  1. Jun 20, 2024 at 4:01 PM
    Gamehenge
    Gamehenge Well-Known Member
    Gunshine State
    2023 MGM TRD-OR DCSB
    Bilstein B8 5100 - Front and Rear. ICON AAL KIT 1.5", ARB/OME 2887 Coil 2", JBA std UCA., FN Wheels F/X Pro 17x8 +0mm, TOYO OPEN COUNTRY A/T 3 - LT265 /70 R17 121S E1 BSW, Overland Tuned,
    Black lugs really sharp!
    BC Hunter and mrabe1979[QUOTED] like this.
  2. Jun 20, 2024 at 4:30 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Looks awesome
  3. Jun 20, 2024 at 7:46 PM
    AV8R Paul
    AV8R Paul Well-Known Member
    Paul
    2022 TRD 4X4 Sport, Long Bed, Blue Crush
    The last thing I did was add a TRD Cold Air Intake. Today I took my truck in for the Rear Axel Recall, and the 10K service, Oil Change, Tire Rotation, etc. When I bought the truck from a local Dealership the Air Pressure in all 4 tires wer 36 PSI. I had lowered the Air Pressure from 36 to 32 in the front and 30 in the rear. On the door it says the Air Pressure should be 29 cold. When I got it back from the dealership from the dealership today, they had them all aired up to 36 PSI. What does everyone run their pressure at. I know it rides better at 32 front & 30 rear PSI
    andthen, 215Yota, -Rorschach- and 4 others like this.
  4. Jun 20, 2024 at 7:47 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    WELCOME TO TW....
    what intake comes on the PRO?
    drizzoh likes this.
  5. Jun 20, 2024 at 7:51 PM
    RIX TUX
    pep boys edition?
    wcoffman and Nadjr[QUOTED] like this.
  6. Jun 21, 2024 at 3:11 AM
    Jcran2
    Jcran2 Well-Known Member
    Middle Georgia
    2016 MGM Tacoma TRD Sport
    Bed Mat, Soft Bed Cover, Weathertech Mats, LEDs throughout interior, 1" Bora Wheel Spacers, OEM Bed Light Kit, OEM Mudguards, Window Tint, Center Console Organizer, Glove Box Organizer
    35
  7. Jun 21, 2024 at 4:59 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    44
    grambo911 likes this.
  8. Jun 21, 2024 at 5:15 AM
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    35
  9. Jun 21, 2024 at 6:03 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    42 front-40 rear but not in oem tires.
    LT 265/70-17
    nevertoomanytacos likes this.
  10. Jun 21, 2024 at 6:07 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I plan on replacing the front door speakers and adding sound deadening too. As much material is added to door, and I know door is closed most of the time, I wonder if anyone has ever had issues with the weight of the door causing problems with the hinge? I've got a box of Siless and that stuff is heavy. Peace and Love.
  11. Jun 21, 2024 at 6:37 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    You need to check the pressure on “cold” tires. Not driven for hours (ideally overnight) so the tires aren’t warm. Then the recommended pressure is a function of your tire type and size. LT tires need more air to support the same weight….seems a bit counterintuitive, but true.
    Gamehenge and -Rorschach- like this.
  12. Jun 21, 2024 at 6:48 AM
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    PSI depends on the type and size of tire really, you’re gonna get a bunch of different answers unless the stock tires are what you’re asking about
    Gamehenge likes this.
  13. Jun 21, 2024 at 7:50 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Intake looks good! I did the same but just use OEM filters.
    If you are running stock tires, use what is on the door placard. If you change tires, here is a good resource for figuring out your starting pressure: Set when cold and at around 70F ambient temperature, out of the sun. If it's significantly colder out, you can drop a psi or 2. Significantly warmer, add one or 2. 36 psi is not terribly far off if the tires are warm.
    Same intake as all the other models. But it comes with the TRD stainless exhaust.
    BC Hunter and 215Yota like this.
  14. Jun 21, 2024 at 8:41 AM
    jkisf
    jkisf Well-Known Member
    JK
    Koreatown Los Angeles
    Stick Shift TRD Pro
  15. Jun 21, 2024 at 11:51 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Looking good! :cheers:
    NormanPerez[QUOTED] likes this.
  16. Jun 21, 2024 at 1:16 PM
    gb_23
    gb_23 Well-Known Member
    Central Alabama
    2023 TRD Sport
    On my previous truck (03 Frontier) I had a layer of dynamat extreme on the outer skin plus spray on dynamat in areas I couldn’t reach to lay mat, 2 layers of extreme on the inner skin and a product they had back then similar to dyna liner, and some spray on on the back of the plastic door panel. I had the truck almost 21 years with out any issue other than the door panel was harder to reinstall when I would remove it. Also I’ll add that when I removed the stereo equipment the dynamat was stuck on just as good as the day I installed it. Sadly my 20 year old Nissan was waayyy quieter than my new Tacoma. Yes I may have went overboard with the amount applied but I ran a car stereo store back then so I tended to go a little crazy sometimes.
  17. Jun 21, 2024 at 2:32 PM
    Tundra24Rnr2Taco
    Tundra24Rnr2Taco OnTacoma#4
    Inland Empire So Cal
    2021 Magnetic Gray Tacoma 4x4 TRD Off Road Dbl Cab
    Replaced stock Goodyear Wranglers with Hankook Dynapro AT2 Xtremes. Stock tires lasted 33k miles. Had Dynapro AT’s on my Tundra and liked them.
  18. Jun 21, 2024 at 2:44 PM
    Gamehenge
    Gunshine State
    I run my Toyo AT3 LT's at 36psi all the way around. It'll rise to 39 warmed up/road trip.
    TacoGeeloor likes this.
  19. Jun 21, 2024 at 2:46 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Installed Subrau Kicker tweeters and the sound is much better than the stock.
    TT005, drizzoh, RIX TUX and 2 others like this.
  20. Jun 21, 2024 at 9:13 PM
    Taco.Tuesday
    Taco.Tuesday Well-Known Member
    New Mexico
    '21 TRD Sport 4x4 DCLB
    Replaced my chrome vent rings with Meso Customs vent rings.
    Miraclejoe, RealTruck, BOMBS and 9 others like this.
