  1. Sep 6, 2024 at 10:11 AM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    I'd heard about this dust issue early on so I used an extra ear bud adaptor cut at an angle to create a 'boot' to keep dust out. It seems to have worked so far. And I obviously need to clean the panel (why does every speck of dust show up in pictures).
    Since I don't have the tools or skills to mod my suspension or wire up fancy electronics like most of you, I get to spend my efforts on these more trivial bits.
  2. Sep 6, 2024 at 10:12 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Try compressed air.
  3. Sep 6, 2024 at 12:36 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    Simple but genius. Now looking for an old set of ear buds.
    17taconut and musicisevil like this.
  4. Sep 6, 2024 at 1:42 PM
    tmcarpen
    tmcarpen Member
    Travis
    Noblesville, IN
    2018 Black TRD OR DCSB
    I installed an Auxbeam panel in my truck a few weeks ago and didn't really like any of the options that I had for where the accessory wire would connect. Using the add-a-fuse either the system would be always on (good for when I want to use some of my lights around camp while the truck is off, bad for long term), or only on when the truck is running. Decided to install a 3-position SPDT switch that I could select between the two options, and then spent some time modeling and 3D printing an insert that the switch could drop into to live in one of the empty spaces. Best of both worlds!
  5. Sep 6, 2024 at 4:20 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Thanks for the follow-up! Yes, even if the company truck (V-2) was deemed ‘at fault’, the blue Hyundai’s (V-1) speed was likely a ‘contributing factor’. Glad you are being covered and hopefully minimal out-of-pocket on your end.
    More inspiration to get my front and rear cameras installed! :thumbsup:
    thomasburk likes this.
  6. Sep 6, 2024 at 4:37 PM
    Walruss
    Walruss Goo Goo G'joob
    2022 Ryobi Pro
    FitcamX Zprecision cup holders
    dleriche, E.T., OldSaltyDog and 10 others like this.
  7. Sep 6, 2024 at 5:05 PM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    I just put 15 gallons of premium fuel into the tank! :thumbsup:
    TacosMan, MGMDesertTaco and atc250r like this.
  8. Sep 6, 2024 at 5:55 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    New pads and rotors at 77k miles
    Oil change also. Wash n wax
    kas2828, drizzoh, TVphotog97 and 15 others like this.
  9. Sep 6, 2024 at 7:41 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    2k2, MGMDesertTaco, Scotfree and 5 others like this.
  10. Sep 6, 2024 at 8:44 PM
    Taudelta
    Taudelta Well-Known Member
    Iurii
    South Florida
    2023 Tacoma Trd OR
    Steelcraft Fortis front bumper, BodyArmor 4x4 rear bumper, LIft: Bilstein 5100+2885 OME coils, Icon RXT 3 stage. 255/85/16 wildpeak at4w
    Finally changed tires to pizza cutters, Falken WildPeak AT4W 255/85/r16
    No rubbing anywhere.
    How it was before
    How it is now
    tollster64, 2k2, burnttaco7 and 8 others like this.
  11. Sep 6, 2024 at 9:32 PM
    MGMDesertTaco
    What kind of pads and rotors? :popcorn:
  12. Sep 7, 2024 at 1:06 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    OEM wiper blade insert replacement. Thanks CCN for the tutorial. I really like the OEM blades and replaceable inserts. First set lasted almost 4 years.
    tollster64, MAS, Seymootaco and 17 others like this.
  13. Sep 7, 2024 at 2:06 AM
    cricket1116
    cricket1116 Mediocre Triathlon Enthusiast
    Robert
    2019 SR - TSS Package
    Is this stock suspension?
  14. Sep 7, 2024 at 5:04 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    You're both right here. You can definitely force an upshift by sitting in a lower gear revving high and moving the shifter into the next higher gear. It will go.
    And yes, it's mostly suggestions as there is no mechanical connection from the shifter to the gears. You are just playing within the pre set calcs.
    Interesting scenario on the mountain passes. If you're revving high in 2nd there is a limit to which it can not drop into first. The ECU will no let you go into first. So far, in my exxpierecnce that has been the only scenario where the pre set calcs have stoped the driver input.
  15. Sep 7, 2024 at 7:40 AM
    Desert Guy Bill
    Desert Guy Bill Member
    Phoenix
    2023 SR5 AC AT 4WD
    why premium?
  16. Sep 7, 2024 at 8:24 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    Stoptec rotors
    Auto zone gold lifetime warranty pads.
  17. Sep 7, 2024 at 8:56 AM
    Rsully3
    Rsully3 Active Member
    2016 TRD sport QS
    Cleaned her up real nice!! For a 2016 she’s still looking pretty!!
    CenCal805, NateJ, TT005 and 27 others like this.
  18. Sep 7, 2024 at 9:12 AM
    winnipegbeachtacoma90
    winnipegbeachtacoma90 Konto wird nicht mehr verwendet
    Looks great, what’s your setup? I’m looking to build mine up soon
  19. Sep 7, 2024 at 9:25 AM
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    This is freaking brilliant, and I'm embarrassed that I did not think of it.
    Looks like a nice print as well.
  20. Sep 7, 2024 at 9:34 AM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Yep. Mine’s a ‘20 too and still running the OGs. I watched that vid a while ago and CCN recommends replacing inserts every 6 months. The guy is good and inserts are relatively cheap but every 6 months, I don’t think so. I will replace mine before winter to be proactive.
