  1. Mar 3, 2024 at 12:17 PM
    era86
    era86 Well-Known Member
    2021 TRD Off-Road 6MT
    Yea! I ordered a replacement one from Pop-n-Lock since I didn't know if the wiring for the Pop-n-Lock would work with any other actuator, including the OEM one. Should probably done more research before ordering.:facepalm:
    PapaRee[QUOTED] likes this.
  2. Mar 3, 2024 at 12:30 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Welcome to TW! :cheers:
    Atellus[QUOTED] likes this.
  3. Mar 3, 2024 at 1:08 PM
    stevenryannn
    stevenryannn Member
    Steven
    2019 Tacoma TRD-OR DCLB
    Derped the TRD OR grill.
    AP1GczO69pwurzrcdZSfVP-WR7ZbiEBfL6_vKhRi_0dbebfec66ee4f46d3ecc341c9769226984739c9.jpg
    Installed a Diode Dynamics SS30 light bar with CaliRaised hidden light bar brackets. Trimmed air dams to retain 3/4 of the OEM-ness and functionality. Snagged the SS30 on Facebook Marketplace and the guy also had some Diode Dynamics ditch light brackets he threw in for $25. So I ordered some ~$40 ditch lights from Amazon. https://www.amazon.com/dp/B0BYMZRZH1?ref=ppx_yo2ov_dt_b_product_details&th=1
    The beam and intensity looked really good while testing prior to install, but my harness hasn't arrived yet, so I'll get some testing/photos once that's completed.
    Honorable mention: Installed Diode Dynamics SS6 light bars to factory hole mounts (with Diode Dynamics U-bracket) a couple weeks ago. They're pointed slightly outward to complement the light bar with a wider spread. Once dialed I'm looking to a) try a flood or fog lense or b) remove them entirely based on needs.
    AP1GczN12gUDeTQtHURQ_-9e9-uTvtiWrzciZRTf_8da6d46b704aaea12381f424f5fc54fc47a1e7be.jpg
    Bonus: The 6" bars in conjunction with the 30" give me Iron Man/flat-mouthed emoji vibes.
    AP1GczNC83Ctz30SFhNhBxwvkknSlhrWwfZgHaj-_4a9b595dd181a65bcb46f849bf04ae76a0984f55.jpg
    In my heavily biased opinion it passes the aesthetics test...we'll see about the test of time.
    Thank you to the members and countless posts of Tacoma World for both the inspiration and instruction on how to get this done.
  4. Mar 3, 2024 at 1:16 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
  5. Mar 3, 2024 at 1:47 PM
    Taco-cat
    Taco-cat Member
    20240303_122333.jpgJust hit 200 miles. I think this is part of the break-in procedure.
    Shayne, Raku77, TheFactor and 33 others like this.
  6. Mar 3, 2024 at 1:52 PM
    robin303
    robin303 Well-Known Member
    Robin
    Houston Tx
    21 TRD Sport
    OO-AHHH :mudding:
    rgljr831 and Taco-cat[QUOTED] like this.
  7. Mar 3, 2024 at 1:53 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Not muddy enough yet. Work on it!
  8. Mar 3, 2024 at 1:59 PM
    Crow41
    Crow41 Well-Known Member
    Lehigh Valley PA
    Welcome to TW. You're off to a good start!!
    rgljr831 likes this.
  9. Mar 3, 2024 at 3:13 PM
    TacosMan
    TacosMan Well-Known Member
  10. Mar 3, 2024 at 3:25 PM
    TheFactor
    TheFactor Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    It took me a while to get use to it gear hunting and then after tune none at all. At first it feels so good you think there might be something wrong lol.
  11. Mar 3, 2024 at 3:45 PM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Well, there’s another habit I’d have to relearn: Setting cruise control. For at least 30 years (had a ‘92 Previa) it’s been a stubby located at 4 o’clock behind the steering wheel.
    EDIT: Makes me think of a variation on the quote attributed to John Wayne: Change is hard; stupid changes are harder.
    skyking3, OBXPaul, oostroma and 4 others like this.
  12. Mar 3, 2024 at 3:48 PM
    KS1371
    KS1371 Well-Known Member
    Rowlett, TX
    '23 MGM TRD Sport 4X4
    Over the last two days, added OME 886s to the front and Icon AAL to the rear.
    23" all four corners.
    Did my best to accurately measure all four the same way from Center hub to lower wheel well.
    Possible that the lean will come out later.
    No before measurements. Sorry folks.
  13. Mar 3, 2024 at 5:30 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Been using this stuff to clean off the bird crap between washings. I use it on my motorcycles too.
    Decided to do entire vehicle since it wasn't very dirty and didn't feel like dragging out the pressure washer. I'm on a private well and the house water pressure isn't that good for washing vehicles.
    Pros: You heard the saying "I put that sh*t on everything". Well this stuff works good on everything. It's real wax as you can feel it when buffing out.
    Cons: Not to be used if vehicle is caked with mud or salt. I didn't use it on the tires. I used soap and water with a scrub brush. You do small areas at a time and because the watery consistency it's hard to see where you left off. A lot of overlapping. Don't really know about the protective qualities.
