  1. Mar 24, 2024 at 6:57 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    I've heard that in Moab they know it's spring when the license plates turn green (from all the CO folks coming since it's still winter here). But you have a blue CO plate so I don't know how that fits in.
    Looks beautiful; I need to go back.
    BirchyBoy[QUOTED] and rgljr831 like this.
  2. Mar 24, 2024 at 7:02 PM
    MrMobile
    Greg
    Colorado
    I really like the Go Avs part. The badge is up to you; if you like it, keep it. I added a small tri color emblem to the grill so I'm just reinforcing the brand too.
    Rellims[QUOTED] and rgljr831 like this.
  3. Mar 24, 2024 at 8:10 PM
    nioking
    nioking Well-Known Member
    whys it look like this is a rear end lol
    drizzoh and rgljr831 like this.
  4. Mar 24, 2024 at 8:11 PM
    nioking
    seeing this makes me want to get a prinsu for my cab to match the camper
  5. Mar 24, 2024 at 8:14 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    Uneven gaps on the rubber around the windows, leaks on the windows, bad paint, side windows chipped on edges.
  6. Mar 24, 2024 at 8:16 PM
    TN1000
    Work in progress
    I refer to those clowns at the stealerships as "Interns"..I refuse to pay top dollar at a dealership for a bunch of interns to F### up.
  7. Mar 24, 2024 at 8:20 PM
    TN1000
    Work in progress
    When you put in a agm battery I read that you have to reprogram your alternator or something to charge the higher capacity battery?
    RIX TUX and rgljr831 like this.
  8. Mar 24, 2024 at 8:31 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Correct. A tuner can change the ECU to up the charge rate for the AGM battery. Of course, you can run without, but it will shorten the life of your battery and you're not getting the full benefit of the AGM that you paid extra for.
    If you're already tuned, it should take less than 5 minutes. If not, it will likely be more expensive and involved.
  9. Mar 24, 2024 at 9:15 PM
    gfunk1127
    gfunk1127 I'm so mild.
    G.W.
    Burlington, NC
    2016 Tacoma SR5 4x4
    Plastidipped Badging Sokie Tech Hood Struts Window Vents (in channel) Eibach Lift
  10. Mar 24, 2024 at 9:28 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    2TR-FE power, even though its not the 3rd gen with the same cab configuration looks much bigger
    rgljr831 likes this.
  11. Mar 24, 2024 at 9:48 PM
    5Sport
    5Sport Well-Known Member
    Those work with the BSM's? Do you have the part number? I thought that the Rav4 Mirrors didn't work with the BSM? Thanks
  12. Mar 25, 2024 at 5:27 AM
    Hogan1966
    Hogan1966 Well-Known Member
    Kevin
    Loveland, OH
    2021 DCSB TRD OR - Army Green
    Blackout package - planned: black bed logos, black wheel vinyls, front seat window tint, tires.
    No pics and not today, but in the last couple weeks:
    • I got the body/cab mount squeak issue fixed
    • installed a 3rd party bed step
    • added Seat Jacks to the passenger seat
    • installed smoked, sequential side mirror turn signals
    • had the OTT tune done to lite/mild on Saturday.
  13. Mar 25, 2024 at 6:15 AM
    AGTaco22
    AGTaco22 Well-Known Member
    Warren
    RVA
    2022 Tacoma TRD OR
    How are you liking the OTT light/mild so far? I'm getting mine done the weekend after next. I'll be going with the light/mild as well.
    stevenryannn and cgraham30240 like this.
  14. Mar 25, 2024 at 6:22 AM
    Hogan1966
    Kevin
    Loveland, OH
    I've only driven less than a hundred miles or so, but so far, I couldn't be happier.
    My thoughts are, in lite mode, it drives exactly like it should have off the lot...much better throttle response from a dead stop, no lag when turning corners, and 0 gear hunting. Mild is a bit jumpy off the start and more responsive. I'm sure I could have gotten used to that if I had it done for the non-ECT mode, but what I chose works perfectly for me.
    I think you'll love it.
  15. Mar 25, 2024 at 6:36 AM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
  16. Mar 25, 2024 at 6:36 AM
    AGTaco22
    Warren
    RVA
    2022 Tacoma TRD OR
    Thanks for the feedback! That sounds like exactly what I'm looking for in this tune.
  17. Mar 25, 2024 at 6:53 AM
    Crusher 2
    Crusher 2 Well-Known Member
    N. Virginia
    19 DCSB, SR5, Cavalry Blue, mostly stock
    Loaded my truck on Amtrak Auto Train and went to Florida!
    (Dummy me missed them loading and unloading my truck… smh). IIRC… Amtrak size limit is 214” long, 84” tall, 84” wide (0/S mirrror to mirror). If I remove the trailer hitch ball the DCSB measured 211” front plate holder to rear bumper.
    andthen, RCrumb, thomasburk and 11 others like this.
  18. Mar 25, 2024 at 7:06 AM
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    Replaced my icon add-a-leaf yesterday with the icon rxt option 3. When I pulled out of the garage to clean up and go got a test drive I seen a single drop of oil on the floor from the front of the truck. I crawled under and my drivers cv input seal is leaking pretty bad, like surprised there was only 1 drop. I did do the ECGS bushing last spring time area. So now new project for today if Toyota has a seal in stock.
    Taco22trdor, spin180 and rgljr831 like this.
  19. Mar 25, 2024 at 7:09 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Used to live off of Rayford and 45 - close to an old freedman's town called Tamina. I'd imagine real estate developers have bought that area out and put homes on it. Any way - There is something about the way a N. Houston neighborhood pic looks. The homes, the grass, the sky coloration. Takes me back. Taco looks great too but the rest of that pic is dripping with nostalgia for me. Thank you.
    Taco22trdor, 23 SR5 LB and rgljr831 like this.
  20. Mar 25, 2024 at 7:15 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
