  1. Oct 1, 2024 at 8:46 PM
    Tulsa Taco
    Tulsa Taco Well-Known Member
    Brennon
    Tulsa
    2020 TRD OR
    Ah. I like the way they look but my next tire will be 3 plies.
    Inyo_man likes this.
  2. Oct 1, 2024 at 8:48 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Right front edge tip to left edge tip hood looks lined up to front fenders, how are you thinking to adjust it?
  3. Oct 1, 2024 at 9:14 PM
    PainterVern
    PainterVern GoatRoper
    Vernon
    Reno Nv
    19’OR
    A few things….
  4. Oct 1, 2024 at 9:16 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    10-4..... ill honk if i see you by 285
  5. Oct 1, 2024 at 9:23 PM
    Mlofthou
    Mlofthou Well-Known Member
    Mason
    2021 tacoma
    For sure! Good eye on ya. I took the pic before I finished torquing things down. Definitely a noticable difference off-road, felt much more planted. Took it for a desert run this afternoon.
  6. Oct 2, 2024 at 5:18 AM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    The 6112 is still in my list of possible setups to get. How does the 6112 ride on the highest clips? I had read some say it rides harsh and other say it rides fine, was just curious on your personal opinion.
  7. Oct 2, 2024 at 9:44 AM
    Tulsa Taco
    Brennon
    Tulsa
    2020 TRD OR
    Thats a good question. Not sure yet. The gaps to the fenders are close enough not to mess with so I’m thinking of just somehow working on the front edge somehow.
    thomasburk[QUOTED] likes this.
  8. Oct 2, 2024 at 10:13 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Know what's cooler? Not having a sway bar. :cool:
    Also, like the other post said, don't forget to torque that UCA nut.
    Mlofthou[QUOTED] likes this.
  9. Oct 2, 2024 at 10:19 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    I figured as such, since I have done the same, but thought it worth the double-checking...:thumbsup:
  10. Oct 2, 2024 at 10:19 AM
    Fireme
    Fireme Well-Known Member
    Bill
    St.JoMo
    2023 LR DCSBOR
    265/75-16 KO2, 16”trd beadlock, 23 OEM Pro Fox sus, OEM roof bar, seat spacer, sequencing mirror indicators, RC tri fold bed cover, weathertech mats. Homemade bam bed sleeping platform.
    I’m glad to see raised white letters on those new KO3’s, I considered waiting for those in a 16”, but was worried about not getting RWL, I sprung for KO2’s last fall. Also I’m 99.9% sure the factory size is 265/70-16 which were 1 size smaller / 1”shorter .
  11. Oct 2, 2024 at 11:41 AM
    Not a burrito but a taco
    Not a burrito but a taco Well-Known Member
    Billy
    Portland, OR
    2020 TRD OR TACOMA
    A few.
    I pulled the trigger on some 35s yesterday and got the new wheels on. I’m psyched on how it looks! Now I need to bust out the cutoff wheel and go to work on the fenders, again. I have to make some decisions on if I want to go LT or just put some stock length LCAs on and/or do a CMR. TBD.
    MAVC33, echoboom, spin180 and 20 others like this.
  12. Oct 2, 2024 at 12:05 PM
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Please forgive my ignorance but the buzzer that sounds when you have the truck running and get out and shut the door. It beeps 8 times, even when you leave the drivers door open and get out and open another door and then shut it, it beeps 8 freaking times. Where is this buzzer located ? It definitely sounds like it is exterior of the cab. Silly question I know but still would like to know where that damn thing is.
  13. Oct 2, 2024 at 12:17 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    You might be able to change this volume level or turn it off completely in the head unit audio settings. I haven't messed with them in a while but just about all of the beeps on this truck are obnoxious.
    EDIT:
    I don't recall seeing this setting in tech stream either or I would have disabled it too. How these trucks react with the Smart Key is pretty annoying. I like not having a key overall, but I wish the settings were more customizable. At least there's finally an option to keep the truck running when you remote start it and open the door.
    bmg88201[QUOTED] likes this.
  14. Oct 2, 2024 at 12:58 PM
    Antboooy
    Antboooy Well-Known Member
    Ant
    Southern Oregon
    2016 Silver Tacoma TRD 2WD
    Bilstein 5100 front and rear Eibach lift springs Freedom Off-road UCAs Torch Off-road 1.5in AAL
    I got an alignment on Tuesday. How do my numbers look? It rides great now that I went from E rated to SL tires. The alignment really helped to tighten things up.
    She sits so pretty on the 4runner snowflakes
  15. Oct 2, 2024 at 1:04 PM
    bmg88201
    Brian
    Quitman, AR
    2022 Tacoma Limited
    Thanks for your response. I might be wrong but I still believe that this particular alarm is exterior of the cab and I’m gonna try to find it. Maybe I can muffle it or disconnect it.
  16. Oct 2, 2024 at 1:12 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    The beep definitely comes from from a speaker in the engine bay, but there might be a setting in the head unit to adjust it. I haven't changed mine because I like the audible beep when I lock/unlock the truck and don't want to lose that.
    A workaround for you though would be just not to close the driver door when the truck is running, as that's what activates the beep.
  17. Oct 2, 2024 at 1:18 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    Tell me more re: "At least there's finally an option to keep the truck running when you remote start it and open the door."
    That's something I'll look into, even though I usually forget I even have remote start until I get into a freezing vehicle.
  18. Oct 2, 2024 at 1:21 PM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I don't see much difference in any of the numbers. It looked decent before and after.
  19. Oct 2, 2024 at 1:24 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
  20. Oct 2, 2024 at 1:54 PM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    I like those 4unner wheels. Also. Where’d your flares go?
