  1. Jul 10, 2024 at 2:20 PM
    dmac120
    dmac120 Member
    Dan
    2021 White Tacoma TRD OF
    None
    Got some new tires for my new-to-me '21 OR. Falken Wildpeak A/T3W 265/75R16. Ride quality is much better than the beat Wranglers it came with.IMG_3968.jpg
    akimmel, burnttaco7, RCrumb and 15 others like this.
  2. Jul 10, 2024 at 3:24 PM
    lupercal
    lupercal Well-Known Member
    Portland, OR
    2020 OR DCSB
    I can fit some mega big gulps now.
    Walruss, RCrumb, -Rorschach- and 7 others like this.
  3. Jul 10, 2024 at 3:31 PM
    JS11B
    JS11B Member
    '23 TRD OR
    Installed OEM 1/2" rear spacers today. 1 year ago I installed 5100s & set the front at 1.1". As of now the rear looks 1/2" or so higher than the front, we'll see how it settles.
    jrzjoe, Kcruisin, RCrumb and 10 others like this.
  4. Jul 10, 2024 at 4:09 PM
    TRDBULL
    TRDBULL Well-Known Member
    Corey
    OH
    2023 Toyota Tacoma TRD Off-Road
    Exterior TRD Pro Grill (5) SCS F5 Wheels in matte jet black 16x8 -25mm 6x139.7 (5) Falken Wildpeak AT3W 265/75r16 w/ Road hazard protection on all five tires AVS In-Channel Window Guards Total Chaos bed stiffeners Toyota bed mat Interior Toyota All Weather Mats Neoprene seat covers (front and back) Big cup holder Screen protector Hondo radio knobs Expedition Essentials Dash Mount GFC Camper V1 (Build 125) in Grey Upgraded Embassy hinges Upgraded foam mattress set Beef rack bars (pair) Universal awning mounts (pair) JE Interior locks Overland Softgoods Fleece Fitted Sheet Set in Green GFC ladder kit Shittco awning kit Camper Build Custom fabricated drawer system w/ locking slides and door latch (keyed alike to the camper) Alu-Cab fridge slide Dometic CFX3 45L Ecoflow River 2 Pro power bank (2) Baja Designs dome lights Power Trays Blue Sea 12 circuit kit w/ shut off (2) Wavian Jerry cans in green Rago Fab bed track accessory mounts (pair) Lifesaver jerry can water container/filter Wilco bed mount tire carrier Snail Armor tailgate (2) Ignit 5lb propane tanks
    Nice truck, I’ve got one really similar! F5s with some wildpeaks FTW.
    azhiaziam[QUOTED] likes this.
  5. Jul 10, 2024 at 4:31 PM
    JBoulder
    JBoulder Well-Known Member
    Boulder Creek, CA
    Plasti Dip
    RCrumb, BigEasy, Charlie Too and 7 others like this.
  6. Jul 10, 2024 at 5:56 PM
    NTaco23
    NTaco23 Well-Known Member
    Millington, TN 38053
    2023 TRD Off-Road DCSB Ice-Cap
    WeatherGuard window visor, AlienGear holster, bug deflector, roll-up tonneau cover, direct mount wireless charging phone mount, Pedal Commander, Chrome Delete with Black Badging Covers, Glove Box Lights, Black Exhaust Tip, Black-out Bumper covers, bed mat, bed step, bed rail mounted rod and reel holders, rear diff breather relocate
    Can anyone tell me where the external trans cooler is located on my 23 OR, I know it is listed as a standard feature
  7. Jul 10, 2024 at 7:31 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    My 2017 TRD OR does have one but I thought it was eliminated in later models. Mine is located in front of the rad.
  8. Jul 10, 2024 at 7:55 PM
    JBoulder
    Boulder Creek, CA
  9. Jul 10, 2024 at 8:12 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    in the radiator
  10. Jul 10, 2024 at 11:49 PM
    FranksGotTacos
    FranksGotTacos donkey
    SB
    Denver
    16 DCSB. Geared, Dual Locked, 35s, Topperlift, wet AF
    5.29 gears, ARB locked, Lil Bs front bumper, Hooligan sliders and roof rack, cab and bed cap, Outgear solutions rear bumper, custom swingout. 35's. Icon rebound pros x 5, OME BP-51s. Topper ez lift. Decked. Full RCI full skids, misting system with 4 gal plumbed into 270 ironman awning, air plumbed to all 4 corners + decked, DK upper shear kit, Marlin LCA brace kit, 10 pc rock light kit, scene pods, u bolt flip, stage 3 deavers, poly bushings all around, archive garage hammer hangars, sumo springs rears, TC gusseted spindles, spiker hood struts, aux beam 8 gang, 50 watt solar on top of 2x pelican cases, Cascadia 4x4 mppt solar charge controller, jackery 1000, alpicool 45L fridge. Rear seat delete with fridge slide on passenger side (by me). Meso overhead rack, Meso cab, dome, rear interior lights, Meso x morrimoto tail lights. CVJ high angle boots,
    Been going to battle with the tacoma recently. After fixing the twisted ADD tube off the front diff, still had some vibrations. I found my drive shaft had lost a balancing weight. Picked up a OE spare for $175 from a used part dealer in town with a carrier bearing and popped that in. Gonna balance the old and keep it as a spare.
