  1. Nov 26, 2024 at 9:07 AM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Just say NO to LED tag lights
    Tacosha, usmc2msu and RIX TUX[QUOTED] like this.
  2. Nov 26, 2024 at 9:08 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    If those do not work, Rough Country is only $200 for custom-fit front and back ... neoprene. I like mine so far ... easier to slide off the edge but you do not slide around while sitting.
  3. Nov 26, 2024 at 9:15 AM
    SHADOWDRIFTER19
    SHADOWDRIFTER19 .
    RH
    2019 2.7L TSS OR
    TRD cat back, molle panel, and Knobs from @illjimae (can't beat $7) . Looking to put my half gallon, recovery boards, hatchet, utility shovel and a bottle jack.
    Shiro213, illjimae, 17taconut and 6 others like this.
  4. Nov 26, 2024 at 9:20 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM), AVS In-Channel Rain Guards (smoke),
    And I get that, and I can't wrap my head around why someone would buy a TRD 2wd and do a lift kit, bigger tires, metal bumpers light bars etc etc etc, why not just buy a 4x4 to begin with?? But to each their own and I am not going to ask them why they do what they do...
    Besides, you are only blocking part of the light, no different then the low beams being cut off at the top, doesn't affect pointing in front of you no more than the blockers affect illuminating the tags...
    sphinxbccp and MagicToolbox like this.
  5. Nov 26, 2024 at 10:56 AM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    New shoes - Yokohama Geolandar AT G015 (replaced the Firestone Destination LE2 tires that came with the truck and lasted for 48,700 miles) and new battery (the original worked great for almost 5 years).
    spin180, Taco22trdor, MAS and 4 others like this.
  6. Nov 26, 2024 at 11:51 AM
    scouterjan
    Jan
    Probably close to 3 hrs getting the outside clean, including pressure washing the underside. Next up, relocation of rear diff breather 20241126_113310.jpg
  7. Nov 26, 2024 at 12:10 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    :popcorn:
    BC Hunter and PondScum like this.
  8. Nov 26, 2024 at 1:40 PM
    OLDTRAP
    OLDTRAP Well-Known Member
    2021 TRD OR
    Stock
    I like the blacked out hood. Is this a Toyota part or aftermarket?
    scouterjan[QUOTED] likes this.
  9. Nov 26, 2024 at 2:02 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Grabbed an OEM exhaust tip for Black Friday
    Tha whistles go WOOO
    wradar, kent50, spin180 and 2 others like this.
  10. Nov 26, 2024 at 2:22 PM
    azhiaziam
    azhiaziam Well-Known Member
    The reef ca
    White 2023 trd off-road
    ordered oem headlights and bilstein 6112 / 5190 setup
  11. Nov 26, 2024 at 2:38 PM
    scouterjan
    Jan
    I had it wrapped along with the B pillars
  12. Nov 26, 2024 at 2:51 PM
    Tlaloc1916
    Tlaloc1916 Well-Known Member
    Magnolia Tejas
    2021 SRish 4x4
    Nice! Have a similar set up.
  13. Nov 26, 2024 at 5:25 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    WW I Jeeps?
    :D
  14. Nov 26, 2024 at 6:12 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Did engine maintenance servise at my 117K km:
    New spark plugs
    Throttle body clean
    Injectors flush
    New PCV valve
    Cooling system flush+new coolant.
    with next oil change will be all fluids changed - MT, transfer case, fr&rear differentials.
    17taconut, spin180, DavesSR5 and 3 others like this.
  15. Nov 26, 2024 at 7:27 PM
    B6P6P6
    B6P6P6 Well-Hung Member
    Brian
    Firestone,Colorado
    2023 Tacoma Sport
    It’s like when you really want to see something, you squint your eyes and tilt your head to the side.doesn’t make sense but we all do it.
    DavesSR5[QUOTED] likes this.
  16. Nov 26, 2024 at 7:44 PM
    RIX TUX
    these are not that bright a better color
    Tlaloc1916 likes this.
  17. Nov 26, 2024 at 7:59 PM
    RIX TUX
    :worthless:
  18. Nov 26, 2024 at 8:04 PM
    RIX TUX
    Jeep Enthusiast Forums
    dand likes this.
  19. Nov 26, 2024 at 8:07 PM
    RoyN86
    RoyN86 New Member
    Roy
    Changed the oil for the first time on my tacoma since buying it earlier this month. Wish I had some heads-up that hot 0w20 would splash everywhere when it hit the drain pain :D
    thomasburk, robin303 and DavesSR5 like this.
  20. Nov 26, 2024 at 8:09 PM
    RIX TUX
    welcome.........to TW
    did you do it at 10k? :popcorn:
