  1. Apr 28, 2024 at 10:35 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I can tell you "high country" east of Steamboat can be mighty cold camping in May ;_)
    Not much sleep that rainy sleety snowy night....
    MrMobile[QUOTED] and rgljr831 like this.
  2. Apr 28, 2024 at 10:37 PM
    VTCAL
    2021 Sport
    Borros or burrows, I can't tell an ass from a hole in the ground.
    scouterjan and musicisevil like this.
  3. Apr 28, 2024 at 11:06 PM
    leomodz
    leomodz Active Member
    2020 Tacoma TRD ORSB
    I went with the recommended size from Accutune, but haven't put enough milage on it yet to be sure. Nice thing is they offer custom spacers in case the travel isn't enough.
    rgljr831 and devinzz1[QUOTED] like this.
  4. Apr 28, 2024 at 11:35 PM
    FranksGotTacos
    FranksGotTacos donkey
    SB
    Denver
    16 DCSB. Geared, Dual Locked, 35s, Topperlift, wet AF
    5.29 gears, ARB locked, Lil Bs front bumper, Hooligan sliders and roof rack, cab and bed cap, Outgear solutions rear bumper, custom swingout. 35's. Icon rebound pros x 5, OME BP-51s. Topper ez lift. Decked. Full RCI full skids, misting system with 4 gal plumbed into 270 ironman awning, air plumbed to all 4 corners + decked, DK upper shear kit, Marlin LCA brace kit, 10 pc rock light kit, scene pods, u bolt flip, stage 3 deavers, poly bushings all around, archive garage hammer hangars, sumo springs rears, TC gusseted spindles, spiker hood struts, aux beam 8 gang, 50 watt solar on top of 2x pelican cases, Cascadia 4x4 mppt solar charge controller, jackery 1000, alpicool 45L fridge. Rear seat delete with fridge slide on passenger side (by me). Meso overhead rack, Meso cab, dome, rear interior lights, Meso x morrimoto tail lights. CVJ high angle boots,
    run and run fast from SPC. Their quality has fallen off. They used to be a company that was an easy fix for correcting angles and moving the tire forward bc of lift, but you will regret it. You will be clunky, riding rough, and pissed off wondering why your truck rides like sheeet after a few months after you JUST installed new parts. Take it from me, stay away from SPC.
  5. Apr 29, 2024 at 12:06 AM
    MGMDesertTaco
  6. Apr 29, 2024 at 6:09 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    didnt know they offered different sizes. i have icon rxt rear shocks with the weird offset lower mount so they kinda need stock height bump stops at compression. want to utilize every single inch of travel available. these seem like a good option. i had plan to order some hammer hangers anyways
    rgljr831 likes this.
  7. Apr 29, 2024 at 6:27 AM
    TecnoMuzik
    TecnoMuzik Member
    Dave
    NW burbs of Chicago
    2023 TRD Sport; Blue Crush Metallic; DCSB
    Installed the TRD skid plate on my ‘23 Sport yesterday. When I was doing the install I found the rear piece of the factory skid plate was missing along with its bolts. Thought that seemed odd but moved on. Then while trying to install the new TRD plate, the rear 12mm bolt on the driver side just would not screw into the bolt hole. Tried a bolt straight into the hole and it would rotate once and stop. The passenger side it fit just fine. I then remembered that after having my oil changed the first time, I had some rattling come from the front of the truck. It turned out to be one of the bolts in the front skid plate that wasn’t secure. It had been mis-threaded so it stopped before it could secure the plate in place. At the time I didn’t think anything of it as I was able to back it out and correct it. But now I’m thinking the dealer probably mid-threaded the rear skid plate and then just said “screw it” and decided to not fix it or re-I stall it.
    I ended up getting a tapper and rethreaded the hole. After that the new skid plate installed easy peasy.
  8. Apr 29, 2024 at 7:34 AM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    The Sport model only comes with the front part of the engine skid plate.
  9. Apr 29, 2024 at 7:39 AM
    frahengeo
    frahengeo Well-Known Member
    Adam
    Tacoma Shopper --> Owner
    I think the Sport trim only comes from the factory with only a front skid plate. I believe the OR trim comes with a front and rear plate (2 pieces).
    Someone/Anyone, please correct me if I'm wrong.
    Edit: MrMobile beat me to it.
    rgljr831 and scouterjan like this.
  10. Apr 29, 2024 at 7:46 AM
    frahengeo
    Adam
    I only get that kind of mpg when I'm traveling south.
    RIX TUX, TacomaAddict23 and MrMobile like this.
  11. Apr 29, 2024 at 7:46 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    The more I read the horror stories about Toyota dealer incompetent service techs the more I think that taking the time to learn to do most of the maintenance myself is the safer and cheaper option.
  12. Apr 29, 2024 at 7:48 AM
    TecnoMuzik
    TecnoMuzik Member
    Dave
    NW burbs of Chicago
    Oh really? Interesting. I swear I’ve only ever seen postings about it being a two piece, but I also haven’t researched the factory skid plate. Thanks for the info
    MrMobile[QUOTED] likes this.
  13. Apr 29, 2024 at 7:49 AM
    MrMobile
    Greg
    Colorado
    I feel fortunate that my local dealer has been fair and competent for us. Once they did a CV boot on our RAV4 and it leaked; they didn't just fix the boot they said it could have damaged the axle and proactively replaced that too at no charge. But there's another one not too far away with much higher prices and I have not liked them.
  14. Apr 29, 2024 at 7:54 AM
    MrMobile
    Greg
    Colorado
    I think fewer Sports than ORs get the skid swapped out so you'd hear less about it. Regardless, the factory plate is IMO just an early warning system and if you are going anywhere rough it's worth the investment to replace with something more robust. I don't intend to skid across mine but from past experience I know I will hit/scrape things. They don't call the Rocky Mountains I live in "rocky" for no reason!
  15. Apr 29, 2024 at 8:17 AM
    Tacodog
    Tacodog Well-Known Member
    Ron
    Renton, Wa.
    ‘19 TRD offroad DCSB Cement
    Icon stage 1, Icon upper control arms, 17” Fuel wheels,Ridge Grapplers, TRD exhaust, leather interior.
    Need to pump up those numbers. That’s rookie shit.
  16. Apr 29, 2024 at 8:32 AM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    So much for approach angle
  17. Apr 29, 2024 at 8:33 AM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    Steel wheel Center Caps Falling Off FIX??
    My steelie plastic center caps seem to be falling off. At first I thought it was where I got the truck inspected but now I noticed another has fallen off.... I prefer them on. Sure I could bend the tabs but as Tacomaworld is filled with people that have already done that I figured I'd ask... .Many thanks!!
  18. Apr 29, 2024 at 8:43 AM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    I'm on 33s. 5.29 regear and KDMax tune. BAMF hybrid bumper, winch, full RSI skid package, Icon Stage 3 lift and an RSI shell. I avg 13.5-14 mpg.
  19. Apr 29, 2024 at 8:48 AM
    indoomitable
    indoomitable Baby-steppin' down the stairs
    Texas
    2018 OR 4x4 DCSB
    Got rid of my rock chipped grill and plastidipped trim ring, all thanks to a member here who hooked it up with a great condition grill and OEM black trim ring. I actually like these grills a lot, once the chrome trim is eliminated of course!
    andthen, MTBTACORN, spin180 and 6 others like this.
  20. Apr 29, 2024 at 9:05 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yeah see that sounds much more accurate. Thanks for the input.
