  1. Jul 3, 2024 at 2:21 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Know it well..
  2. Jul 3, 2024 at 2:35 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    It does, it's just not originally designed for the Taco. Same part, different material. Some claim the bypass is different, I looked at mine closely and can't see how it's different. Had mine on for 2 years now and it appears to be working just fine. The bypass is for over-pressure relief, pressure is pressure, no matter what vehicle...and they all run the same oil pressure.
    After the dealer did the first 3 oil changes on my truck, I started doing it myself. The plastic housing shattered taking it off, dealer must've used an impact putting it on. Aluminum would take a lot more abuse before shattering.
    dand[QUOTED] likes this.
  3. Jul 3, 2024 at 3:18 PM
    ericSR
    ericSR Member
    Eric
    Gilroy, CA
    2018 Silver Sky Metallic Tacoma TRD OR 3.5L 4x2
    CVC 3.0 Tuned, 2020+ LED Headlight Conversion, Eibach Stage 1 Lift with 2in Add-A-Leaf, Carven Catback Exhaust, and many more I’ve lost count at this point…
    That’s the exact same part number I purchased as well, it should work as long as you don’t have a JBL system. Just make sure they include the nav box with the HU. I’ve seen some people trying to sell it separately to make more money off of them.
    Concrete_taco likes this.
  4. Jul 3, 2024 at 3:22 PM
    ericSR
    ericSR Member
    Eric
    Gilroy, CA
    Also another thing I forgot to mention. You will need to keep the mounting brackets off your stock unit and swap them over onto the Sienna one so it’ll mount up into the dash.
  5. Jul 3, 2024 at 6:17 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I was trepidatious about fitment before I called my OEM Parts guy in NY...He gave me an OEM answer that the VIN# only lists: 15620-36020.
    It really is up to your own discretion.
    I put them both side-by-side and see they are almost identical.
    The internals are very much the same; spring/valve tension, thread and contact point...the fins are slightly different.
    The center piece stands a little taller...sitting flush with the top of the filter.
    I kept the piece but you can twist it off and swap...I've had no issues leaving it as it was.
  6. Jul 3, 2024 at 6:43 PM
    Fireme
    Fireme Well-Known Member
    Bill
    St.JoMo
    2023 LR DCSBOR
    265/75-16 KO2, 16”trd beadlock, 23 OEM Pro Fox sus, OEM roof bar, seat spacer, sequencing mirror indicators, RC tri fold bed cover, weathertech mats. Homemade bam bed sleeping platform.
    This Anytime locker dealio showed up about last Tuesday, we left for Colorado the day before on its maiden voyage, it was close to *100 in Missouri and we woke up to *40 up on Geneva Creek.
    I knew I didn’t exactly need it for the trails, but I want it more of a want for winter playing! This truck did most everything in 2wd but I was loaded pretty heavy, hitting the bump stops on occasion!
    Ideally a 2wd low would be money better spent, but I’m not springing for the lock out hub kit anytime soon ($,$$$.)
    It was a great trip, but short! Homemade bambed platform, used shell cheap, used tent extension. ($550 total) Colorado scenes priceless!
    Maybe I’ll install the Anytime harness tomorrow?
  7. Jul 3, 2024 at 8:12 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Are those anodized aluminum?
    spin180, Metalskool[QUOTED] and dand like this.
  8. Jul 3, 2024 at 8:34 PM
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    Is this how you're suppose to do it?
  9. Jul 3, 2024 at 8:36 PM
    VTCAL
    2021 Sport
    Careful, People will start thinking you have gone "Electric"........;-)
  10. Jul 3, 2024 at 8:37 PM
    VTCAL
    2021 Sport
    It's good to have a fall back plan!
    Kolache007 and Gamehenge like this.
  11. Jul 3, 2024 at 9:05 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Yes: Kaas Lead Acid Battery Terminal Clamps, Positive and Negative Set, for SAE/DIN/EN Tapered Top Post, 4-Way Connectors, Compatible with 8AWG to 4/0 AWG, includes OEM Top Post Adapter https://www.amazon.com/dp/B0D4X3DYM3
    Seems like an odd material choice for high conductivity.
  12. Jul 3, 2024 at 9:27 PM
    VTCAL
    2021 Sport
    I would be concerned about "dissimilar metal corrosion" Pb-Al
    https://fairwindfasteners.com/blogs/news/galvanic-series-or-nobility-chart-for-dissimilar-metals
    "Keep 'em dressed" is my suggestion
    https://www.idealind.com/us/en/category/product.html/noaloxr-noalox.html
    might be an option
    Desert Guy Bill likes this.
  13. Jul 3, 2024 at 9:54 PM
    Metalskool
    Metalskool Adversity Builds Character
    Michael
    2020 TRD 4WD
  14. Jul 3, 2024 at 10:08 PM
    VTCAL
    2021 Sport
    Did you note the galvanic chart implide .2 V differential?
    Good contact is essential!
    I've got a s "summer sports car" that needs the battery terminals refreshed every spring.
    Metalskool[QUOTED] likes this.
  15. Jul 3, 2024 at 10:35 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    I installed Anytime Camera in my 2023 Tacoma, yesterday. I ordered it from Trail Grid Pro, with pre-wired and soldered for another $30. The hardest part was running wires behind dash, and through the firewall.:D:thumbsup:
    Fireme, RIX TUX, gr8-wrx and 3 others like this.
  16. Jul 4, 2024 at 2:42 AM
    Taco22trdor
    Taco22trdor Well-Known Member
    East Tennessee
    2022 Tacoma TRD Off Road White
    I agree on the Frontier seats. My 87 and 09 Frontier seats, far more comfortable than my Tacoma seats. I still drive my 09 sometimes 363k miles and I don't have to duck my head to get in and the seat is still comfortable.
    Radd[QUOTED] likes this.
  17. Jul 4, 2024 at 5:04 AM
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Yes, it appears you have the fuel nozzle in the correct orifice. Well done.
  18. Jul 4, 2024 at 6:31 AM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    That positive terminal should be covered / shielded.
  19. Jul 4, 2024 at 7:31 AM
    BlueRibbonRM
    BlueRibbonRM Well-Known Member
    2023 TRD OR
    Pulled the truck in the shop yesterday to address the URD y-pipe I installed a couple months ago, I figured I would need to retighten all the hardware but found the rear most clamp wasn't holding the pipe very tightly at all, could actually move the whole rear section of the exhaust up and down, so I pulled the whole thing and used exhaust sealant on all slip in connections before installing it back and securing everything, let it sit and dry over night. Came in this morning and did the 5k service, oil change and rotation along with double checking a bunch of fasteners throughout the truck. Now that the exhaust is better secured and has the sealant it sounds much better, a lot of the annoying resonance I was hearing under heavier load is gone. It still has a bit of an undesirable tone at times but is way better than it was before. I'm willing to live with the tone for the benefits I have experienced with the pipes installed so far, which is slightly higher mpg, easier time getting up hills, and the security of not having cats for someone to steal! Having this exhaust along with the Anderson manifold spacer has made the truck much more enjoyable, now I just need to reach back out to OV tune to see if the lost cable I ordered will ever get resolved, though after 11 months I am guessing I'm screwed and just have to pay for another one. Looking forward to seeing how a tune will improve this further.
    215Yota likes this.
  20. Jul 4, 2024 at 9:01 AM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Good catch! I guess I know what to add to the list. Lol Would you have the Toyota part # for the metal housing? Thanks
    MiTacoTRD likes this.
