  1. Aug 22, 2024 at 6:05 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Was there a reason to change the PVC or just preventative maintenance? I have 150000 kms on my 2017 TRD OR.
  2. Aug 22, 2024 at 6:41 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I'm installing a supercharger and it was right next to the last plug on the driver side. Cheap part while I'm in there. It did not need changing so I'll throw it in my ultrasonic cleaner and install it the next time I do my plugs
    oostroma[QUOTED] likes this.
  3. Aug 22, 2024 at 7:53 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    From what I remember, there is a concern by some that this can plug up prematurely and cause internal pressure to build up leading to front timing chain cover leak. Don't know if this is true or not but I will probably do the same at 120K kms when I have the plugs changed for peace of mind.
  4. Aug 22, 2024 at 8:25 AM
    CLOUDL1GHT
    CLOUDL1GHT Well-Known Member
    Garrett
    North Houston
    2023 Tacoma SR
    This is the one I purchased and am very happy with. Much more compact than the one sold direct from Softopper and have been very happy with it.
    https://thetoppertent.com/products/mid-size-for-soft-tops
    BoomerGVNG[QUOTED] likes this.
  5. Aug 22, 2024 at 10:16 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Only one is needed for this purpose. :rofl:
    RIX TUX, Taco_mike73 and Spadi_5 like this.
  6. Aug 22, 2024 at 10:51 AM
    suckingdarts
    suckingdarts Well-Known Member
    Jake
    Michigan
    '21 Lunar Rock TRD Pro
    33s, Bed Cap, Eibach Coils, Icon Leafs
    How are the seals around the edges of the tailgate/bed? I would imagine there are a lot of holes that are hard to close up.
  7. Aug 22, 2024 at 10:58 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    You’ll get used to RB look. It’ll “disappear.” I like mine due to its purpose. Maybe adjust it more to the inside…
    rgljr831 likes this.
  8. Aug 22, 2024 at 11:03 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I put this kit on at 800 miles because I found the stock pads inadequate. at 11k miles now. No ragerts.
  9. Aug 22, 2024 at 11:08 AM
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
  10. Aug 22, 2024 at 11:22 AM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    How. This makes so much more sense. Link please
    Jbbarrette and Spadi_5[QUOTED] like this.
  11. Aug 22, 2024 at 11:27 AM
    Spadi_5
    Wisconsin
    2019 DCSB TRD OR
    dand likes this.
  12. Aug 22, 2024 at 12:44 PM
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    The tent material folds over the edges of the tailgate so it is not an issue. There are clips that wrap under the tailgate to cinch it down. On the sides of the bed, it includes velcro strips that work really well to close it all up
  13. Aug 22, 2024 at 12:49 PM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I considered this but to me it makes more sense to leave it as is in case I need to plug something like a compressor in there and just use the push in adapter to usb I already have.
  14. Aug 22, 2024 at 12:52 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Have you had it long, how do you like it? even with having a 6ft bed i could use a little extra room. Had looked at this topper tent or the dac, the added space and to be able to get a little more ventilation is nice.
  15. Aug 22, 2024 at 1:50 PM
    CLOUDL1GHT
    Garrett
    North Houston
    2023 Tacoma SR
    It's fantastic. Have only had it a few months and been able to use it on 2 trips so far before it got way too hot here in Texas but works great. Plenty of room in the short bed for my wife, my dog, and myself to sleep comfortably. Plenty of ventilation with the massive screen under the rain fly.
    andthen, Charlie Too, spin180 and 9 others like this.
  16. Aug 22, 2024 at 2:19 PM
    Spadi_5
    Wisconsin
    2019 DCSB TRD OR
    I had a flush mount rapid charger in the socket for about a year and it worked great but I wanted something solid in there and have never used it for anything but charging phones and such. If I ever had a need to run a 12v accessory I may install one in the bed.
    atc250r[QUOTED] likes this.
  17. Aug 22, 2024 at 3:00 PM
    RealTruck
    RealTruck Well-Known Member Vendor
    Great video! It was definitely interesting to see how the Tacoma performed out there in real time. The slow movement was mesmerizing to watch!
  18. Aug 22, 2024 at 3:25 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    Since the engine in the Gen. 3 is a combination of direct and port injection there is going to be gunk building up on the valves.
    Direct injection engines are very well known for "gunking" up the valves.
    Changing the PCV valve is a great preventative maintenance task.
    Cheers
  19. Aug 22, 2024 at 3:42 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Changed my brakes, rotated my tires, replaced the brake fluid, cleaned suspension components, and sprayed everything with mavcoat.
    Toyota OEM pads/fluid used
    Probably could have gotten 5-7k more miles, but today was nice, I had off work, and I got it done before it gets cold and I don't feel like wrenching.
    D-knoww, atc250r, ClassyTacos and 7 others like this.
  20. Aug 22, 2024 at 4:01 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
