  1. Sep 30, 2024 at 5:58 AM
    D-knoww
    D-knoww D-Know
    Washington state
    2019 Tacoma TRD Sport Longbed
    Damn! Nice job.
  2. Sep 30, 2024 at 7:27 AM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    AwesomeLaw68[QUOTED] likes this.
  3. Sep 30, 2024 at 9:08 AM
    PresidentDwayneCamacho
    PresidentDwayneCamacho Member
    Scott
    2018 TRD OR 6MT
    BAMF Plate bumper, Dobinsons MRR F/R, Dobinsons springs, Kenda Klever RT 35/10.5r17 on KMC 725’s, 5.29 gears.
    Nicely done, looks like a good day of projecting. Next time when you try to remove the CV’s by yourself, after you remove the hub end, take a piece of paracord and run it through the UCA. Then tie it in a loop and put the CV through and rest the axle shaft on the paracord. That has worked well for me when removing them solo.
    huckyourmeat[QUOTED] likes this.
  4. Sep 30, 2024 at 9:16 AM
    huckyourmeat
    huckyourmeat Well-Known Member
    Denver, CO
    19 TRD OR DC Silver
    Redline QL Plus hood struts, seatbelt chime off, cupholder mod, LED interior and license plate lights, Fumoto oil drain valve, Leer 100XR Mile High Edition, Kicker/tweeters, Kicker Key, Anytime + front camera, ECT anytime, 6112s (10/8), 5160s, Icon RXT (Stage 2, may drop to 1), Qi delete/dash pocket mod, TRD skid plate, alloy filter housing.
    Thanks for the tip... I'll give that a try. I tried a couple of other things to no success
  5. Sep 30, 2024 at 9:42 AM
    Rellims
    Rellims Well-Known Member
    Sean
    Denver, CO
    2021 Black Tacoma Trail
    Grill, headlights, tail lights, mirror turn signals, rock sliders, tint, bed cover, fog lights, KDMax tune, interior mods...
    Mountain States
    MrMobile[QUOTED] likes this.
  6. Sep 30, 2024 at 10:34 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes, Thanks.
    thomasburk[QUOTED] likes this.
  7. Sep 30, 2024 at 10:34 AM
    Canadian Caber
    Les
    B.C. Canada, eh
    Thank you.
    thomasburk likes this.
  8. Sep 30, 2024 at 10:42 AM
    huckyourmeat
    Denver, CO
    19 TRD OR DC Silver
    Got my alignment done today. I asked the tech to shoot for 0 camber, 0.02 toe, and as much caster as possible up to 3. He tried pretty hard, but wasn't able to get caster above 1.7 and even that required 0.5 camber.
    All good, I pretty much expected this since I chose to gamble and not do UCAs at this time. All values are still within OEM spec, so I'll drive it for a bit and then decide on UCAs. Also maybe things will improve a bit after everything settles.
    Flori-duh Taco likes this.
  9. Sep 30, 2024 at 10:43 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    My caster is in the same neighborhood IIRC and the truck doesn't drive bad at all.
    huckyourmeat likes this.
  10. Sep 30, 2024 at 10:49 AM
    myothertruckhas18gears
    myothertruckhas18gears Active Member
    23 trd off road auto access cab
    bilstein 5100s, eibach 1" lift blocks, baja designs fog lamps, mori moto HID bulb conversion, bed stiffeners, rear seat delete, 17" 4runner rims powdercoated, 255/75r17 dualers, trail edition grill, blacked out badges, decal delete.
    IMG_0477.jpg IMG_0640.jpgSo a while back I posted that I mounted a 400w solar panel on my canopy. Up until now it’s just been decorative. But today I finally got a chance to test it out with my new power station. It was charging slowly due to cloud cover but it WAS charging so that’s the main thing. Also I can verify that the solar panel has held up well without any signs of damage after being up there for several months and been through a fair bit of rough terrain.
  11. Sep 30, 2024 at 3:35 PM
    8ighty9ine
    8ighty9ine Well-Known Member
    Took her fishing
  12. Sep 30, 2024 at 4:26 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Very nice!
  13. Sep 30, 2024 at 5:03 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Saw this todayIMG_1811.jpgwiped it clean, can’t find a crack or hole. Also messing with my bed rack moved my lights, IMG_1813.jpgthey used to be up top and under, ultimately in the way. And then there’s this tray that I’ve got working here. IMG_1812.jpg
  14. Sep 30, 2024 at 5:04 PM
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts Cooper S/T MAXX 255/85/16 Body Armor Sliders
    Swapped out my Push To Start Button.
