  1. Aug 12, 2024 at 5:20 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    got a chance to drive over speed bumps and other bumps in the roads I would normally notice clicks and didn’t hear anything. Tested different speeds and angles. Seems like it’s a worthy chance for $25 to make the sound go away.
  2. Aug 12, 2024 at 5:29 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Should be. The mag lugs have a slightly different contact cone/head to them than steelie ... run mag lugs on steelies I am told make for wobbly and other bad things.
    BC Hunter likes this.
  3. Aug 12, 2024 at 6:06 PM
    mauctopa
    mauctopa Well-Known Member
    OK thanks.
  4. Aug 12, 2024 at 6:14 PM
    McPickle
    McPickle IG: @ThatTopoTaco
    Dillon
    Central Oregon
    2019 TRD OR DCSB in MGM
    More info on this install??
    Made671 and vettencle like this.
  5. Aug 12, 2024 at 6:42 PM
    Rsully3
    Rsully3 Active Member
    2016 TRD sport QS
    Hello fellow Tacoma owners. What brand/type of rear seat cover are y’all using to try and keep dog hair from getting into your cloth seats? Thanks in advance.
  6. Aug 12, 2024 at 6:54 PM
    vettencle
    vettencle Active Member
    Bakersfield
    23 TRD Off Road DCLB
    Switched out the ol stock OR wheels for the 16” bronze DX4 Beast and reused the stock tires. Nothing fancy, but looks better.
  7. Aug 12, 2024 at 7:41 PM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    This was the dealer installed usb originally mounted in the back of the center console. Power supplied by being tapped into the console storage usb.
    I added the Guild interior AC converter wiring in a new receptacle (including USB-A and C) in the back of the console. Moved the dealer option to the passenger footwell.
    vettencle likes this.
  8. Aug 12, 2024 at 7:47 PM
    RxYoda
    Mark
    Florence, SC
    Oh… also added a dual usb-a and a usb-c receptacle behind the radio trim to power twin RAM-mounted MagSafe charging and HUD gps speedometer.
    (made my own bracket-rough adaptation)
  9. Aug 12, 2024 at 8:01 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    What do you think you're going to lose in ride quality with a lift? If done properly, your ride quality shouldn't change very much. With a bit over 2" of lift, I'm only marginally stiffer over small bumps and I'd argue that the ride is much better over big bumps. Even with the sway bar removed, I have little extra body roll when I maneuver hard. The same goes with the 255/85/16 tires.
    atc250r likes this.
  10. Aug 12, 2024 at 8:59 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    I did that once to my 2021. Way too much work, and the truck didn't work any better after.
    Then I drove it out of the yard and down the dirt road out, and I couldn't even tell.
    A clean windscreen is nice though!
    wcoffman, MrMobile and robin303 like this.
  11. Aug 12, 2024 at 9:53 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    sum beeches
    Scotfree and OldSaltyDog like this.
  12. Aug 12, 2024 at 10:42 PM
    RIX TUX
    i found one with a 10 year old new tire......sorry now its 12 years old
  13. Aug 12, 2024 at 10:47 PM
    RIX TUX
    so if you get a flat on an alum wheel you cant use the steel spare
  14. Aug 12, 2024 at 11:04 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    Does anyone know if Thule makes longer claws for there boxes?
  15. Aug 12, 2024 at 11:16 PM
    RIX TUX
    width may be different
  16. Aug 13, 2024 at 12:20 AM
    AssQuake
    AssQuake Unknown Member
    A.J.
    Washington
    4runner
    Made in Japan
    I have a problem with collecting but I think i settled on a grill i like. SR5/Limited has got to be the best 3rd gen grill ever.
    You can call me Paul Wall
  17. Aug 13, 2024 at 12:22 AM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    Did the install on the NYTOP rear recovery points. It always takes me longer to install items than the estimates. By now I think I am the common factor. NYTOP sent new bolts for the frame tie in but I found that the holes in the recovery piece don’t completely line up with the frame welded nuts. I used three new bolts on each side and one existing bolt. Worked like a champ and is on very solid.
    Also installed the Kuat bed rack about two weeks ago. What a quality piece! I set it to the mid height for now. You can change it to bed height if you what. There is also an option for an enclosed panels kit for short beds only right now. I got mid height Molle panels for each side but haven’t got them put on yet. Kind a work in progress.
  18. Aug 13, 2024 at 4:41 AM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    I'm interested in the NYTOP front points. I'm not sure what you mean about the mounting holes not lining up? Is that a QC issue to be concerned about? How did you have to address this to mount them? Thanks.
  19. Aug 13, 2024 at 5:28 AM
    aCoops2wd
    aCoops2wd Well-Known Member
    Adam
    21' SR AC Utility Package
    265/75/16 Back Rack 15% Tint Around
    Width of the wheel? It measures exact same as the spare essentially. That’s really all they are. Just not OEM Toyota ones because like someone said above I refuse to pay 300 for a single one with an 8 year old tire on it
    jgarverick likes this.
  20. Aug 13, 2024 at 5:41 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    No photos, but just about to hit 500 miles on my regear to 5.29s. A little overgeared right now on 265/75r16, but 33s are next as well as some weight from cap and bumper.
    I can actually use 6th gear now, and it doesn't complain or downshift over ant hills. It's great!
    ClassyTacos, 215Yota and atc250r like this.
