  1. Aug 26, 2024 at 6:11 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Depending on the depth you might be able to put the stainless steel cup holders in like we have in our boat.
    https://a.co/d/iImjtjn
    BoomerGVNG likes this.
  2. Aug 26, 2024 at 7:08 AM
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    Low actually, just under 12,800 miles. Well below the Toyota recommended 30,000 for normal driving.
    I had heard that factory fill was often a little low due to the various diffs they put in. A little less than 4qts came out of a 4.2qt diff, with a long drain time.
    I was disappointed with the quality of oil that came out considering its lack of abuse.
    I'm in the process of going through and checking/changing out all the factory oils as a precautionary measure.
    musicisevil likes this.
  3. Aug 26, 2024 at 7:12 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Have not set it up yet, but found a right line gear tailgate canopy on clearance at fleetfarm last night. Should make a good addition for tailgating for my daughters dance team.
  4. Aug 26, 2024 at 7:17 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Would you want them draining into the tailgate though?
  5. Aug 26, 2024 at 7:25 AM
    atc250r
    Orange County, NY
    Is not hard to either seal the hole or use the fittings they come with that accept plastic pipe to drain them externally like you're supposed to on the boat. :thumbsup:
  6. Aug 26, 2024 at 7:30 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    long island
    2022 TRD SPORT DCSB
    i would be getting the solid bottom, no drain. There's enough room for the deep/standard style cupholder, but I will likely get shallow ones. easier to clean out.
  7. Aug 26, 2024 at 7:49 AM
    Rellims
    Rellims Well-Known Member
    Sean
    Denver, CO
    2021 Black Tacoma Trail
    Grill, headlights, tail lights, mirror turn signals, rock sliders, tint, bed cover, fog lights, KDMax tune, interior mods...
    No today, but yesterday some early morning trail action. Great views. IMG_5776.jpg IMG_5774.jpg
  8. Aug 26, 2024 at 9:30 AM
    hoytshooter1
    hoytshooter1 Well-Known Member
    Cave Creek, AZ
    2020 DCSB
    ICON's Method's w/265-70-17 (Gone) '16SR5 Wheels with 255-85-16 Falken MT's AZ pinstriping
    153!!
    VatoTaco623[QUOTED] likes this.
  9. Aug 26, 2024 at 10:26 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    This weekend I strengthened the joint of my tailgate auto lock by adding a cotter pin. It was always jumping off that little nub.20240825_185306.jpg
    RCrumb, ClassyTacos, spin180 and 4 others like this.
  10. Aug 26, 2024 at 10:28 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    This screw must be cemented in, 2nd or 3rd tool I've broken trying to loosen it. 20240825_190402.jpg 20240825_190416.jpg
    RCrumb, spin180 and andthen like this.
  11. Aug 26, 2024 at 10:37 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I have learned from disassembling several laser printers with 100s of tiny screws that you should try tightening 1st in order to break the seal on the bolt or screw.
  12. Aug 26, 2024 at 11:28 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    I hit mine with a 3/8 impact and it came off after a couple seconds. Sometimes impact is better than constant torque.
  13. Aug 26, 2024 at 11:44 AM
    EvlFlash
    EvlFlash Well-Known Member
    Utah
    2023 Tacoma TRD OR 6MT
    Took care of this nanny "feature"
    The mock up
    And the install
    Have the disc on the way for the final mod but no leaks so far on the line and the clutch engagement is sooooo much smoother now.
    RCrumb, drizzoh, ClassyTacos and 6 others like this.
  14. Aug 26, 2024 at 11:59 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    Always seems counter productive but in my aviation maintenance career I’ve found this to be very useful
  15. Aug 26, 2024 at 1:02 PM
    5nahalf
    Erik
    Minnesota
    Got the canopy setup to test and figure out the best ways to put it together each time. Not too bad for $40. Its designed for open beds without a topper, but seems to work just fine with the topper too.
  16. Aug 26, 2024 at 1:35 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yes I used an impact gun.
  17. Aug 26, 2024 at 1:35 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I will try
  18. Aug 26, 2024 at 2:05 PM
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Get one of these best way to remote it, you hit the back with a hammer. It really helps with breaking bits or rounding bolts. I only used mine 3-4x but they are a lifesaver
    https://www.amazon.com/Extractor-12...s=hammer+impact+driver&qid=1724706246&sr=8-17
    Evostaco, gr8-wrx, oostroma and 2 others like this.
  19. Aug 26, 2024 at 4:05 PM
    gb_23
    gb_23 Well-Known Member
    Central Alabama
    2023 TRD Sport
    Was your torx bit rated for impact? Non impact sockets are much more likely to break on a impact.
    RIX TUX likes this.
  20. Aug 26, 2024 at 4:27 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    It was not. But it lasted a few minutes while in service. :notsure:</WhereIsBigHammerGuyIconWhenYouNeedHim?> You know, everything looks like a nail when your only tool is a hammer? Hahah.
