  1. Oct 8, 2024 at 9:23 AM
    Shayne
    Shayne Well-Known Member
    Shayne
    South Shore, Mass
    2018 Inferno TRD Sport DC 4x4
    How is the condition of the paint? Any fading issues?
  2. Oct 8, 2024 at 9:24 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    Flip a coozie over it.
  3. Oct 8, 2024 at 10:17 AM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    Check out Taco Garage, they have a kit that may address this. I'm running there DMM , with multiple mounts, and love it. Also, great customer support!
    SHADOWDRIFTER19 likes this.
  4. Oct 8, 2024 at 10:36 AM
    tacotrdyota
    tacotrdyota Well-Known Member
    Kevin
    Lloydminster Alberta
    2018 Tacoma trd sport
    Paint under is perfect. Hard to tell if it faded with white.
    Shayne[QUOTED] likes this.
  5. Oct 8, 2024 at 12:22 PM
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
    MAS, spin180, RIX TUX and 6 others like this.
  6. Oct 8, 2024 at 12:23 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Looooove my Husky's <3
    RobWinNC and Spadi_5[QUOTED] like this.
  7. Oct 8, 2024 at 12:43 PM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
  8. Oct 8, 2024 at 1:12 PM
    Spadi_5
    Wisconsin
    2019 DCSB TRD OR
    I wish I would have gotten them a long time ago. Sooo much more coverage than the oem mats.
    drizzoh[QUOTED] likes this.
  9. Oct 8, 2024 at 1:49 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Not so. I've used synthetics exclusively since 1979. No problems getting it. No problems using it.
    CharlesB and B6P6P6 like this.
  10. Oct 8, 2024 at 4:10 PM
    danedeath
    danedeath Active Member
    Raleigh, NC
    2021 MGM TRD Sport
    Made a 3d print mount for a switch pro. Decided to go with this as I wanted to keep the sunglasses holder. It does block the SOS but to slightly, but I don’t have a subscription anyway.
    Took multiple iterations to find a solution I liked. Printed out of PAHT-CF as a final.
  11. Oct 8, 2024 at 4:20 PM
    RockBunny
    RockBunny Well-Known Member
    Northern NH
    22 LunarTRD DCLB Sport
    Finally got the hood lift struts and installed them.
    I tried to change the engine oil but I can't get the filter off ! I'm not a weakling and used a 24" breaker bar....
    Gave up and schedualled oil change at dealer. I've only had it for a thousand miles and it's a dealer who tightened it too much. I've also had to remove half a cup of brake fluid and cut off the previous person's trailer hitch lock.
    Also had to use the big breaker bar to get the r. diff. fill plug off.
    RealTruck, spin180, TacosMan and 8 others like this.
  12. Oct 8, 2024 at 4:23 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Did you use a Motivx tool with a breaker bar? That tool should hold onto the the filter housing at at strongest point, then breakerbar in small increments.
    https://www.motivxtools.com/collections/oil-filter-wrenches
    RIX TUX likes this.
  13. Oct 8, 2024 at 4:26 PM
    RockBunny
    Northern NH
    Yes. The standard cup like tool I already had several of to use on my RAV4 and Lexus RX 350. I used a socket on the socket part of the tool.
    MGMDesertTaco likes this.
  14. Oct 8, 2024 at 4:31 PM
    Darthkevyn
    Darthkevyn Well-Known Member
    Kevin
    Washington State
    2020 Cement TRD Off Road
    HAM radio installed, Kenwood head unit installed, tinted windows, TRD pro tail lights, MESO laser etched (topo) blacked out emblems and steering wheel cover, MESO dome and map lights, 3rd bed rail installed, MESO skip button installed, Puddle lights, bed lights, MESO over head rack, Kicker speakers, JL Audio stealth Box subwoofer, Alpine amp, 3TPAM installed.
    561c6f3d-ffb6-4a00-88be-bf7f76ecfaaf.jpg 76b542a5-72b0-4b29-aeb1-7a6eaca3f593.jpgDecided to finally upgrade the stock head unit. I'm pretty stoked about it.
  15. Oct 8, 2024 at 4:37 PM
    danedeath
    Raleigh, NC
    2021 MGM TRD Sport
    What brand and model is that?
    Tlaloc1916 likes this.
  16. Oct 8, 2024 at 4:42 PM
    Darthkevyn
    Kevin
    Washington State
    Kenwood DNR1007XR it's pretty awesome. If you look into it and don't need standalone Navigation you can save some money by going for the DMX1057XR
  17. Oct 8, 2024 at 4:48 PM
    Darthkevyn
    Kevin
    Washington State
    Yeah you can install a 3TPAM I have one in my rig and went with 2 USB C But this is for power only.
    AwesomeLaw68[QUOTED] likes this.
  18. Oct 8, 2024 at 4:49 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    As you mentioned, It was probably the dealer who tightened the filter housing too tight - they will do it again. They cannot help themselves. Please don't let the dealer change your oil, you can do it, give it another shot another day. IMHO. Sometimes, laying on your back, under truck, feet toward rear head toward the engine, and find a place to put your feet & toes up into the undercarriage so that you can get some cranking strength on that 24" breaker bar, you should be able to loosen it. Like @RichochetRabbit said, get a good tool and make sure it is seated square before bearing down on it. Good Luck.
  19. Oct 8, 2024 at 4:53 PM
    RockBunny
    Northern NH
    Thanks for the encouragement but I've done that. Braced myself and used my leg on the bar. Pretty much ruined the 3/8" square hole on the cup before I started on the socket.
    Cup doesn't go on very far. It was popping off, losing paint.....
    It's ok. They have the best price on the winter tires I want by a couple hundred bucks.
    Edit to add... this isn't the dealer I got it from.
    RIX TUX and thomasburk like this.
  20. Oct 8, 2024 at 4:56 PM
    RichochetRabbit
    Motivx goes on far enough that any tiny amount of oil makes a suction that is annoying. I sometimes have to hammer the Motivx lightly to unseal the vacuum (on the Motivx tool, that is, not the vacuum in my head).
    RockBunny[QUOTED] and thomasburk like this.