    Make sure to read instruction. I spray product on surface and wipe gently with damp MF towel. Before product dries on surface, buff out with CLEAN MF towel. I rinse applicator towel, or use clean towel, between doing areas of surface being cleaned.
    I also 'accessorized' my HU with RAV4 radio knobs (no picture).
    2Nice, LunaRover, timw1 and 13 others like this.
  14. Mar 3, 2024 at 5:42 PM
    GruntOutdoors
    GruntOutdoors Active Member
    Stephen
    2017 Black Tacoma Limited
    2017 Toyota Tacoma Limited Built With: Performance: @Alexautomotivesinc - Tacoma Exhaust Reroute & So Much More @ARB - Front & Rear Lockers @ECGS @Eastcoastgearsupply - 4.88 Gears @Inhousefabrication - 4″ Stainless Steel Snorkel @Injentechnology - Injen Evolution Cold Air Intake System @Mismimoto - Performance Aluminum Radiator & Silicone Radiator Hose Kit @OTT - Overland Tailor Tuning @Runnin4tacos - High-Clearance Cat-Back Exhaust Armor: @Advancecoatingsolutions – Desert Tan & Black Powder Coating @CBIOffroad - Full Overland Skid Plates @Extreme_Custom_Collision - Rhino Liner Truck @Fishboneoffroad - Fishbone Offroad Rear Bumper @Lil_Bs_Fabrication - Mid Bar With Bull Bar Pod Mount/Pre Runner Side Bars Suspension: @Blackrhinowheels - Bantam 16x8 @Bilstein - B8 8112 DCA + & B8 8100 Bypass @Icon Vehicle Dynamics - Delta Joint Tubular Upper Control Arms @Ironman4x4 400lb+ leaf springs Electrics: @Anytime Front/Rear Cameras @Auxbeamlighting - 8 & 12 Gang Switch Panel @Battlebornbatteries - 2x100ah 12v Lifepo4 Deep Cycle Battery @Cali_Raised_Led - 3x2 18w Amber Led Pod, Bed Channel Supports & Stiffeners @Mesocustoms - V2 Ultimate Dome Light & V2 Dual Color Map Lights @Morimoto - HXB 2banger (Combo/White) / (Wide/Yellow), HXB 4banger (Combo/Yellow) / (Wide/Yellow), and HXB Bigbanger (Amber DRL/Combo/White) @Redarc – BCDC 1240d 12v, 40A In-Vehicle DC To DC Battery Charger @Trailgridpro - Sony Xav-Ax8100 Plug & Play Bundle Recovery: @ARB - Twin Motor Onboard 12v Air Compressor Kit @Bleepinjeep - Freedom Winch Line Style 3/8" Rope 90ft @HARBor Freight - Badland Apex 12,000 Lb. Winch @OVS – @Yankum_Ropes - Standard Groove Fairlead Camping: @Alucab - Shadow Awning & Shower Cube @Dfgoffroad - Fridge Slide & Tilt For CFX3 45 @Dometic - CFX3 45 @Vagabondoutdoors - Vagabond Drifter Interior: @300Industries - 1 Piece Steel Grille For Toyota Tacoma 2016-2017 - Straight American Flag @Expeditionessentials - Dash Mount @Mesocustoms - Overhead Hexrack @SHWOffroad - Full Rear Seat Delete - Tall Height @Teton_Workshop - Automatic Tacoma 3rd Gen Design 1 Exterior: @Dirtcom - Trail Swing @Ragofabrication - Shackle Hangers @Runnin4tacos - Tailgate Lock Full Kit @Uptopoverland - Bravo Tacoma Double Cab Roof Rack
    I had some free time today so I decided to install some new sliders. So far I'm really liking the Step Edition Rock Sliders with Filler Plate. That desert tan powder coating is amazing! I hope it can hold up!20240303_181753.jpg
  15. Mar 3, 2024 at 5:44 PM
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    ssd2k2[QUOTED] likes this.
  16. Mar 3, 2024 at 5:57 PM
    ssd2k2
    Keith
    Minnesota
    OBXPaul and Dtax[QUOTED] like this.
  17. Mar 3, 2024 at 6:05 PM
    Dtax
    Massachusetts
    Mods = N+1
    OBXPaul and ssd2k2[QUOTED] like this.
  18. Mar 3, 2024 at 6:10 PM
    SpaceInvader1128
    SpaceInvader1128 Member
    Pete
    2023 Toyota Tacoma SR5
    - Legit! I was going thru the ringer, i put up with that garbge for the better part of a year, finally caved and slipped my notice. I work in pharma, wicked high turnover rate cuz of burnout.
    - I love this saying. never gets old.
    OBXPaul likes this.
  19. Mar 3, 2024 at 6:11 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Part of work parking lot. Mines on the right.
    SoCalSport, 2Nice, KS1371 and 39 others like this.
  20. Mar 3, 2024 at 6:19 PM
    Cement_wheels
    My neighbor works in pharma here at RTP. Seems he changes jobs about every 4 or 5 years. Always working weird shifts/hours.
    OBXPaul likes this.
