  1. May 26, 2024 at 6:19 AM
    Detailsmatter
    Detailsmatter Member
    Grayson
    ‘19 Cement DCSB TRD OR 4x4 MT
    To get to the oil filter. The TRD Pro skid has an access door on the skid. The TRD off road cheapo skid has to be removed entirely. I do oil every 5k. So I pull the skid about 3 times per year.
  2. May 26, 2024 at 6:21 AM
    Kane50
    Kane50 Well-Known Member
    2016 TRD Sport
    Garage kept and not my daily driver, plus because I live near the ocean I wash it ALOT :bucket:
  3. May 26, 2024 at 6:22 AM
    Detailsmatter
    Grayson
    No offense taken
    Explain it to me like I’m 5 years old
    portorawk likes this.
  4. May 26, 2024 at 6:27 AM
    Detailsmatter
    Grayson
    To be honest, I never considered putting anti seize on the threads… I’m just a hobbyist learning as I go! I thought the culprit of the problem was my 12-point socket combined with the cheapo soft rusting metal of the bolts… maybe I’ll slap some anti seize on the new aluminum bolts next oil change. Thanks!
    Irons likes this.
  5. May 26, 2024 at 7:00 AM
    lastcall190
    lastcall190 Well-Known Member
    NJ
    2023 Silver DCSB TRDOR
    Installed the SS3 Pros Friday and this AM grabbed these off CL with a set of lugnuts. Not sure when I'll get some new tires to go with them but the deal seemed good and they're near new takeoffs.
  6. May 26, 2024 at 9:32 AM
    hoytshooter1
    hoytshooter1 Well-Known Member
    Cave Creek, AZ
    2020 DCSB
    ICON's Method's w/265-70-17 (Gone) '16SR5 Wheels with 255-85-16 Falken MT's AZ pinstriping
    THE best mod you can do to your Taco.
  7. May 26, 2024 at 10:29 AM
    Bravesfan1995
    Bravesfan1995 Well-Known Member
    Ashley
    2023 Tacoma TRD off-road Ice Cap
    It’s a swisstech. Unsure of the model. It was a gift to all the groomsmen in a wedding I was recently in. Blade feels nice and it has a smooth spring opening.
  8. May 26, 2024 at 10:35 AM
    Bravesfan1995
    Ashley
    Front seat jackers and molle panel by yota TV. Wanted to go with desert does it, but couldn’t justify spending twice as much for seemingly same quality product. Picked the jackers (just 1 seat) and Molle panel for $132 total.
    Burns, spin180, elboniecki and 7 others like this.
  9. May 26, 2024 at 11:03 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Been putzing with this project for a couple of weeks, in between other things. Mounted and wired an Auxbeam 6 switch panel, rewired my 20" light bar, added 2-7" light bars in the rear bumper, and topped it all off with ditch lights.
    ljerr2, 23 SR5 LB, spin180 and 11 others like this.
  10. May 26, 2024 at 11:21 AM
    kylecrish
    kylecrish Well-Known Member
    Cel. Silver 2023 Tacoma TRDOR
    Stainless steel is almost always a softer material than it's equal sized carbon steel counterpart. Low carbon content in the stainless means that it can not be hardened. So, when you go to torque it down, it'll need to be torqued to a lower value. Meaning it's not always the right choice for some off-roading parts. But, if you don't do much off-roading, I'm sure they are fine to simply hold the skid plate. Max torque on an M8 stainless bolt is 11 ftlbs with thread lubricant. On a class 8.8 carbon steel bolt of the same size, it's 16 ftlbs.
  11. May 26, 2024 at 12:22 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I added bug screens to the camper shell, so I can actually camp in it. I couldn't figure out a good way to attach it until I thought of hot glue. It turned out to be super easy. I used about two glue sticks, and it took 20-30 minutes. It's semi-permanent, but the glue can peel off the aluminum trim if I need to remove it.
    If it rains I'll just put some kind of stick or block in the windows so they are only open a few inches. If it's hot I'll leave them wide open.
    The bug mesh was $12 on Amazon for a 5'x10' piece.
    PXL_20240526_174936271.jpg PXL_20240526_174754914.jpg PXL_20240526_174731080.jpg
    Trigger1013, Tnc, RCrumb and 10 others like this.
  12. May 26, 2024 at 12:24 PM
    Taco.Tuesday
    Taco.Tuesday Well-Known Member
    New Mexico
    '21 TRD Sport 4x4 DCLB
    Applied a GapShield cover for the tailgate gap, I'm loving it so far.
    E.T., RCrumb, spin180 and 4 others like this.
  13. May 26, 2024 at 12:31 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Ohh you're talking about the stock splash guard hardware...had me confused for a bit
    RIX TUX likes this.
  14. May 26, 2024 at 1:28 PM
    steve1503
    steve1503 Well-Known Member
    New Hampshire
    2020 SR5
    I added the Cartrimhome Heated steering wheel today.
    ljerr2, JSX, TacosMan and 14 others like this.
  15. May 26, 2024 at 1:33 PM
    AGTaco22
    AGTaco22 Well-Known Member
    Warren
    RVA
    2022 Tacoma TRD OR
    Frito, -Rorschach-, RCrumb and 9 others like this.
  16. May 26, 2024 at 2:20 PM
    StinkFu
    StinkFu Well-Known Member
    Pacific Northwest
    2022 Tacoma TRD Pro MT
    AJT Design Tacoma 4x4 Knob AJT Design Tacoma Climate Rings AJT Design Tacoma Door Handle Covers All-Pro Off-Road HD Rock Sliders Alu-Cab Tilting Fridge Slide Aluminum Radio Knobs Android Auto Cable ARB Twin Air Compressor AWE 0FG Exhaust with BashGuard - No Tips Badland Jack Mounts Badland Off-Road Jack Baja Design Rock Lights / Scene Pods Black Door Handle Covers Bolton Velocity Off-Road Kit Cali Raised AC Drip Relocation Cali Raised Center Console Molle Panels Cascadia 4x4 45W Panels & Controller Ceramic Coating CourseMS Phone Mount Desert Does It Seat Blocks & Panel Diode Dynamics Ditch Lights Diode Dynamics Stealth Light Bar Kit Dual Circuit Breaker Battery Tie-Down Expedition Essentials Panel Bracket Factor 55 HitchLink Flag Stickers Glove Box Letter Inserts GloveBox Organizer Hella Supertone Horn Kit Icon 1.5 Inch Lift Rear Expansion Pack Interior LED Light Kit Interstate AGM 24F Battery KC Hilites Under Hood Light Krazy Beaver Shovel and Cover License Plate Frames Magnuson Supercharger MAXTRAX Xtreme MAXTRAX Xtreme Mounting Pin Meso Customs Gasshole Meso Customs Vent Ring Kit MESO Overhead HexRack - Sunroof Mishimoto Radiator MMRAD-TAC-16 Nilight 3PCS 60 Inch Bed Light Strip Nitto Ridge Grapplers 285/70R17 Quick Charge 3.0 Dual Charger Socket RedArc Dual Input + 40 Amp Fuse Kit Rhino Rack Stow It Utility Holder Rhino Rack Stow It Utility Holder Rhino Sunseeker 2.0m Awning Rhino USA D Ring Shackles Rhino USA Trailer Hitch Lock RSI SmartCap Evo Sport RSI SmartCap Platform Rack SDHQ Battery Terminal Kit Seven Sparta Grill Led Lights Shift Knob Adapter SmartCap EVO Security Screen - v2 Smartcap MOLLE Panel Steering Wheel Cover Steering Wheel Emblem SumoSprings Front SumoSprings Rear Supreme Suspensions Front Tow Hooks Switch-Pros 9100 Switch-Pros Power Tray Wiring Bundle Tacoma Door Clean Up Kit Tacoma Door Sills Tacoma Lifestyle Sequential Turn Signals Tacoma Tailgate Inserts Tail Gater Tire Table Total Chaos Bed Stiffeners Toyota Cargo Net Toyota TRD Pro Shift Knob TRD PRO 17 Matte Black Alloy Wheels TRD PRO CAI Box & Accelerator TruckVault - Utility Height Uptop Alpha Rack - 38" Extreme LEDs Uptop TracMOUNT Vinyl Letter Decals for Tailgate Handle Vinyl Letter Decals TRD Pro Bedside Vinyl Letter Decals TRD PRO Grille VLEDS Dual Output Front Footwell Kit VLEDS VTAILS Taillight Conversion Kit WeatherTech Bug Deflector WeatherTech Rain Guards Wescott Tacoma Fox TRD PRO Lift Kit
    I've been waiting to pull the trigger on the new Apogee bumpers. Please post a pic after the install. I was holding off because I haven't been able to gauge how far the ends stick out to accommodate the BSM.
    Valkryie21[QUOTED] likes this.
  17. May 26, 2024 at 2:21 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Let’s us know how you like it!
    ljerr2 likes this.
  18. May 26, 2024 at 3:43 PM
    M85
    Colorado
    2019 SR ACLB
    I also built a catch to hold the back window open slightly. There are three adjustable settings. I'll use this mode if it's cold and/or windy and I just want a little ventilation. I'll use the side windows if it's hot or buggy.
    The shell is an ARE.
  19. May 26, 2024 at 3:45 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Brilliant
  20. May 26, 2024 at 3:48 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Do you have any impressions on the seat jackers? I need to do the same, but the price of desert does it is out of my reach. Also, do you have a link to where you purchased them? Thanks
