  1. Aug 25, 2024 at 7:44 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    For anyone else having smoke issues try Ozium. Took care of the stale cigar smell left in my truck courtesy of an agriculture/livestock inspector in Patagonia.
    Shit smelled like almost burnt French toast, the rotting grass you scape out from under the mower, and dried cow shit for like a month even with windows open, air freshener, you name it.
    Wife got sick of hearing me bitch about it every time I called and sent some Ozium down. Glad she did.
  2. Aug 25, 2024 at 8:19 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Ozium is one thing I looked into. It was a lot more pricey at retail and for some reason around me they only sold tiny cans of it in stores. It was available at that place with the world's biggest selection in a larger size. I just opted for the meguairs product mostly for the delivery method in to the vents. The vents seemed like where I could still smell it with the AC on and windows closed, even though I always smoked with a window down. I could set it off the Maguires product and let the AC system pull it in. With Ozium I'd figure id have to spray it in the recirculation intake while in the cab with it going. Knowing my luck it would probably blow it out in my face.
  3. Aug 25, 2024 at 8:43 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    Replaced my tailgate panel with a 15” x 55” sheet of 1/4” King Starboard HDPE. Installed rivnuts and 1” 1/4-20 SS button head bolts for the lower section, and used a forstner bit to countersink them. Also had to trim 1/8” off the 2 rubber bump stops for the tailgate to close properly.
    now I can put my beer down and not have it fall over sheet of HDPE was $60 from a local marine shop in town. $10 on hardware and $20 for the rivnut tool.
    2Dayvid, portorawk, Spadi_5 and 22 others like this.
  4. Aug 25, 2024 at 9:04 AM
    MGMDesertTaco
    Amazon?
    I use this to clean the ac coils and then follow up with the big can of ozium. Not for smoke, but just regular cleaning. Seems to work well.
    https://www.amazon.com/nextzett-961...44&sprefix=ac+car+cleaner+foam,aps,145&sr=8-2
  5. Aug 25, 2024 at 9:10 AM
    Taco_mike73
    York, PA
    MGMDesertTaco[QUOTED] likes this.
  6. Aug 25, 2024 at 10:37 AM
    Jacoma77
    Jacoma77 Well-Known Member
    Jay
    NJ
    2017 Tacoma TRD Sport
    Installed my BHLM custom headlights from Kevin @no vtec 4me today. The pics don’t do them justice. Kevin installed DD switchback halos, smoked turn signal covers, and smoked clear side markers. Kevin improved my OEM headlights beyond my expectations.
    Jerry311SD, NateJ, Robskino and 22 others like this.
  7. Aug 25, 2024 at 11:11 AM
    PTSDTherapy
    22 SR5 DCSB
    I started the truck turned on the air on recirc got out closed the drivers door opened the rear drivers door sprayed for 20 seconds and closed the door and let the truck and ac run for about 5 mins. Took two times of that to kill the smell.
  8. Aug 25, 2024 at 11:30 AM
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    Changed out the Rear Diff oil for the first time on this vehicle. I didn't see any metal shavings/glitter in the oil or on the magnetic plug, just slug.
  9. Aug 25, 2024 at 11:39 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    What products do you use for deodorizing? I have an older 1988 Subaru that had sat for a bit and I don’t want an over chemically smell but it has a musty smell I just can’t seem to get rid of no matter how many times I’ve cleaned and shampooed it. It’s had it since I bought it a few years ago. Might just be baked in at this point. THANKS!
  10. Aug 25, 2024 at 11:40 AM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    This is on my list to do soon. I’m at 49k and due for an oil change in about 2k, might just do it then.
  11. Aug 25, 2024 at 12:41 PM
    BassFisher887
    BassFisher887 Well-Known Member
    Near Chadds Ford PA
    2023 Tacoma TRD OR AC
    Basic 15k mile maintenance; oil and filter change and tire rotation. Used the Motivx tools, which are very nice.
    Took the opportunity to install a Fumote valve 133S. I wasn't thinking about it being brass, torqued it down, and this happened.
    Luckily I was able to extract the broken off nipple from the pan without damaging any threads using an extractor. I had purchased two Fumoto valves, as I planned to put one in the Highlander. I installed the second valve hand tight and then a quarter turn to snug it down.
    Now I need to go find another Fumoto to use for the Highlander.
    andthen, drizzoh, VatoTaco623 and 4 others like this.
  12. Aug 25, 2024 at 12:45 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Advice I read to install my Fumoto ... hand-turn to tight, then use wrench for 1/4 turn more. Torque was not on my list of tight-check.
    TacoTime55 likes this.
  13. Aug 25, 2024 at 1:49 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Looks great. To be honest I don't remember exactly how the OEM attaches, but couldn't you have used the stock mounting locations? I have wanted to do this not just for a beer to not tip but if I climb on the tailgate to get someone out it doesn't hurt so bad on the knees, and then finally as a flat surface while camping.
    2Dayvid likes this.
  14. Aug 25, 2024 at 2:06 PM
    Nevada Mike
    Nevada Mike Well-Known Member
    Michael
    2022 Silver Tacoma TRD Off Road
    I took it camping and broke the tires in on the dirt roads. I wasn’t at high enough elevation to get any snow, just rain. So far I’m liking the new tires over the original ones. Better grip off-road and better manners on road over the Goodyear AT’s that came on it. The new ones weigh more, but also have a higher load rating. The original tires were SL rated, but the new ones are E rated. A bit too much for the Tacoma, but for stock size I only had the options of SL, XL, and E. I would have been happy with C rated if it was offered in the size, but anything less wasn’t an option for me.
  15. Aug 25, 2024 at 2:28 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Same here. He does nice work. It's the only modification that I really didn't want to DIY. I'm glad I had him do it. Professional job, no leaks, looks OEM.
    Jacoma77[QUOTED] likes this.
  16. Aug 25, 2024 at 3:21 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Dang!
    I did not torque my Fumoto.
    Hand tighten then 1/4 turn.
  17. Aug 25, 2024 at 3:55 PM
    Tlaloc1916
    Tlaloc1916 Well-Known Member
    Magnolia Tejas
    2021 SRish 4x4
    Dang. At what mileage was thiis. I changed mine at 80ish and didn’t look like that. o_O
    -Rorschach-[QUOTED] likes this.
  18. Aug 25, 2024 at 4:03 PM
    aarcarr
    aarcarr Well-Known Member
    Arizona
    23 Tacoma TE | 18 4Runner SR5
    08 4Runner SR5 sold 03 Tacoma TRD sold
  19. Aug 25, 2024 at 4:22 PM
    Tlaloc1916
    Magnolia Tejas
    2021 SRish 4x4
    Hearing all the issues with the new Tacos and watching RobMotive vids. I’m glad I’ve kept mine.
    2Dayvid, Shiro213, 2k2 and 5 others like this.
  20. Aug 25, 2024 at 4:28 PM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    Cool new patch…
    Kbar, sphinxbccp, andthen and 8 others like this.
