  1. Jun 2, 2024 at 5:45 PM
    CMan
    CMan Well-Known Member
    Dallas
    2023 TRD OR Red
    Changed the oil and rotated the tires. I figured it was the least I could do after she got me to Virginia and back (from Texas).
    2Dayvid, 23 SR5 LB, spin180 and 4 others like this.
  2. Jun 2, 2024 at 5:48 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    I second this! You like?
  3. Jun 2, 2024 at 6:19 PM
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    :worthless:
    RIX TUX likes this.
  4. Jun 2, 2024 at 6:42 PM
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    So far, yes. I opted not to use the nut and bolt that provided to install the nutserts. Instead, I bought a tool for installing them. Install was pretty straight forward. I had to move my winch battery swich, but overall, everything fits nice.
    Out2gtcha[QUOTED] likes this.
  5. Jun 2, 2024 at 6:43 PM
    Southwest Tacoma
    Southwest
    I'll take a few pics and post them.
    Out2gtcha likes this.
  6. Jun 2, 2024 at 7:18 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    are they led?
    dand likes this.
  7. Jun 2, 2024 at 9:25 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Wanted just a little more rear lift so I swapped out the TRD PRO 1/2" rear lift block for a Wescott 1".
    Hardly noticeable.
    Will post the TRD blocks/ubolts for sale shortly.
  8. Jun 3, 2024 at 2:30 AM
    kylecrish
    kylecrish Well-Known Member
    Cel. Silver 2023 Tacoma TRDOR
    Everything I'm seeing from Goodyear and any online tire site says the Goodyear Wrangler Territory AT is an LT tire. Factory spec for the tire is 30psi. 35 was the lowest I could enter on that site. It's perfectly safe for him to run 32psi on an E rated tire. But once again, everyone can feel free to do their own research. It took me all of 2 minutes to look at a few different sites that show factory info.
  9. Jun 3, 2024 at 3:17 AM
    Fireme
    Fireme Well-Known Member
    Bill
    St.JoMo
    2023 LR DCSBOR
    265/75-16 KO2, 16”trd beadlock, 23 OEM Pro Fox sus, OEM roof bar, seat spacer, sequencing mirror indicators, RC tri fold bed cover, weathertech mats. Homemade bam bed sleeping platform.
    Initially I didn’t like the looks of the KO3, and they didn’t have Raised White Letters, and didn’t offer any in a 16 inch size. Now I see RWL and a 305/70-16 which is way too big for me! I assume eventually they will offer more sizes.
    265/75-16 is just right for my needs
  10. Jun 3, 2024 at 3:28 AM
    Fireme
    Bill
    St.JoMo
    2023 LR DCSBOR
    The 1” OEM lift spacers would have made your wallet less thin in turn making you feel like you’re riding higher! :)
    Also did your factory U-bolts feel like they were not very tight? I added the 1/2” spacers last week and mine were not tight at all on one side and not much more snug on the other side!
  11. Jun 3, 2024 at 6:40 AM
    Rellims
    Rellims Well-Known Member
    Sean
    Denver, CO
    2021 Black Tacoma Trail
    Grill, headlights, tail lights, mirror turn signals, rock sliders, tint, bed cover, fog lights, KDMax tune, interior mods...
    It's 8. Should be fine for what I am going to run through there. Ditch lights, grille lights and amp for now.
  12. Jun 3, 2024 at 6:53 AM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    thanks for the nudge on the air bags, currently doing research on what will work best for my setup!
  13. Jun 3, 2024 at 7:21 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The load rating is SL on the Goodyear site, so not an LT. But it doesn't start with a "P" like in P265/70/R16, so maybe just "metric" and not "P-metric."
    So don't do conversion from OEM using the LT designation, you will get a wrong answer. 32 psi is a little low.
    taco abbo, BC Hunter and oostroma like this.
  14. Jun 3, 2024 at 7:23 AM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    I have had 2 sets of 265 75 16 E load BFG KO2s. I run them at 30psi.
    If I am fully loaded for a trip so up to 1,000 pounds in the back, I will put them at 33psi.
    Off road which is usually weekly, I drop them down to 20-22psi.
  15. Jun 3, 2024 at 7:40 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    I buy bagged mulch and soil also. Usually on sale. Easier to spread, plus I can store bagged mulch for months, as I work on different plants.
  16. Jun 3, 2024 at 7:43 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    But you are in Canada and there is less gravity the further you are from the equator, so you can run lower pressures.
    Seriously, though, there is the technically correct answer and then there is what you want to do. The technically correct answer converts the load capacity of OEM to what is needed for the new tire to handle the same load. I ran 37 psi in KO2's that same size and they wore evenly and were a great tire. But you are free to do as you please and are probably fine running lower or higher.
    doublethebass and BC Hunter like this.
  17. Jun 3, 2024 at 8:16 AM
    Cement Guy
    Cement Guy New Member
    2022 TRD Offroad
    Rubigrid.jpg Installed the Rubigrid.
    andthen, 2Dayvid, -Rorschach- and 5 others like this.
  18. Jun 3, 2024 at 8:31 AM
    CementMixr
    CementMixr Well-Known Member
    2019 Tacoma OR 4x4 ACLB
    Looks so awesome… blue crush metallic is such a beautiful underrated color
    Kolache007 likes this.
  19. Jun 3, 2024 at 10:17 AM
    NlOffRoad11
    NlOffRoad11 Well-Known Member
    Tyler
    2021 Cement TRDOR
    They aren’t Winjet. Seem to be holding up fine so far. The only reason I replaced is because the OEM ones snapped off
    bkhlrTaco's[QUOTED] likes this.
  20. Jun 3, 2024 at 11:35 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    P-Metric is just "Passenger" Metric for passenger cars. I'm not really sure the "P" denotes anything special other than that tires with the P are usually a little lighter than a truck tire.