    Went to reinstall my skids and had 2 threaded holes give up on me, so drilled em out, and welded in a flanged nut to the frame to replace the blown out threads. I also ordered a new TCase skid cross member from RCI bc it was nearly broken in half and touching my TCase. Went to put it in and came up almost 3/4” short. Not sure if this could be from welding deflection at the RCI factory or my frame is bent from the previous crossmember taking such a beating and spreading the frame a tad. Im headed out friday to wheel so I guess I will cut the crossmember at the welds where it kicks up to meet the frame, flatten it out to make it long enough to reach the frame and re weld it, then reinstall it. I might even weld it to the frame- lightly in a way i can easily cut it off when needed.
    you can see in the pics how different they are fresh compared to abused, so tough to say what the problem is. I did take some measurements of the frame, so if anyone without a tcase skid wants to chime in please do
    Under the flag bolt on the driver side that holds the brake line housing (2nd to last pic) : 39-7/16” inside to inside
    Directly behind the frame wrap, where its kinda boxed in, just behind the brake line housing, on the actual frame- not the added steel on top- last pic :40 7/16”.
    I plan on calling RCI in the morning to get to the bottom of it and to check dims/ angles. Chime in if you got time to measure to verify if my frame is a lil tweaked- thanks yall
  11. Jul 11, 2024 at 5:45 AM
    Rellims
    Rellims Well-Known Member
    Sean
    Denver, CO
    2021 Black Tacoma Trail
    Grill, headlights, tail lights, mirror turn signals, rock sliders, tint, bed cover, fog lights, KDMax tune, interior mods...
    KAGU All-Weather mats from 3d Mats. Fit is great, like the look and feel. May still use the OEM ones in the winter but we will see. I do like how they overlap the trim a bit. Will see how they clean up with dirt and dog hair as the first pick was just off my shoes pulling the truck out of the garage for 2 seconds. IMG_5290.jpg IMG_5291.jpg
    JustinFro, spin180, RCrumb and 9 others like this.
  12. Jul 11, 2024 at 7:14 AM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Same on my 2017 Off-Road
    oostroma[QUOTED] likes this.
  13. Jul 11, 2024 at 8:07 AM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    I just received a re call to fix my third brake light. Now that I have already replaced it with the flashing/solid LED.
  14. Jul 11, 2024 at 9:05 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Looks good.. but spacers don't settle lol.
    MDA57, Fireme, RIX TUX and 3 others like this.
  15. Jul 11, 2024 at 9:18 AM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
  16. Jul 11, 2024 at 9:32 AM
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Dreading taking my truck to dealer.
    Took it in for the rear axle weld slag recall. Made an appointment 2 days before, told me on phone it would be a 30 minute inspection. I drove it in & waited. After 1.5 hrs, they still hadn't moved the truck. Called wife to come get me & go to lunch. Called dealer after lunch, it will be a few more hours. WTF? Finally, the call & truck is done. 6 fucking hours & they said my truck didn't need anything except retorque fasteners. Wife drops me off, I get paperwork & they pull truck around. When I went to get in truck, there's 2 deep scratches on driver front door. I go get the service manager, they get the service writer & they review all the pics they took when I brought it in. Said they will contact me in a few days to schedule to bring it in to paint dept. How much time for that? Maybe 2 or 3 days. Celestial silver? Bet that match will be a shitshow.
    I fucking hate dealerships.
  17. Jul 11, 2024 at 10:24 AM
    japjoe7
    japjoe7 Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    That’s infuriating!
  18. Jul 11, 2024 at 10:28 AM
    Sand_In_My_Taco
    NOR*CAL
    Picked up Meso v5s BNIB for 50$
    Sweet deal! Really easy to install as well.
    Ill want the drivers lights, so I'll run the wiring for that this weekend.
  19. Jul 11, 2024 at 10:39 AM
    JS11B
    JS11B Member
    '23 TRD OR
    I'm aware of that CPT obvious, my truck was in the air so I was referring to over all settling, which is normal
    thanks for your concern
  20. Jul 11, 2024 at 12:38 PM
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Hauled 16 x 80lb pavers = 1280lbs total. She was a lil heavy. Was told they were only 40lbs en route to Lowe’s…..was not the case upon arrival to the garden section
