  1. Oct 3, 2024 at 9:20 AM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Hondas have been doing this for decades..
    You'd think Toyota would by now..
    RxYoda and atc250r[QUOTED] like this.
  2. Oct 3, 2024 at 9:32 AM
    TacoThomas21
    TacoThomas21 Well-Known Member
    2021 TRD Off-Road
    TRD Lift, TRD Wheels, RSG sliders, RCI skid plate
    Finally found my Cement Tacoma Hot Wheels!
    Shiro213, spin180, RIX TUX and 3 others like this.
  3. Oct 3, 2024 at 10:04 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I used an appropriate length of airhose (w/ rubber capped QDs) to keep the front flap tucked in between the bed and cab. Now I have an extra section of hose if I need to reach a bit farther from my on-board compressor.
    I also keep two lengths of 1/2" PVC pipe with male snaps attached, at proper intervals, to rollup the sides neat & clean.
    I know I took photos when I installed the snaps to the pipe (6 yrs ago) but damn if I can find them now.
    This photo shows the white pipe, just above the shovel on the left side. And on the right too. The pipe rests very neatly between the topper canvas and framework. Absolutely no rubbing on topper or framework, no loss or falling out, and it has come in handy once or twice to retrieve something deep in the bed so I didn't have to crawl up in there. (the photo was taken to show the fit side-to-side of a 50g Rugged tub)
    spin180 likes this.
  4. Oct 3, 2024 at 10:35 AM
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    Oh I like that. Those pvc pipes will be next. Great idea!
  5. Oct 3, 2024 at 10:39 AM
    TartanEagle
    '17 ACLB 4x4 MT
    You can buy the male end of the snaps -with wee screws- right from SoftTopper. (At least you used to be able to. I haven't looked in a while.)
    Be sure to put smooth rounded caps on the pipe-ends where those ends would touch the canvas (i.e. front & rear Topper panels).
  6. Oct 3, 2024 at 10:43 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    https://softopper.com/products/snap-screws/
  7. Oct 3, 2024 at 10:51 AM
    MagicToolbox
    MagicToolbox Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    I dunno what we are talking about, but that has never stopped me from giving my opinion before. I made a tent and used screw in snaps from Seattle Fabrics in my build. I don't know what size would be compatible - but I HIGHLY doubt soft-toppers are using proprietary snaps.
    musicisevil likes this.
  8. Oct 3, 2024 at 10:56 AM
    TartanEagle
    '17 ACLB 4x4 MT
    No, never meant to imply they used proprietary snaps. Simply that they carry the proper size, which saves one from having to search around.
    Giving your opinion was a bonus this time - you provided one more link for items we can make use of. That alone make it a worthy post.
    VTCAL and musicisevil like this.
  9. Oct 3, 2024 at 11:01 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Does anyone have the thread # for the fix to the Sway bar hitting coilover? Upon inspection, I have a little of that going on I think it only occurs during full turn to right stop, but I'm thinking it might be better that it is fixed. TIA.20241003_135007.jpg 20241003_135031.jpg
  10. Oct 3, 2024 at 11:24 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Hot Dam! No more bleeping beeping when starting the engine, doors open, and walking away with fob in pocket! Thank you.20241003_140637.jpg 20241003_141008.jpg 20241003_141133.jpg
  11. Oct 3, 2024 at 12:15 PM
    TartanEagle
    '17 ACLB 4x4 MT
    Other mods that I (& many others) have done include (plz excuse if you've already accomplished these):
    a.) Sliding this insulation between the canvas and the frame inside the Topper ceiling. I kept it long enough to cover the rear window also. (It is rolled up above the window for driving.)
    DGSL Double Reflective Bubble Foil Insulation Foam, 47 in X 10 FT Aluminum Foil Thermal Insulation Radiant Barrier for Window, Garage Door, RV, Roof - Amazon.com
    b.) We covered using the snaps (on the PVC pipes) for running Safari mode. Now let's deal with the retaining buckles on the outside top for securing that rolled Safari mode. Get an extra 6-10 of those buckles (the repair kit from ST is prefect because you can install them on a closed loop strap without sewing) and attach the appropriate mating end to the edge of a lightweight tarp. Buckle the tarp to the Topper and support the other edge with poles. (PVC pipe, dead saplings, hiking poles, etc.) Easy Awning for either side. Or both sides if you make two.
