  1. Sep 16, 2024 at 3:58 AM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    Welcome.
  2. Sep 16, 2024 at 4:16 AM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    K9tacoma and Spadi_5 like this.
  3. Sep 16, 2024 at 5:27 AM
    Danner488
    Danner488 Well-Known Member
    2016 TRD Sport
    You'll probably need a bunch of little parts. Toyota sells the parts a la carte and not as a kit. I bought a used OEM tonneau for $150 and spent close to $200 for parts. The dealership wanted almost $8 each for the 64949-04010 bolts, so I sourced them from a local hardware store. For the other items you're probably going to have to go to a dealership.
    You don't need part 64933C. Mine broke off and the cover is fine without it. It protrudes into the bed and just takes up space.
    Also take note that the front passenger bracket, although it has the same part number 69391, is different than the other five. It has "NO.2: as a suffix and the other are "NO.1".
  4. Sep 16, 2024 at 6:10 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I prefer no hoops.
    burnttaco7, andthen, spin180 and 6 others like this.
  5. Sep 16, 2024 at 6:13 AM
    -Rorschach-
    -Rorschach- The Black Helicopters are coming…I gotta go!
    2019 Silver Sky Metallic Tacoma DCLB TRD OR 4x4
    Hoops!
  6. Sep 16, 2024 at 6:17 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Skewp and a hoop? Too much? Idk, I think skewp and a hoop and next thing you know someone hangs their panties off your rear view.
  7. Sep 16, 2024 at 6:56 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Say what?
  8. Sep 16, 2024 at 6:58 AM
    Danner488
    2016 TRD Sport
    You will have to cut out spots in plastic top rails for the 693914 brackets. I marked my rails with a silver Sharpie then pulled them off and cut it with utility knife.
    InfernoTacoCO[QUOTED] likes this.
  9. Sep 16, 2024 at 8:36 AM
    habaneroTrd
    habaneroTrd Well-Known Member
    2018 Tacoma Trd OR DCSB
    I love the hoop look and would have purchased that look had I got it new, buttttt I got it on marketplace for like a third of the cost and it was brnd new so no complaints. still need to mount my winch
  10. Sep 16, 2024 at 10:21 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @BraskaTaco,
    The new front bumper looks fantastic! I really like how the hoop complements the overall design. Adding LP6 lights to the center section would be an excellent choice, giving you a top-notch lighting setup. Whenever you're ready to upgrade the lighting whether for the front or rear just shoot me a PM, and I’ll be happy to help fine-tune the perfect package for you.
    Best,
    Bill
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.com Phone: (760)560-2252
  11. Sep 16, 2024 at 12:25 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  12. Sep 16, 2024 at 12:27 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
  13. Sep 16, 2024 at 12:39 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I do I do.
    Here is what I got, I would go with darker color if I had to re-order, because even this material reflects brightly when the sun hits it just right and that reflection is then reflected in the windshield.
    https://www.shearcomfort.com/
  14. Sep 16, 2024 at 1:35 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    How do you like that material? I ordered swatches and one of them was that material. I’m partial to the carpet look
  15. Sep 16, 2024 at 4:55 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    I see a big difference between the two: the cheap ones connect only to the bottom of the non-structural cross member, and the ones @ljerr2 used go up higher with through bolts and may indeed connect to the frame.
    That said, I don't own either product and can't verify exactly how they connect, but think we should give the OP some room for making a rational decision.
    BC Hunter and JBoulder like this.
  16. Sep 16, 2024 at 5:00 PM
    RIX TUX
    the ARB uses 5 bolts and cost less than the OP's and is really the only upgrade to the OEM but to each his own
  17. Sep 16, 2024 at 5:30 PM
    JBoulder
    JBoulder Well-Known Member
    Boulder Creek, CA
    3 bolts per side?
  18. Sep 16, 2024 at 7:53 PM
    ljerr2
    Iowa
    2020 Tacoma TRD Pro
    Just 2 bolts per side. They are an improvement over demon shackles, probably a slight improvement over the OEM off-road hook since the bolts are in 2 different planes, plus they give you shackle options. I understand they are not ARB-level by any means. I never liked the approach angle that seems to be affected with the ARB point, even if it's just aesthetics, but I understand it's not even close to comparing apples to apples with the ARB "true" recovery point and the NYTOP "recovery point" (maybe better classified as an enhanced tow point). I also like having a "point" on both sides of the truck, although a bridle is still recommended. I still view it as an upgrade over stock and allows soft shackles for downward driveway pulls. Or hopefully, sufficient strength for the potential ditch pull/snow pull that would be more likely something I will face. No mud bogging or heavy recovery operations are in my future with this truck.
    17taconut, VTCAL, musicisevil and 2 others like this.
  19. Sep 16, 2024 at 8:58 PM
    G_W_Chonkr
    G_W_Chonkr Well-Known Member
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
    Took the DIY Wedge on the maiden voyage all through West Idaho last week. Stopped by 13 state parks and did a touch of wheelin. Overall the setup did well and only have to smooth a few things out. Temporary Electrical setup worked like a charm and only burned 1, 4aH dewalt battery over 5 days.
  20. Sep 16, 2024 at 9:13 PM
    MGMDesertTaco
    I need to know a little more about the dewalt battery power setup. Do you have a write up or link? :popcorn:
