat by morning
  15. Jan 19, 2024 at 11:51 AM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Love those sliders. Truck looks great!
  16. Jan 19, 2024 at 11:52 AM
    mrchristopher2
    mrchristopher2 Well-Known Member
    2020 TRD Pro 6spd
    Took a short drive out to Backbone Rock in the fresh snow
  17. Jan 19, 2024 at 1:38 PM
    hoytshooter1
    hoytshooter1 Well-Known Member
    Cave Creek, AZ
    2020 DCSB
    ICON's Method's w/265-70-17 (Gone) '16SR5 Wheels with 255-85-16 Falken MT's AZ pinstriping
    And if so, do they rub and what lift?????
  18. Jan 19, 2024 at 1:39 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    2 mm lift.
  19. Jan 19, 2024 at 1:44 PM
    hoytshooter1
    Cave Creek, AZ
    2020 DCSB
    RUB man!! Do they rub?!!! I's gots to know!!:D
    Spadi_5 and BC Hunter like this.
  20. Jan 19, 2024 at 1:45 PM
    RichochetRabbit
    Enquiring minds must know!
    BC Hunter likes this.