    Realize that the Topper will have two buckles at each location along the top sides. This will enable you to secure the Safari mode rolls of canvas -and- allow the tarp/awning to click into the second set of buckles at the same time. Pet stores sell miniature size tennis balls. One cut in half provides two protectors (pole to tarp contact) to save ripping your tarp, and are easy to carry on a string attached to the poles.
    btw; the repair kit (from ST!) are different size buckles than the original (at least on my 2017 model Topper). WTH???? Not a worry when it comes to attaching the awning, but I'm out of luck if I have to replace a Safari mode buckle. Grrrrr!
    c.) Also with PVC pipe, you can rig "stand-off" poles for the topper side flaps to angle/slant them downwards, but still open for cross breeze, during rain showers. Put the male snap ends into the PVC caps and stick the caps on these short pipes. Other pipe ends just wedge against the topper frame rail along the top of the bed. Bungies can be your friend here. Or you can create an actual attachment to prevent the wind from lifting the flap and pulling the poles free. (Hate it when they bang into the side of the truck, even though they are lightweight and non-marring.)
    d.) I zip-tied LED light strips to three of the toppers' ceiling frame tubes. Ran power from the fuse box, to a switch, to the lights. Also ran 4 matching light strips just under the bed rails, so I'll still have light if the topper is folded or removed.
    e.) Last bit of ST mod I've done was to hang my old military mosquito-bar inside the topper for full 360* net coverage --- and still get cross-breezes from any/every direction. The mosquito-bar has plenty of attached tie-ribbons to allow hanging it inside of the old two-piece canvas puptents. (Circa 1940-1990) Those ribbons work swell when attaching the net to the topper ceiling frames. Though sometimes I enhance it with zip-ties. Also, this net is wide enough and long enough to cover my 6' bed.
    In fact, just last week I picked up another one from the local army-navy store for $10. New ones there are $20, but this old one was complete, did not have any holes, and had all of the ribbons secured. (Going to use it in teaching my nephews poncho shelters.)
  12. Oct 3, 2024 at 12:17 PM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    Does it still beep when you lock and unlock? I think that all comes from the same thing.
    drizzoh and musicisevil like this.
  13. Oct 3, 2024 at 12:32 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Good call, no beeping on lock/unlock. I had my beep on lock/unlock turned down, so I'll confirm later if it is totally disabled now. I don't remember if I had that beep off, or down low....
  14. Oct 3, 2024 at 12:53 PM
    jgarverick
    2021 DC SR
    Appreciate all these ideas guys. Top notch stuff.
    TartanEagle[QUOTED] likes this.
  15. Oct 3, 2024 at 1:03 PM
    MrMobile
    MrMobile Well-Known Member
    Greg
    Colorado
    22 TRD OR DCSB Lunar Rock
    RCI sliders & engine skid, BAKFlip MX4, PPF, and many other smaller things
    I use the same selective hearing I developed for crying babies, whiny teenagers, and dramatic women on cellphones in public (just haven't managed to block out the dramatic guys yet...still working on that). I just don't notice it until someone reminds me it makes those noises.
    Antboooy[QUOTED] likes this.
  16. Oct 3, 2024 at 1:06 PM
    dmca
    dmca Active Member
    There’s a block button on TW to do that for the dramatic guys. :D
  17. Oct 3, 2024 at 1:49 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Ditch lights done! 20241003_152434.jpg 20241003_152834.jpg 20241003_152910.jpg 20241003_153048.jpg 20241003_153110.jpg
  18. Oct 3, 2024 at 2:00 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Beep is gone for lock/unlock. I'll need to evaluate that, maybe reinsert that buzzer for that reason, although it is so annoying when I got it running and forget something sitting in the kitchen that I need to retreive.:rolleyes:20241003_161737.jpg
    tvterry, MrMobile and musicisevil like this.
  19. Oct 3, 2024 at 4:49 PM
    MGMDesertTaco
    I wasn't aware it was an issue with factory suspension. I know Accutune makes brackets for the fox elite 2.5's for this reason.
    dand and thomasburk[QUOTED] like this.
  20. Oct 3, 2024 at 6:32 PM
    ITmaD
    ITmaD Well-Known Member
    Atlanta
    Installed a new set of Alpha Rex