    Overall, pretty simple, though I’m not proud of how long it took me to get the chrome trim ring back on. :anonymous:
    Dam325, RCrumb, spin180 and 5 others like this.
  15. Sep 30, 2024 at 5:09 PM
    r_ben65
    r_ben65 Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue 270 degree XC awning, Four Wheel Campers Project M, CBI Baja Front Bumper, Warn VR EVO 10S winch, Baja Design OnX6+ 20 inch LED Light Bar, WeBoost, Diode Dynamics SS3 Ditch Lights, Prinsu Pro Roof Rack with Heretic 6 series 40 inch light bar
    Used the truck as a relief point/lunch table/command center for a refuel point for hospital employees.
    We were asked to assist another hospital in our corporate system. So right I'm just pulling security for the tanker truck of gas.
    I'll be down here for a couple more days.
    Augusta Ga got hit pretty hard,
    MAS, spin180, andthen and 18 others like this.
  16. Sep 30, 2024 at 6:22 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Your inspiring me to do mine, I am in the Fraser Valley. I do have some rust on the welds. Apparently WD40 brand also has a new rust inhibitor spray, so far I haven't seen it anywhere
  17. Sep 30, 2024 at 6:33 PM
    BornaBurden
    BornaBurden Active Member
    Raymond
    Sonoma County
    2022 SR5 4x4
    17" Pro Sema Wheels & Tires, TRD Skid, OTT Tune (mild), ROKBLOKZ mud flaps, Cali raised Rock Sliders, Bilstein 6112/5160 w/ Bilstein UCA's, Tiger Tough seat Covers + BAM molle truck bed systems. Carhartt dash cover, Diamondback Switchback bed cover, Other cosmetic gems
    This is the latest mod. I should have made it my first mod. Excellent. Thanks again Daniel.
    scouterjan, spin180, andthen and 2 others like this.
  18. Sep 30, 2024 at 7:21 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you can get just the pipe at k/n
  19. Sep 30, 2024 at 7:45 PM
    Raku77
    Raku77 Well-Known Member
    Daoud
    2017 Toyota Tacoma TRD
    Nothing crazy!
    Put mud flaps on C4 rear bumper. It’s growing on me. I think I’m in the “I’m old and I don’t give a s$&t era” .
    Road Bull, BOMBS, spin180 and 16 others like this.
  20. Sep 30, 2024 at 9:45 PM
    Canadian Caber
    Les
    B.C. Canada, eh
    I was uncertain with what undercoating to use. I did notice the new WD40 product but leaned towards products that have been around a while. Cost and availability on those products were a consideration. Hamazon was the main place of purchase. Being that we don't get hit with the salt as bad as the rust belt I decided on the cosmoline type undercoating. Leaves a waxy type surface when dried. Hopefully it lasts a long time. Didn't really want the more runny Fluid film. However, I did by one can of Rust Cure Formula 3000 from Canadian Tire to spray the chain and lifting mechanism for the spare tire. It was cheaper that Hamazon. Not sure I wanted wax type rust inhibitor for those moving parts. The Rust Cure is more Fluid Film like.
    With everything looking pretty good under there, a damp pre-clean, prepping and covering existing surface rust with Tremclad rust inhibitor, then the CRC, it's like a having a mint undercarriage again. Now with the benefit of enhanced rust resistance. I have piece of mind on those sloppy, salty road days where I don't have to worry where all that salt is getting into. I will still take it through the touch-less car wash and pay and spray to help keep the salt down in the middle of winter tho. Out your way the valley does get hit a little harder.
    I will really have to monitor long term results as this is surface only. Not removing plugs and getting into spraying all voids like they do in the rust belt. This is more like lipstick.
    Be interesting to see how it all held up with salt spray when driving this winter.
    Not sure if there are even any companies around us that offer this service. Does not seem common around here. This is all new to me. Bit of an experiment as I'm learning as I go. I think it's worth it if you plan to keep your truck long term. I didn't want to kick myself after 10 years thinking I should have done this sooner or even better when the truck was brand new. At least I have a baseline now of 4 years moving forward.
